So I just got my brand new MicroStack the other day and have been enjoying it every spare minute I've had ever since. I initially purchased an Ultra Micro amp, but then decided that I would have a better sounding setup if I had a standalone DAC. So I exchanged it for the Micro amp and DAC. The added transparency from the DAC is amazing. I have SE530s and even with these the noise floor is almost completely silent. I can hear rooms if that's believable. Some bands you can tell they lay down vocal and instrumental tracks in different rooms because the drums and vocal echo differently. I realize that this isn't the most expensive or "best" headphone rig by far. I do, however think that this is definitely one of the best setups for sub $1,000 and honestly probably just as good as some costing twice as much. Having the Amp and DAC in separate components allows HeadRoom to keep the signals isolated providing better audio quality without having to really up the price cost to keep the signals separate with hyper expensive multilayer boards and the like. Instead they can put all of the money into the individual bits and pieces of the units, which really shows. The top of the line Cirrus DAC chip and wonderful TI Op-amps are an amazing combination together. The Amp is biased into class A too I believe. I doubt this makes a huge difference with low impedance earphones like the shures, but for those with 300 ohm Sennheisers it's nice to know that this amp can completely drive them to their full potential without distorting. Admittedly I haven't done a very wide variety of listening yet so I won't do a full review at this time. Initial impressions though are great. Not as hyper detailed as a Grace m902, but has an amazing warm and musical feel to it. The Grace was designed as a sound engineers tool and so is used to analyze music not necessarily to enjoy it. (although many do) This combo has the typical headroom sound sig. which IMHO sounds detailed and articulate but not like I'm analyzing the music under an electron microscope, more like I'm just watching on my hi-def tv. Crisp and clear but entertaining, just how I like my music to sound.
Head-Fi.org › Forums › Head-Fi Special Forums › Premier Sponsor Forums and Sponsor Forums › Premier Sponsor Forums › HeadRoom Premier Sponsor Forum › 2007 MicroStack
Join Now
Be a part of the community.
It's free, join today!
Recent Reviews
To update in depth shortly.
I loved these buds to bits, they were the perfect everyday headphone. Small and light and comfortable and barely protruded past the outside of your ears. I like the fact that no one can really...
These and the PL30 are terrible quality buds, I went through both of them in less than 8 months. Both times they failed they left me in an awkward position where I really needed earbuds for...
These and the PL50 are terrible quality buds, I went through both of them in less than 8 months. Both times they failed they left me in an awkward position where I really needed earbuds for...
Good value for the use I get out of them professionally and personally.. A great all rounder Can and they make my ears happy ;)
Head-Fi Sponsors
Drop by and thank our partners for helping keep the lights on at Head-Fi!
2007 MicroStack
post #2 of 6
2/16/08 at 7:18pm
- tanis38
- Trader Feedback: 0
- offline
- 27 Posts. Joined 2/2008
- Select All Posts By This User
Thanks for your impressions. I am seriously considering getting a micro stack myself. Just have to save up for it.
post #3 of 6
2/17/08 at 1:16am
- jjcha
- offline
- 3,473 Posts. Joined 1/2004
My guess is that while things certainly can and should change from the 3 or 4 years since the original HeadRoom stack was created, but if you feel you aren't getting the detail that you get from the m902 (which again is not a detailed system, especially on the transient edges), it's the amp that's making it sound that way.
Either way, congratulations on an excellent purchase. I use my HeadRoom Overture (DAC) daily still, and can see why some would like the sound of the amp.
Best regards,
-Jason
post #4 of 6
2/17/08 at 4:34am
- Qosmio
- Trader Feedback: +13
- offline
- 113 Posts. Joined 9/2007
Congrats and thanks for sharing..
- Joelc87
- offline
- 366 Posts. Joined 12/2007
I am by no means an experienced listener or reviewer but will try to give you guys a little more detailed info as far as the sound of the setup when I get a little more time. My first post was just some very initial impressions and my next one will probably be just some more detailed comments and not really a full review.
