You are in Sleek Audio's Premier Sponsor Forum at Head-Fi.org.
To get back to Head-Fi.org's Main Forums, click here.
Register FAQ Members List Calendar Mark Forums Read Today's Posts Search
Go Back   Head-Fi: Covering Headphones, Earphones and Portable Audio > Premier Sponsor Forums and Sponsor Forums > Sleek Audio Premier Sponsor Forum
Reply
LinkBack Thread Tools
  #16 (permalink)
Old 01-24-2009, 09:24 AM
Taikero's Avatar
500+ Head-Fi'er
Default
I commonly see Altoids cans used as IEM cases.
__________________
"What would the magical leopluriton do?"
Head-Fi Damage To Wallet: $1,866.63 since October 14, 2008
Equipment I Commonly Use Or Coming Soon
Headphones: {* Denon AH-D5000 [Amazing] *} {* ZAGG ZAGGphones [57mm driver] *}
IEMs: {* Shure SCL4 [White] *} {* Etymotic HF5 [Ruby] *} {* ZAGG Z.Buds [Red] *} {* Future Sonics Atrio M5 v2 [x2] *} {* Klipsch Image X10 *}
Listening Sources: {* Sandisk Sansa Fuze 8 GB [Silver] *} {* foobar2000/AIMP 2 ==> ASIO [Native or ASIO4All] ==> E-MU Systems 0404 USB 2.0 ==> Purity Audio K.I.C.A.S. ==> Headphones *}
DACs/Amps: {* Purity Audio K.I.C.A.S. [Worth every Canadian penny] *} {* E-MU Systems 0404 USB 2.0 *}
  #17 (permalink)
Old 03-24-2009, 02:46 AM
NightWoundsTime's Avatar
Headphoneus Supremus:
A nice hunk of young man
Send a message via AIM to NightWoundsTime
Default
Best case of the type that I ever saw was for some cheap earbuds. You mounted the buds in a similar molded plastic compartment, and then the whole top would spin and wind up the cord. Clean and simple cord management.
As for me, I've got the wireless unit and just use the bag that came with it.
  #18 (permalink)
Old 03-24-2009, 06:51 PM
pseudohippy's Avatar
100+ Head-Fi'er
Default
I know, I really like the sleeve that came with the wireless, it fits my Cowon S9 player perfectly. Cowon should sell the bag with its player lol.
__________________
Gear I've actually Kept:
Cowon D2> Headphonia Penguin CMOY>Sure SE530
Cowon S9>Fiio E3 >Sleek SA6 w/Kleer Wireless
Sansa E260>Creative Labs EP-640
RS Raptor>HD650
Sold or given away list is way to long lol
  #19 (permalink)
Old 05-11-2009, 05:38 AM
FLACvest's Avatar
100+ Head-Fi'er
Default I Use my Phonak Audeo case too!
Originally Posted by |Fred View Post
the best case I've seen so far is from phonak simple tiny nylon dual compartment pouch made in china.
One side is for my Audeo PFE, the side that says "Audeo" and the other is for Sleek Audio SA-6. It's really the best case, and these are two of the top sounding IEMs.
My 2 cents...
__________________
Best in Any Manner Of Things...
-FLACvest
* PMP's: iRiver iHP-120 20GB w/ optical out > COWON O2PMP BLACK 32GB
* Headphone Amplifiers: iBasso D10 Cobra > iBasso T4 > FiiO E5
* Headphones: Victor HP-FX500 > etymotic ER*4-P > Phonak Audeo PFE > Sleek Audio SA-6 > JVC HA-FX300R > Altec-Lansing MHP136 MUSX > V-MODA bass freq > Grado SR-60 > Head-Direct RE0 (on order)
My Feedback : http://www.head-fi.org/forums/f12/flacvest-434701/
  #20 (permalink)
Old 05-11-2009, 08:29 PM
Pinny's Avatar
100+ Head-Fi'er
Send a message via AIM to Pinny
Default
I agree the carrying case isn't great. Better than other IEM cases, but it takes to long to insert and remove headphones. The best carrying case imho was the crappy little plastic case that came with the sony ex 71's. It was a little 2inX1inX.5in plastic box. You just scrunched the headphones in and then pulled them out. Terribly inelegant, but functional.
