You are in Sleek Audio's Premier Sponsor Forum at Head-Fi.org.
To get back to Head-Fi.org's Main Forums, click here.
Register FAQ Members List Calendar Mark Forums Read Today's Posts Search
Go Back   Head-Fi: Covering Headphones, Earphones and Portable Audio > Premier Sponsor Forums and Sponsor Forums > Sleek Audio Premier Sponsor Forum
Reply
LinkBack Thread Tools
  #151 (permalink)
Old 10-15-2008, 09:30 AM
Junior Head-Fi'er
Default
I don't recall people noticing such noise during the Can Jam on the pre-production unit. I hope it's an unfortunate unit.
  #152 (permalink)
Old 10-15-2008, 11:34 AM
Edwood's Avatar
∙ 1/2 hamster, 1/2 Turkish
∙ Blueteething
Default
It was also quite loud in that room. The buzzing noise is not that loud.
__________________
My Head-Fi Feedback
  #153 (permalink)
Old 10-15-2008, 05:22 PM
100+ Head-Fi'er
Default
How does it compare sonicly to the Sennheiser MX W1?
  #154 (permalink)
Old 10-15-2008, 06:06 PM
BloodSugar00's Avatar
Default
Originally Posted by Edwood View Post
Just got my W-1 Wireless adapter today. Charged it up finally and am listening to it right now.
Initial impression is extreme disappointment. The W-1 has a high amount of noise. It has an annoying high pitched buzzing noise that comes and goes, it seems prone to grounding problems and interference. It does not work well at all with any computer headphone output and it even has ground loop buzzing with my HeadAmp Pico, which I have yet to have anything else have buzzing with. If I touch the sides of the case of the W-1 transmitter, it buzzes louder.
If I'm listening to loud music, it's not noticeable, but with quiet music, it's very annoying.
The high noise floor is unacceptable to me, especially when it's solely used with sensitive IEM's like the SA6. But the noise is loud enough that if I were to mod this W-1 to be able to use with other IEM's it would still be annoying since the SA6 is not nearly as effecient as some other IEM's out there like the Shure E500/SE530.
So what gives? Did I get a defective version? Or is the built in amplifier in the W-1 just that noisy?
-Ed
Woah!! Just shows you, you can't take anything for granted huh? Something looks perfect, a concept well implemented and then your relative naievity is breached when a totally unforseen shortcoming comes to light as with the noise floor/buzzing that you're reporting ED.
Fingers off the trigger for me now. Look forward to more reports and impressions and for feedback form Sleek about this buzzing.
EDIT: Just realised tht I was taken to last unread post and didn't see that the thread had progressed a few pages past that!
EDIT: Post content really still stands after reading rest of thread to date. Look forward to Jason's explortion into the problem.
__________________
WTB: A resistor Adaptor-http://www.head-fi.org/forums/f44/wtb-resistor-adaptor-attenuator-331783/
My Feedback-http://www.head-fi.org/forums/f12/bloodsugar00-339661/
UK Headphone Society/Can Jam 2009 looking to be set-up. Interested?:
http://www.head-fi.org/forums/f24/uk...2009-a-348887/
  #155 (permalink)
Old 10-15-2008, 07:34 PM
100+ Head-Fi'er
Default
Update:
I tried removing the included iPhone adapter cable and putting the W-1 directly onto the headphone out jack of my iPod. With some maneuvering I was able to get the W-1 onto my Headsix without using any extension cable. The high pitch noise gone.
However, the white noise that I hear when W-1 is turned on is still there. It's not as noticeable when music plays, but it's definitely there.
__________________
FLAC -> 840c -> AT-HA5000 -> W5000
FLAC -> 840c -> Staxes
Feedback: Head-Fi
  #156 (permalink)
Old 10-15-2008, 09:16 PM
Edwood's Avatar
∙ Blueteething
Default
I just talked to JasonK on the phone. He thinks it's likely a problem with the Transmitter Unit. He's sending me a new one, and I'm sending mine back for him to take it apart and test it out.
Thanks so much, Jason. Was great talking to you again.
-Ed
__________________
My Head-Fi Feedback
  #157 (permalink)
Old 10-15-2008, 09:18 PM
Edwood's Avatar
∙ Blueteething
Default
Oh, one more thing. Jason clarified a feature for me.
The tiny little power switch is not intended to be used as the sole power switch. It was only really there to keep it off in transit. Holding the power buttons will turn off the units completely. Or after a few hours, it will completely turn off on it's own. That's a great feature, because I often forget to turn things off.
-Ed
__________________
My Head-Fi Feedback
  #158 (permalink)
Old 10-15-2008, 10:20 PM
epithetless's Avatar
Default
I really hope so. I'd like to think Sleek would've encountered a problem like yours during the testing phase if it was due to a universal design flaw...
