09-03-2008, 10:41 AM
100+ Head-Fi'er
Just got my SA6's today. Very nice!
I run mine through a Cowon D2 -> Xin Supermini-III
I think I will settle with:
Treble: +
Bass: + (with hole cleared with a pin)
All player settings on flat
Xin bassboost (7db) enabled.
Sounds very good to my ears listening to Rock and Metal.
I dunno that my Atrio M5's can survive this newcomer!
Paul
__________________
[size=2]
Current Gear:
[SIZE=1] HOME
Computer (FLAC) --> SqueezeBox2 --> DAC-AH CAA --> Meier Cantate --> Denon D2000
PORTABLE
iPod Classic 80GB -> LOD -> Xin SuperMini-III -> Sleek SA6
Australian Digital Photography (my website)
09-21-2008, 06:14 AM
Junior Head-Fi'er
I got my SA6s!!! Woo!!!
But my sound fingerprint is really weird and took a long time to find but I like it thus far. I have an iAudio X5 80GB, and I modded it with Rockbox. I swapped the bass and treble around over the last few days, and finally settled on the + bass (with the staple mod), and a + Treble, but I also set Treble to +5 db on Rockbox. I would use the ++ Treble, but it gives it this really airy sound which isn't very nice. But it sounds beautiful now!
09-22-2008, 11:39 PM
500+ Head-Fi'er
Originally Posted by Obstinate
...and finally settled on the + bass (with the staple mod), and a + Treble, but I also set Treble to +5 db on Rockbox. I would use the ++ Treble, but it gives it this really airy sound which isn't very nice. But it sounds beautiful now!
You bring forward a very interesting point about the SA6.
When I got my Triple.Fi, the SA6 sounded a lot darker. To have a brighter sound, I have to use the Treble Booster EQ on my iPod to bring the mid/high frequencies up. However, as I was using the ++ Treble Tips, the sound found itself slightly too much on the very high end part of the spectrum. No problem. Switched to the + Treble tip. Voilą, problem solved.
Because of this, I might eventually be ready to get rid of the Triple.Fis. The fit and comfort on the SA6 is second to none (compared to those IEMs I tried, and they DO stay in my ears!), the bass is really great and deep, especially with the bass + mod, and all I needed to bring the sound forward a bit is a touch of EQ and a tip change.
Something that I couldn't have been able to do with any other IEMs!
So huh... wireless coming soon?
__________________
Ears....: AKG K141s & K414p, ATH-ES7, BeyerDynamic DT770/80 Pro, Grado SR60, Monster Turbine, Sennheiser HD280 Pro & PX100, Sleek Audio SA6.
Amps..: HeadRoom Total AirHead, Ray Samuels Audio "The Predator".
Past....: ADDIEM, Grado SR325i, Jays Q-Jays, Klipsch Custom 3, UE Triple.Fi 10 Pro, Yuin PK1.
Portable Rig : iPod Touch 2nd Gen 32gb -> Modded ATH-ES7 - Monster Turbine.
09-24-2008, 05:20 AM
100+ Head-Fi'er
Treble++
Bass+ (modded)
Shure Olives
10-22-2008, 10:30 PM
Junior Head-Fi'er
just to clarify an earlier conversation in this topic. The sleek are similar to q-jays in that the filters need to be replaced often? I had though that the filters on these were mostly for "shaping" sound...
12-04-2008, 04:46 AM
100+ Head-Fi'er
using ipod touch 2 no EQ. currently using new bass + port and treble + port. wearing down. might experiment more between treble +, ++, and =, but the bass + is here to stay unless there is something that gives even more bass.
12-04-2008, 07:40 AM
Headphoneus Supremus: Niiice!
bass +
treble ++
waiting on new bassports to come, what is this bass mod?
