or Connect
New Posts  All Forums:Forum Nav:
£80 DAC
post #1 of 6
Thread Starter
Hi there I have recently purchased a Little dot mkiii and am very happy with it however I now need to look for a decent DAC to pair it with. I am not looking to spend over £80 and was wondering whats the best option for me. So far I have identified the smsl 1955+ and the HiFimeDIY Sabre U2 Async as being in my price range with good reviews and was wondering if I should get one of them or something that might be even better?
post #2 of 6
Thread Starter
help would be greatly appreciated
post #3 of 6
Originally Posted by sgbwill2 View Post
... I am not looking to spend over £80 and was wondering whats the best option for me...
Best option is keep saving!
When you reach £100 you will be able to afford a used Arcam rPAC. Job done.
post #4 of 6
Thread Starter
Thanks for the reply but i already got the topping d20 and it really is superb. so much so that i might buy a topping t-class power amp to drive some new bookshelf speakers i just bought :D
post #5 of 6
I have a TP20 mkII and it is astonishingly good provided you only need 5 Watts (which is true for most people most of the time).
post #6 of 6
Thread Starter
Im so happy with my Topping D20 that I just ordered a Topping TP-22 T-amp similar to the TP-20 that you have but uses an upgraded 2050 chip which supplies more power. I'm going to use it as a power amp to drive my mordaunt-short avant 902i using the laptop as source to the D20 DAC to little dot mkiii as a pre amp then to the TP-22. Hopefully this setup will work nicely as ive heard good things about the TP-22 and the similar TP-20 you have. For the price you get a good product with the D20 so hopefully the TP-22 will follow suit :)
  Return Home
  Back to Forum: Dedicated Source Components
