You are in Sleek Audio's Premier Sponsor Forum at Head-Fi.org.
To get back to Head-Fi.org's Main Forums, click here.
Register FAQ Members List Calendar Mark Forums Read Today's Posts Search
Go Back   Head-Fi: Covering Headphones, Earphones and Portable Audio > Premier Sponsor Forums and Sponsor Forums > Sleek Audio Premier Sponsor Forum
Reply
LinkBack Thread Tools
  #16 (permalink)
Old 05-18-2009, 08:28 PM
100+ Head-Fi'er
Default
Originally Posted by Andrew C View Post
Jason and Mark are actually heading to China at the end of this week to visit our manufacturer and get it on the move. Which, unfortunately, is why we are going to be missing CanJam this year.
So that means the cables won't be available anytime soon. I guess that I won't be ordering any Sleeks for a quite a while.
  #17 (permalink)
Old 05-29-2009, 08:42 PM
s_nyc's Avatar
100+ Head-Fi'er
Location: Paradise City (where the grass is green and the girls are pretty)
Default
Hi Andrew,
Are you planning on offering multiple options to your customers (i.e. several types of cables, with different prices and quality)?
Thanks
S.
  #18 (permalink)
Old 06-03-2009, 08:26 PM
Bojamijams's Avatar
Default
Any ETA on new cables ?
__________________
My Feedback
---JH|13 Pro--- | ESW10JPN | Essence STX | Audioengine A5
\m./ d-_-b \.m/
  #19 (permalink)
Old 06-04-2009, 04:12 PM
Andrew C's Avatar
Head-Fi'er
Default
Next week we will be receiving the new cables. So we are anticipating sending them out the latter of next week.
Thank you all for your patience and understanding.
  #20 (permalink)
Old 06-04-2009, 05:51 PM
tintin47's Avatar
Default
how much will they retail for as a separate item? I think that I will probably want one.
__________________
ALAC --> Macbook --> Fubar II DAC --> AMB Labs Cavali-Kan Kumisa III DIY --> Grado RS-1
Do you have a contingency plan in the event of a zombie apocalypse?
  #21 (permalink)
Old 06-05-2009, 02:03 PM
Andrew C's Avatar
Head-Fi'er
Default
The cables will sell for the exact same price it currently is on our website
  #22 (permalink)
Old 06-05-2009, 02:30 PM
100+ Head-Fi'er
Default
What changes are made to the new cables?
  #23 (permalink)
Old 06-27-2009, 02:00 AM
100+ Head-Fi'er
Default
I just got my new cable and the main difference is they changed it from a 90 degree mini plug to a straight. Also the Y-split is now a black cylinder. I have one for sale and a pic if your interested check my sig
__________________
Feedback
  #24 (permalink)
Old 06-28-2009, 07:46 AM
Junior Head-Fi'er
Default
Has anyone had experience with the new cable? Would Andrew describe its difference with the old one, in terms of SQ, durability, etc?
  #25 (permalink)
Old 06-29-2009, 01:59 PM
rasmusf's Avatar
Junior Head-Fi'er
Default
I received my new sleek replacment cable this saturday.
It's a better quality, but I wouldn't call it sturdy. Very thin.
To my ears the sound has even improved a little.
I've already had to super glue the metal cover at the minijack connector since it came off when pulling at it. I don't know if it's me, but I've had many other headphones with no cable issues at all (like UM2s).
I would still like to call on Sleek Audio to make their connectors available to others to make hi-quality cables for us nerds.
  #26 (permalink)
Old 07-20-2009, 05:47 PM
Head-Fi'er
Default
I think that the new cable is from the manufacturer of the iphone cable, it is very thin and very flexible my experience with it, is that it collect less cable noise than the original cāble.
the iphone cable was asymmetric the reg cable is symmetric
Time will tell how reliable it is
I had many earphone with cable issue actually the n°1 reason to change earphone was that the cable broke, that's annoying on a 40$ and even more on a 400$ piece.
That said as far a I can tell westone makes the most reliable earphone
__________________
*First Authorized Sleek audio listening point in France*
  #27 (permalink)
Old 08-20-2009, 10:41 PM
Junior Head-Fi'er
Default
Seriously for me the main prob with the sleek cable (4 in one year) is that they all brake at the plug that connect to the earphone. Well they dont really brake they just stop transmitting sound (if you play at bit with the cable you can make them sound again for a short amount of time...). The last one did completely break tough on one ear , leaving the connection and the iem in my ear while i was only trying to remove it and the cable just fell, perfectly cut away from his connector... for precision i always pull them from as close as possible to the iem to dont put too much tension on the cable...
  #28 (permalink)
Old 08-21-2009, 07:36 PM
100+ Head-Fi'er
Default
Is this the new cable, old cable or both you have had problems with?
I definitely had breakage problems with the old cables, but not, so far, with the new one.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Sleek cables quality issues rasmusf Sleek Audio Premier Sponsor Forum 26 02-28-2009 05:39 PM
Sleek Customs Fit-Issues/Wearing berniebennybernard Portable Headphones, Earphones and In-Ear Monitors 4 01-13-2009 04:57 AM
Anyone else having durability issues with Sleek Audio SA6? Bull Moose Portable Headphones, Earphones and In-Ear Monitors 7 06-28-2008 09:22 PM
er4p quality issues? asap2006 Headphones (full-size) 7 12-08-2006 04:40 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2 Head-Fi.org
