or Connect
Head-Fi.org › Forums › Equipment Forums › Computer Audio › $2000 Setup. Help me complete it!
New Posts  All Forums:Forum Nav:
post #1 of 5
Thread Starter
Just got a sweet new computer and I'd like to do some music production. I've decided upon Senn HD600s for cans, KRK Rokit 6's/8's (or maybe even VXT 4's) for monitors, and Ableton. Now I just need help selecting an interface.
My main concern is losing sound quality/fidelity using an audio interface with a built-in DAC as opposed to a dedicated/boutique DAC (was looking at something in the $500 range like an AudioGD NFB-10, Nuforce Icon HDP, or maybe just a Schiit Bifrost).
I want the audiophile playback of a dedicated DAC in an interface. Any recommendations? Or are there any suggestions for an standalone interface/controller I could just add to a dedicated DAC for D/A?
I need to put in an order soon as I'm currently living in Korea and have a friend coming over from the States soon.
Any input would be great! Thanks
post #2 of 5
The bifrost is a wonderful dac. Given it's price to performance ratio, it punches way above it's weight class. Very well built, beautifully renders music. Good company standing behind it also.
post #3 of 5
Thread Starter
Yeah, it looks super sleek and cool.
If I go with that, are you familiar with any standalone recording interfaces that I could add to my chain?
Computer --> Bifrost --> Interface (???) --> Monitors
Or would it be redundant as most quality interfaces already have a DAC inside? I'm concerned with the quality difference between a dedicated DAC and one included in an audio interface (like the Apogee Duet, for example).
post #4 of 5
There's nothing wrong with the pro-audio interfaces. If all you're looking for is D/A, then a boutique dac is fine. If you need something with A/D and other controller functions, then stick with the pro devices and have fewer components in the chain. I myself have had good experience with Focusrite equipment.
post #5 of 5
Thread Starter
Thanks for the reply :)
I posted a similar thread on gearslutz and it looks like I'll be going with an RME Babyface!
  Return Home
  Back to Forum: Computer Audio