__________________
Thanks and be well,
Pinny
My gear: Koss KSC-75, Shure E2C (eq settings: +4,-3,+1,+2,+3), Sleek SA6 with W-1 wireless adapter
Previously owned: Sony EX-71, Koss KSC-50, Sennheiser PX200, Sony V6, Philips HS900 (broke), Grado SR60 & SR80, Beyerdynamics DT770
My feedback: http://www6.head-fi.org/forums/showthread.php?t=58671
  #21 (permalink)
Old 07-07-2009, 02:59 PM
Head-Fi'er
Default
You know, large sized Rite Aid pill bottles work magnificently as carrying cases. Especially for the SA 6's; they fit perfectly.
It's also virtually indestructible under normal circumstances.
  #22 (permalink)
Old 07-08-2009, 09:18 AM
active's Avatar
Junior Head-Fi'er
Thumbs down Design Failure
Takes just a minute to figure out how useless is this make-up powder box. Looks cute at the first glance, but, as mentioned in previous posts, it is absolutely impractical for daily usage. Getting IEMs in and out takes too long and is an annoying process. Rubber molds are nice, but make the box heavy. IEMs don't fit in the mold when cable is turned upside down for over-ear wearing and/or when fitted with large tips.
A cheaper and very simple zip pouch would do a much-much better job.
Some manufacturers include spacious cases to fit a whole kit inside: IEMs, tips, filters, adapters, cleaning tool, e.t.c. You would not want to use such a case to carry around, but it is very conveniently store all necessery stuff in one box at home.
So who is the SA6 case targeted to? - A gadget fetishist, who stores IEMs in a visible place, takes them out once in a while to play around a little and compare to other IEMs/earhones/headphones he/she has in the collection, but almost (never) actually wears them.
How could Sleek Audio approve this design failure?
Luckily they carefully read our comments and note, what customers think. They'll do much better next time, that's for sure.
  #23 (permalink)
Old 07-08-2009, 10:15 AM
active's Avatar
Junior Head-Fi'er
Lightbulb Quick SA6 Case Mod
Real quick mod for those who agree with the issue of impracticality, but want to use it, and often.
The idea is to get rid of the inner compartment to make inserting/removing IEMs easier, have an extra room for a clip/adapter, make the case lighter.
1. On the pictures the case is opened, but you better close it. Then push the metal bar out with a screwdriver or any other blunt tool.
Careful, it can slip, don't injure yourself. When the end of the bar is sticking out far enough, pull it out using pliers.
2. Open the case, remove the middle compartment, put the transparent lid back on it's place, close the case. Push the metal bar back, where it originally was.
3. Done!
I still prefer a bit larger zip pouch from $1 store, but this way the SA6 case can be more useful.
SleekAudio, please please, make a clip for SA6 ;]
  #24 (permalink)
Old 09-15-2009, 04:24 PM
Pinny's Avatar
100+ Head-Fi'er
Default
That is a super idea. I'll do that when i get home. Then it will be attractive AND usefull!
__________________
Thanks and be well,
Pinny
  #25 (permalink)
Old 09-15-2009, 10:24 PM
1000+ Head-Fi'er
Default
The Shure case for the 530 is nice, but big for small IEM's only.
This is for Shure E2/E3, and is really nice:
Shure Round Earphone Carrying Case for E2C/E3C in Black HiFi Headphones
A cheaper version I found on eBay.
Same diameter, thicker/more space,not so rugged/hard, but cheaper:
Case for i-Pod shuffle 2G headphones in-ear earbuds - eBay (item 300330235267 end time Oct-12-09 02:09:45 PDT)
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Carrying case for HD650? dkpaul Cables, Power, Tweaks, Speakers, Accessories (DBT-Free Forum) 1 09-28-2007 07:17 AM
carrying case for KSC75? Cooter Headphones (full-size) 1 01-31-2007 08:46 PM
A strong carrying case Steve754 Portable Source Gear 8 10-08-2003 06:30 PM
Carrying Case? Paul_A Portable Source Gear 10 01-13-2002 05:32 AM
CD carrying case gusmahler Portable Source Gear 6 01-02-2002 05:34 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2 Head-Fi.org
