New Posts  All Forums:Forum Nav:
2500 Pro vs 2200 HiFi
post #1 of 11
Thread Starter
Been wanting to grab some cans that fold up neat so I can pack them away in a case for use in hotels etc.
I have been looking at the 2500's and was just about to buy when I spotted that the 2200 are some £30 cheaper from the same website, so I thought .. whats the difference between them soundwise etc, or will the 2200 be just as good a headphone as the 2500 give or take the colour!
post #2 of 11
The 2200ULE is an open design, and uses a gold-plated driver.
The 2500 is also an open can, but uses a higher-resolution, titanium plated drive, and less forgiving of bad recordings & associated gear.
If using for travel, I'd suggest also looking at their closed counterparts - the PRO650 and the PRO750 respectively wrt the drivers.
post #3 of 11
The PROline 2500 is the open back version of the 750. I have owned the 2500 for a while and really like its sound. However I should mention that not all enjoy its highs, those few indicate they are astrigent and harsh. I do not hear so but I thought I should mention.
BTW, I also use my 2500 as transportable and have enjoyed every second of their use in my office or while traveling. Since it comes w/ two cables you could shorten one and re-terminated it into a 1/8" so it is easier to use while traveling.
Good luck.
post #4 of 11
Thread Starter
ok, so I assume no-one has the 2200, but lots have the 2500 and 750.
I was curious because on the website the 2200 retails for £20 more than the 2500 and 750, but in the sale it comes out to the £30 cheaper.
I have IEM and NC phones for travelling, but was after a set of cans to use whilst away from home, that can be packed away small and not get mashed whilse baggage handlers do there thing.
BT
post #5 of 11
BT
BT, in my experience the blue paint on the PROline 2500 is not very durable. I have seen many examples where the paint has flaked off and they have plenty of nicks and scratches. I am very careful w/ my gear and the headband on my PROline 2500 looks pretty beat up. It does not matter to me because IMO they sound awesome, but you should know the issue w/ the paint.
post #6 of 11
The latest 2008 models have an improved headband, and also now come inside a hard-cover case that will withstand much abuse, and protects the cans quite well.
post #7 of 11
Originally Posted by silverrain View Post
The latest 2008 models have an improved headband, and also now come inside a hard-cover case..
How about sonics of the 2008 model ? Any difference from the old models ? I mean the Pro 2500.
post #8 of 11
I only bought the 2008 model of PRO 750, 2500, and HFI-780.
There should be many peeps here that have older ones, and bought newer ones, that can answer that.
post #9 of 11
I was wondering the same thing. I swapped an AKG K271S a while ago for an Ultrasone HFI-2200ULE, but only listened to them briefly when I got them. About a week ago, I pulled them out and gave them a good listen and haven't listened to anything since then. They are very good headphones to my ears. They suffer a bit from lack of detail compared to my DT880 '03, but are much more fun to listen to. I tried the PL2500 a while ago and I think I got rid of them too soon...not enough burn-in as I bought them new. I'm thinking I should revisit them but didn't know whether to go for the older or newer ones.
post #10 of 11
When I bought my Ultrasones recently, I was thinking about getting one of those leftover (on-sale) pre-2008 ones for less money, since I have read many times that they were sonically the same as the newer ones -- but, I read on the Ultrasone site that the 2008 models had improved headband, improved thicker earpads, and also a new hard-case, too -- all that combined made me just go for the newer 2008 models.
post #11 of 11
The drivers and technology are still the same, it just perhaps more durable, and the hard case is definately very attractive indeed.
  Return Home
  Back to Forum: Ultrasone Premier Sponsor Forum
