You are in Sleek Audio's Premier Sponsor Forum at Head-Fi.org.
To get back to Head-Fi.org's Main Forums, click here.
Register FAQ Members List Calendar Mark Forums Read Today's Posts Search
Go Back   Head-Fi: Covering Headphones, Earphones and Portable Audio > Premier Sponsor Forums and Sponsor Forums > Sleek Audio Premier Sponsor Forum
Reply
LinkBack Thread Tools
  #166 (permalink)
Old 10-17-2008, 02:36 AM
epithetless's Avatar
Default
Originally Posted by EyeAmEye View Post
Received the wireless today. Yes, there is a small amount of white noise in silent passages.
How small is the amount of white noise? Barely-noticeable small?
__________________
musicophile / euphonophile
team porta-fi / team exo-amplessness / team self-defeating bargain junkies
// feedback //
  #167 (permalink)
Old 10-17-2008, 02:48 AM
Default
You'll hear it in very quiet/silent passages. Not really noticeable any other times.
I should also note two things listening a bit more. It adds some bass, so for those who thought the Sleeks needed a bass++ port, you got it. Secondly, I had to move the volume on the Zune up a notch to achieve the same volume as the wired Sleeks.
__________________
My Feedback - http://www.head-fi.org/forums/f12/eyeameye-56333/
  #168 (permalink)
Old 10-17-2008, 04:00 AM
Default
Cool. Glad to hear you're not having the same problem as Edwood.
__________________
// feedback //
  #169 (permalink)
Old 10-17-2008, 06:37 AM
Junior Head-Fi'er
Default
if you were to use the wireless with a digital piano, would you think that the noise would be an issue?
can you give exemple of tracks and times where you heard the noise.
can you try on:
Gary Jules Mad world
Archie Shepp's Deep River (Goin' Home) or How Long Blues 5 Trouble in Mind)
Star Wars Phantom Menace tack 7 (The Arrival At Tatooine )
is Arnold McCuller 's Free Bird still enjoyable ?
  #170 (permalink)
Old 10-17-2008, 06:45 PM
BloodSugar00's Avatar
Default
Received the wireless today. Yes, there is a small amount of white noise in silent passages. That issue aside, Zune + Sleek wireless + Sleek custom is an absolute winner. This combo kills!
Kudos to the Sleek team once again.
Both very encouraging reports! Heres hoping Edwood was unforntunate enough to recieve a faulty unit. Look forward to more impressions on the W1
__________________
WTB: A resistor Adaptor-http://www.head-fi.org/forums/f44/wtb-resistor-adaptor-attenuator-331783/
My Feedback-http://www.head-fi.org/forums/f12/bloodsugar00-339661/
UK Headphone Society/Can Jam 2009 looking to be set-up. Interested?:
http://www.head-fi.org/forums/f24/uk...2009-a-348887/
  #171 (permalink)
Old 10-17-2008, 10:23 PM
Head-Fi'er
Send a message via AIM to ss64 Send a message via MSN to ss64
Default
humm i must have misread his post, anyways its not noticeable once you turn it up a bit more.
when i had the chance to take a listen i was at work and wanted to listen at low levels just in case if my boss needed me i can hear him...I dont think its that much of a problem now.
I wore it on the bus today and while i was walking to work, some times the track would skip like it was losing signal but it came back after i held my zune up for a little .I thought it was the battery but it only happened when it was in my pocket and walking.
I cant really say about the sound quality because i find it difficult to find the correct fit in my ear.I find it hard to enjoy music when i put these on.i'm gonna get those comply foams which i hope helps.
Overall not the experience i expected.Hopefully it will get better once i get my foamys
  #172 (permalink)
Old 10-20-2008, 03:31 PM
100+ Head-Fi'er
Default
No offence to the engineers at Sleeks, but did you guys have to make the on/off switch so inaccessible? It's really hard to switch it on/off everytime I want to use it because I don't have long nails, and I have to use my PDA stylus to switch it on/off.
