or Connect
New Posts  All Forums:Forum Nav:
$20 IEMs?
post #1 of 6
Thread Starter
Hi all,
I'm currently looking to buy a cheap pair of IEMs (around $20) and I need recommendations.  The headphones that I use most of the time right now are my UE 6000s, but I was hoping to get some cheap IEMs that I could just throw in my backpack and use on the go.
In terms of SQ, I was looking for something that is somewhat balanced (slight bass emphasis would be fine, but definitely nothing too overpowering).  At this price point, however, I don't really know if that's possible...
Anyway, I was currently considering the Meelectronics M9 and Philips SHE 3580 based on reviews I've read in these forums.  Any suggestions or new recommendations?
Thanks for the input!
post #2 of 6
What about that cheap $7 monoprice or from what I've read the JVC FX40 is pretty good.
post #3 of 6
I'll be watching this thread to see what advice you get, just letting you know I posted a fairly similar question and I may get answers helpful to you: http://www.head-fi.org/t/689359/iem-sub-30-question-dunu-trident-vs-brainwavz-delta-vs-cw31-vs-m9-sl
post #4 of 6
Thread Starter
Thanks for sharing this!  I'll check it out
I've heard good things about the monoprice 8320s as well, but I'm worried over the fit...
post #5 of 6
I just remembered the sony xba-1 can be had for around $25 if you shop around.
post #6 of 6
Thread Starter
Thanks for the suggestion; it looks interesting...about $30 on Amazon, but i'll shop around
  Return Home
