You are in Moon Audio's Premier Sponsor Forum at Head-Fi.org.
To get back to Head-Fi.org's Main Forums, click here.
Register FAQ Members List Calendar Mark Forums Read Today's Posts Search
Go Back   Head-Fi: Covering Headphones, Earphones and Portable Audio > Premier Sponsor Forums and Sponsor Forums > Moon Audio Premier Sponsor Forum
Moon Audio Premier Sponsor Forum Headphone cables, audio cables, DIY, headphones, headphone amps, electronics and speakers, and equipment racks.
Reply
LinkBack Thread Tools
  #16 (permalink)
Old 09-07-2008, 05:10 AM
grandenigma1's Avatar
Headphoneus Supremus:
Member of the Trade:
Enigma Audio
Send a message via AIM to grandenigma1
Default
You will have a hard time fitting anything much larger than 22awg.
__________________
Feedback:
Head-Fi
, eBay
  #17 (permalink)
Old 09-10-2008, 01:22 PM
n_maher's Avatar
Moderator
Resistorous Conflagorous
Default
Originally Posted by Edwood View Post
What's the largest diameter (gauge) of wires that can possibly fit these?
Just to add to what GE said, 22ga is about it and seems limited by the size of the stock strain relief. So if you had some heavier gauge wire that had a very thin coating you might get it to work, although why someone would use heavier than 22ga wire for a headphone cable is beyond me.
__________________
SB3/Arcam CD73 -> Hertsens Signature DAC -> Project Menace -> Woody HF-1 or HF-2
-Head-Fi Feedback-
d-_-b
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2 Head-Fi.org