__________________
MUSIC| Trance, Dance, Metal, Rock, Pop, Vocal, Classical
SOURCES| iPod Classic 160GB/iPhone3G 16B
EARS |Westone3/SA6/LiveWires
CAMERA| NikonD90
LENS| 17-55mm f2.8/70-200mm f2.8/VR - 18-200mm/50mm f/1.8
OTHER| SB900/2x SB800
Head-Fi Feedback
12-04-2008, 09:47 PM
100+ Head-Fi'er
Forget about the bass mod, just get the new bass ports. They sound better than the modded ones anyhow. The bass mod was just to poke a needle through the back of the bass+ port. Some heat it up so that the hole stays open, some just poke it through. It will close back up eventually though. Use a needle or staple. But like I said the new bass ports are good. The change isnt big either way though.
__________________
Gear I've actually Kept:
Cowon D2> Headphonia Penguin CMOY>Sure SE530
Cowon S9>Fiio E3 >Sleek SA6 w/Kleer Wireless
Sansa E260>Creative Labs EP-640
RS Raptor>HD650
Sold or given away list is way to long lol
12-06-2008, 05:15 AM
100+ Head-Fi'er
right now im testing it on treble tip = and new bass + port. it gives a very smooth and warm sound with excellent bass. only problem is that you lose a little clarity and detail. im really going back and forth on it with treble + and = port because + gives a more realistic and clear detailed sound while = gives a smooth luscious warm sound with some good bass.
12-16-2008, 02:51 AM
Junior Head-Fi'er
I just got the new bass ports in today, I am loving them so far. Gives them a little more punch. So far I am using the treble + tubes with them and I am liking the sound.
I'm having to use the Shure Olives (with the plastic inside cut for easier removal from treble tips) with mine now because the medium tips became too loose and now get stuck in my ears (checked with the smaller tips and they fit snug, ruled out the treble tips as the cause). Has this happend to anyone else? Kind of scary. I guess I need to order some more, I like the ease of placing them in my ears and removal is also easier than the olives.
02-01-2009, 02:42 PM
Just got mine a few days ago in wireless bundle. I am using the Bass + and the Treble = ports right now which I seem to be very satisfied with.
__________________
Headphones: Stax: SR-007 MkII, SR-003; Ultrasone: Edition 9 (2); AT:ESW10JPN; Sleek SA6 Wireless--- Home Amps: Stax: SRM-252a; Headamp: KGSS(bg) Yamamoto: HA-02--- Portable Amps: TTVJ: Portable Millet Hybrid;-----Sources: Lavry DA10 (2); Oppo 981HD; Squeezebox V3; iMod; Sansa Fuse; HeadAmp Pico-amp/dac&Pico DAC-----Feedback: http://www.head-fi.org/forums/f12/slwiser-129086/ <><
02-01-2009, 07:25 PM
Junior Head-Fi'er
wow some of you guys like a lot of treble, im using the new bass + port and treble = port, love the sound, fit is great using just the medium tips
__________________
Iphone 3G 16gb
Ipod Video 30gb
Sleek-Audio SA6
02-01-2009, 08:53 PM
100+ Head-Fi'er
My foorprint is currently size 11.
Anyway i went with bass+ treble+ on the customs as most seem to prefer this, you may get the odd one who likes the total opposite but i can always eq things a bit if needs must.
__________________
1st gen nano>cowon s9>sansa clip
Sf5 pro>sleek customs
02-02-2009, 12:02 AM
100+ Head-Fi'er
Anyway i went with bass+ treble+ on the customs as most seem to prefer this, you may get the od one who likes the total opposite but i can always eq things a bit if needs must.
Ive been seeing you post around about your customs, very exciting indeed. So did you actually get them yet. Las I read some ninja told you they were in route. What do you think? I dont like the fit of the SA6 all that much but I have the wireless and love their sound, I think the custom is also in my future. It will be a while, I have my Cowon S9 on the way already
__________________
RS Raptor>HD650
02-02-2009, 02:15 AM
100+ Head-Fi'er
On my SA6, I had Treble +, Bass =. The bass was sufficient enough, but I went and got Bass + on my Custom.
__________________
Head-Fi Feedback (13)
eBay Feedback (62)
Brown ahead for Bure. Bure going in.. he scores! Pavel Bure has won it for the Vancouver Canucks! It's a triple overtime hat-trick for Vancouver!
- Western Conference Quarter-Final Game 7, April 30, 1994
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
Powered by vBulletin® Version 3.8.4 Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