__________________
musicophile / euphonophile
team porta-fi / team exo-amplessness / team self-defeating bargain junkies
// feedback //
  #159 (permalink)
Old 10-16-2008, 12:05 AM
Edwood's Avatar
∙ Blueteething
Default
Yeah, hopefully it's just a fluke, and I'm just very lucky, uh unlucky.
__________________
My Head-Fi Feedback
  #160 (permalink)
Old 10-16-2008, 12:16 AM
Head-Fi'er
Send a message via AIM to ss64 Send a message via MSN to ss64
Default
Hello , i had just recieved the bundled W1
I get the same white noise issue on less then load songs. ill probably wont RMA it till i know for sure there is a solution.
I use the Zune pass songs which are 192k bit rate songs i believe.I dont use any amps though.
  #161 (permalink)
Old 10-16-2008, 01:25 AM
100+ Head-Fi'er
Default
Godamnit, even you as well?
__________________
General gear -> Sleek SA6 + Samsung YP-P2 (Retired: Mylar X3i)
Coming soon ->
Used to own -> iBasso T1 / Mylarone 3 / iPod Nano 8GB 2G / Ultimate Link Crescendo i / iRiver Clix2 / Cowon D2 / Livewires T1
  #162 (permalink)
Old 10-16-2008, 02:42 AM
JasonK's Avatar
Premier Sponsor
Sleek Audio
Default
As with any wireless system there will be a small amount of white noise if the volume is all the way down. This is similar to many amps I have tested including some very expensive tube amps and desktop amps that have tested.
The noise Ed was hearing was a high frequency whine. The same one that people with the iPhone 3g have complained about they can hear in their car with the wifi turned on. He was able to move the transmitter and change sources to get ride of this and that leads me to believe the transmitter is the issue.
The sound quality is no comparison to Bluetooth or other wireless systems. We have a 95dB dynamic range and full lossless sound processing, Bluetooth is a 75dB range the same is an FM radio.
I will be at the meet in Florida and plan on sending out units to some other head-fiers. I know that people will be pleased with what we have produced. After all, every Kleer product is interoperable and we all use the same transmitter system. The difference is the headphones and name on the outside.
To the new head-fier whose first post was a bad experiance, please PM me and I will be happy to call and discuss the issues you have had. I have a very open door and love having the chance to discuss our product with fellow audiophiles.
Jason
  #163 (permalink)
Old 10-16-2008, 05:51 AM
Sovkiller's Avatar
Member of the Trade:
Rudistor Sound Systems
US/Canada
Proved that despite its huge size, the CD3000 can be shoved down one's throat.
Default
Just send me one of the defective ones at least to have a flavor of what is going on....
__________________
I do love the Edition 9, and probably you know what that means, so you have been warned...!!!
Disclaimer: Please assume every single of my statements, to mean: “in my system”, “to my ears”, "in my experience", “in my opinion”, etc...(otherwise stated).
Neutrality, accuracy? OK, just ask yourself first: Do you certainly know how the recording is supposed to sound? Sorry, but for me euphony is all about!!! Please do yourself a favor, stop listening your gear, and enjoy the music instead!!!
Home setup: Sony DVP-NC555ES => BJC IC's => RPX-33 MKII/RPX-31 => UE9
"On the go" setup: Panasonic SL-CT570 => XJ-03 => Sleek SA6/Klipsch Images X5/X10
Proved that despite its huge size, the CD3K can be shoved down one's throat...wait...but now I'm shoving the Ultrasone Edition 9???
EQUIPO HEAD-FI HISPANO: DILE ADIOS A TUS AHORROS!!!
My feedbacks in: Head-Fi , eBay and Amazon
  #164 (permalink)
Old 10-16-2008, 11:13 PM
vulc4n's Avatar
500+ Head-Fi'er
Send a message via AIM to vulc4n
Default
Trying to imagine how the transmitter would be mounted on an iphone. Seems like it might make it a bit to tall to be easily pocketable. Anybody try it or have pictures?
__________________
Team College-Fi (Lehigh University)
Home: HK AVR 435 - 3x KRK ST6 Monitors
School: Black MacBook - M-Audio StudioPro 3's
Portable: 16GB Black iPhone - Phonak Audeo PFE [w/ Mic]
Sold/Retired Phones: Sleek SA6 - V.Moda Vibes - Etymotic ER-4P - UE Super.Fi 5 Pro - Sennheiser HD 280 Pro - Beyer DT 250-80 - Audio Technica ATH-ANC7 - Zune Premium Canalphones - JBL Reference 220 - Panasonic HJE50
  #165 (permalink)
Old 10-17-2008, 02:03 AM
Default
Received the wireless today. Yes, there is a small amount of white noise in silent passages. That issue aside, Zune + Sleek wireless + Sleek custom is an absolute winner. This combo kills!
Kudos to the Sleek team once again.
__________________
My Feedback - http://www.head-fi.org/forums/f12/eyeameye-56333/
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2 Head-Fi.org
