I have been following this forum for a while and finally decided to build a DAC and an amp. Since others (especially amb and Mister X) have contributed so much, I thought the least I could do was to post the BOMs for the units I will build (σ11 + γ1 + M³). Also, happy birthday amb! (Noticed it in your profile, since it is my birthday too.
If anyone has comments on the BOMs, let me know. I will try to fix any mistakes. I am ordering these tonight from Digi-Key and Mouser.
The following are for Digi-Key. Copy and paste into their BOM wizard.
σ11
γ1
M³
Parts not available at Digi-Key:
From Mouser:
All for M³ except last two, which are for σ11.
I am sure I missed something! So I will update this post as mistakes are discovered. There is no warranty for speling or that the lists are complet.
Since this is my first post.... Electronics used to be a hobby of mine a looong time ago. I am so excited to have found this forum with such a friendly and helpful community, and to get started building audio components. I plan to use the units at work where I spend my days by a computer (programmer).
Cheers,
- Henrik
)If anyone has comments on the BOMs, let me know. I will try to fix any mistakes. I am ordering these tonight from Digi-Key and Mouser.
σ11
Code:
10P10.0KCACT-ND 10P1.00KCACT-ND 10P100CACT-ND 10P0.47W-2BK-ND 10BC1065CT-ND 10P10356-ND 10P10343-ND 1P10351-ND 1478-3399-ND 4MUR820GOS-ND 1P467-ND 1345-1006-ND 4277-1247-ND 1277-1249-ND 1TE62062-ND 1HM981-ND 1Q206-ND 1450-1666-ND
Code:
1296-1088-1-ND 1296-1091-1-ND 1296-9819-5-ND 22N3904FS-ND 1360-1772-ND 1399-4143-ND 8399-4148-ND 1399-4172-ND 1399-4179-ND 14399-4264-ND 1399-4290-ND 4445-2857-ND 2470-1003-ND 3565-3051-ND 1598-1123-5-ND 3604-1051-ND 1754-1243-ND 1HM969-ND 1HM970-ND 1LP2985AIM5-3.3CT-ND 1LP2985AIM5-4.5CT-ND 1MCP100-315DI/TO-ND 1MCP101-315DI/TO-ND 10P1.00MCACT-ND 10P1.50KCACT-ND 10P110CACT-ND 10P22.0CACT-ND 10P22.0KCACT-ND 10P220CACT-ND 10P3.00KCACT-ND 10P47.0KCACT-ND 10P560CACT-ND 10P75.0CACT-ND 4S1011E-02-ND 2S1011E-03-ND 1S7036-ND 1S7038-ND 1S9001-ND 1T999-P5P-ND 2TORX147PLFT-ND 1WM17115-ND
Code:
10P1.00MCACT-ND 10P1.00KCACT-ND 10P10.0KCACT-ND 10P100CACT-ND 10P7.50KCACT-ND 1P1.0W-2BK-ND 3CT94EW102-ND 3CT94EW502-ND 10BC1007CT-ND 10BC1065CT-ND 10P10323-ND 10P11258-ND 2BC2062-ND 11N4001DICT-ND 42N3904D26ZCT-ND 12N3906D26ZCT-ND 10ED5308-ND 2OPA627AP-ND 10WM4200-ND 10WM2000-ND 1277-1247-ND
From Mouser:
Code:
1546-1455T2202BKInstrument Enclosures 8.66 x 6.3 x 2.1 Black 1163-1061-EXDC Power Jacks 2.5MM SNAP-IN PNL MT 1568-NJ3FP6C-BAGPhone Jacks 1/4 LOCKING JACK BK 2502-3501FPX RCA Phono Connectors FRONT MOUNT JACK 1610-1N53141N5314 1610-1N53071N5307
Cheers,
- Henrik