__________________
General gear -> Sleek SA6 + Samsung YP-P2 (Retired: Mylar X3i)
Coming soon ->
Used to own -> iBasso T1 / Mylarone 3 / iPod Nano 8GB 2G / Ultimate Link Crescendo i / iRiver Clix2 / Cowon D2 / Livewires T1
  #173 (permalink)
Old 10-20-2008, 04:20 PM
pseudohippy's Avatar
100+ Head-Fi'er
Default
its a good thing they didnt, just hold down the button for a while and it will shut off. That is according to Edwoods post earlier in this thread. Post #157 I believe.
__________________
Gear I've actually Kept:
Cowon D2> Headphonia Penguin CMOY>Sure SE530 (530's currently out for custom treatment)
Cowon S9>Fiio E3 >Sleek SA6 w/Kleer Wireless
Sansa E260>Creative Labs EP-640
RS Raptor>HD650
Sold or given away list is way to long lol
  #174 (permalink)
Old 10-20-2008, 04:36 PM
Head-Fi'er
Default
I would describe using that switch as a "hard" shut down. But you really don't need to use that switch unless you think the wireless is going to be shut down a long time (several days or so). A "soft" shut down, with the easy-to-use button on the surface of the accessory, provides weeks of battery life.
  #175 (permalink)
Old 10-21-2008, 12:22 AM
FeedMeTrance's Avatar
Headphoneus Supremus:
Niiice!
Send a message via MSN to FeedMeTrance
Default
Well I have mine, I do agree with the onn/off switch, had to use a nail file to get it switched.
As for the white noise, yes when the iPod is paused or between songs, otherwise cant really notice it
Sounds aweeeeesome!
__________________
MUSIC| Trance, Dance, Metal, Rock, Pop, Vocal, Classical
SOURCES|
iPod Classic 160GB/iPhone3G 16B
EARS |Westone3/SA6/LiveWires
CAMERA| NikonD90
LENS| 17-55mm f2.8/70-200mm f2.8/VR - 18-200mm/50mm f/1.8
OTHER| SB900/2x SB800
Head-Fi Feedback
  #176 (permalink)
Old 10-21-2008, 03:43 AM
Edwood's Avatar
∙ 1/2 hamster, 1/2 Turkish
∙ Blueteething
Default
LOL, yeah. Thanks.
I'm still waiting for the replacement W-1 Transmitter from Sleek.
-Ed
__________________
My Head-Fi Feedback
  #177 (permalink)
Old 10-21-2008, 08:47 AM
Niiice!
Default
Does anyone who has theres have skipping issues?
I noticed when I had mine in my bag, it wud skip like every 4-5 seconds, thenstop and skip etc, v weird
__________________
SOURCES|
CAMERA| NikonD90
Head-Fi Feedback
  #178 (permalink)
Old 10-21-2008, 04:47 PM
Default
Originally Posted by Edwood View Post
LOL, yeah. Thanks.
-Ed
..collateral damage
__________________
  #179 (permalink)
Old 10-21-2008, 05:16 PM
robojack's Avatar
500+ Head-Fi'er
Send a message via MSN to robojack
Default
Currently, I'm not very happy with the lack of response from Sleek. I emailed them a question regarding shipping a few days ago, and have not received a response yet. This, and along with all the sound quality issues (skipping, white noise, etc.), is making me consider delaying my order of the Wireless transmitter.
__________________
Portable: Cowon D2 > RSA Predator | RSA Tomahawk (backup) > Westone 3 (main) | Sleek Audio SA6 (main) | Futuresonics Atrio M5 (secondary) | UE SuperFi 5 Pro (backup) | SoundMagic PL30 (not impressed)| Koss KSC75 (Kramer-mod with Dowin DW04 adapter)
Home: Diyeden SVDAC04-U USB DAC > Darkvoice 332 > Sennheiser HD650 | AKG K701 | Ultrasone HFI-780 (S2 Audio-mod)
My Feedback
"Friends don't let friends buy Bose."
  #180 (permalink)
Old 10-21-2008, 10:50 PM
Head-Fi'er
Default
Based on my experience, it's better to give them a telephone call. My guess is that they are flooded with email owing to introduction of the new wireless device.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2 Head-Fi.org