- Joelc87
- offline
Ok well, I've done some more listening (quite a bit more actually) and from what I've heard I definitely like a lot. The DAC is wonderfully clear, I feel as though I may have misrepresented myself a bit before. When I said that this setup sounds warm and musical and not analytical I meant more that its tonal qualities lend itself more to high end personal listening and not analyzing in a studio. I didn't mean in anyway that it sacrifices detail, although I'm sure that it does that just a little. Overall I'd say that it sounds very nice with all ranges of music. Classical sounds very nice with a very wide soundstage. You hear the conductor breathing front and center and kettle drums and double basses way back in the back. Rock music is very punchy and this is where I notice the warmth the most. This setup is practically perfect to my ears, emphasis TO MY EARS. It has lots of detail but just enough warmth that there is no harshness either. I find myself not having to constantly adjust the volume to hear something and then turning it down to keep my ears from hurting on something else. Bass is low and I mean rumbly low(once again SE530s) very effortless almost as if there was unlimited power behind these little units. Mids are very articulate and "well thought out" but still very immediate and dynamic, this is probably the warmest range with the MicroStack. Vocals are very musical and transparent. Treble range is an interesting range and perhaps exaggerated because of my test headphones.(Shure SE530 and Grado SR60) This is where I most notice the balance between warmth and detail. Trebles are just so detailed but drop off before they get too harsh. Violins scritch and scratch but always pleasing. Every color of the tonal palette sounds smooth through these but still very realistic. It's almost as if someone were to record themselves scratching a chalkboard and play it through this setup, you would hear it and even feel it but it wouldn't hurt your ears. Reverb and decays seem to be very natural as well. I have yet to listen to this with some true full sized audiophile phones (HD650s) or some other type of 300+ ohm variety. Because of the punchy yet pleasing sound signature of this DAC Amp combo I'm pretty sure this would be a great K701 setup. I'll be curious to see what other people have to say about the new MicroStack with full sized phones. Senns, Beyers, and AKGs come to mind.
Return Home
Back to Forum: HeadRoom Premier Sponsor Forum
Currently, there are 1770 Active Users
(357 Members and 1413 Guests)
Recent Discussions
- › JH Audio JH16 Pro First Impressions 1 minute ago
- › The Stax thread (New) 3 minutes ago
- › New Audiolab DAC 4 minutes ago
- › Replacement options for dead Re0s 4 minutes ago
- › Getting "called-out" for not wearing the Beats 4 minutes ago
- › ASIO won't install on Foobar2000 6 minutes ago
- › The GrubDAC 8 minutes ago
- › iBasso DX100 Reference DAP - ES9018 inside 9 minutes ago
- › Looking for someone who can solder a 3.5mm plug to a cable 10 minutes ago
- › Petition for a "Video Games Lounge" subforum. 11 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Corsair Vengeance 1500 - 50mm PC USB 7.1 Dolby Headset + Mic by curiousgeorgieo
- › Etymotic Research ER6i Isolator In-Ear Earphones (Black) by jcotteri
- › PL50 In-ear Headphones by jcotteri
- › Soundmagic Pl30 In-ear Headphones by jcotteri
- › Sennheiser HD 25-1 II Professional Headphone by jcotteri
- › Apple - Apple In-Ear Headphones with Remote and Mic by leochaves
- › Sennheiser HD-558 by mrcrazyshoes
- › FiiO L3 Line Out Dock (LOD) Cable For iPod and iPhone by Thing Fish
- › MEElectronics M9-BK Hi-Fi Sound-Isolating Earphones (Black) by ravefire
- › SanDisk Sansa Clip+ 4 GB MP3 Player (Red) by Oeufdepoire
View: More Reviews
Recent Articles
- › Headphone Buying Guide by keanex
- › Fostex T50RP modification summary LINKS - wiki by ardilla
- › Comparisons of the LCD-3 and the LCD-2 Rev. 2 by MacedonianHero
- › Posting Guidelines by Currawong
- › Comparisons of LCD-2 Rev. 1 and Rev. 2 by MacedonianHero
- › Membership Levels, Badges and Custom Titles by Currawong
- › Sennheiser Hd4 8 Modding For Newbies by koolkat
- › Grado Pad Choices And Mods by Maverickmonk
- › Grado Modification Overview by maxsayer
- › How To Open Your Grado Headphones by chrislangley4253
View: Recent Articles | All Articles
Home | Head Gear | Forums | Articles | My Profile
About Head-Fi.org | Join the Community | Advertise
© 2012 Head-Fi.org is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
