Support Head-Fi.org by
starting all of your
Amazon.com shopping by
clicking here.
____________________________________________________________________
Today's Featured Head-Fi Blog: A Japanese headfier's monologue (Sasaki)
Please help
support Head-Fi by becoming a Contributing Member
CLICK
HERE -- Contributing Members, thank you
for your generous support! --
Go to system>administration>system monitor and check your RAM usage under the resources tab. If you're running low, adding some RAM might help but in my experience Ubuntu should run just fine on 256MB, let alone 512. While you're there, check the processes tab and sort by CPU usage to see if anything's unnecessarily hogging your resources.
__________________
Team College-Fi!
Headphones: Ultrasone HFI-680, Sennheiser HD-595, Creative EP-630
Speakers: Energy C-100
Sources: Stello DA100, Zune 80
Amplification: McIntosh MAC 1500 tube receiver, Meier Audio HeadFive #150
Cables: BJC LC-1 | Power: Tripp Lite Isobar 6 DBS
Instruments: Cello, Electric Guitar System Specs | Feedback | Gone and missed: HD-280, iAudio X5L (30GB), Kramer modded Koss KSC-75
If the Swap line shows a lot used, then you're swapping. vmstat 5 5 will show you how your swapping, but it's kinda hard to read if you're not used to it.
Hi there. Such a slowdown is surprising, but RAM is no doubt your issue. For all unix based OSs ram is very important (max os x included), much more so than winblows because it puts everything it can into your ram. My advice is to buy good quality ram thats as fast as your system bus can allow and have at least a gig and probably get rid of your old stick/put it into a wintel box.
I was recently installing ubuntu on an old PC that ran windows fine to no avail because of buggy ram. This RAM thrashing is perhaps a design flaw in linux... But as you say RAM is cheap these days, and I'd rather spend my money on RAM than give it to the robot devil in exchange for an operating system built on untested code as a response to the media industries as opposed to open source tried and tested code.
Rant over.
