03-06-2009, 02:19 AM
Junior Head-Fi'er
DPS placement?
I just received my Ultra Desktop Amp and Desktop Power Supply today. So recently, in fact, that I have not yet tried it out! This is a huge upgrade for me, and I am not wanting to rush anything.
Does it matter whether I place the DPS on top of the amp, or the amp on top of the DPS? Or is this just a matter of personal preference? I looked online for photos and saw the amp sitting atop the DPS on two occasions, but also saw the reverse once as well.
03-06-2009, 02:26 AM
I would place the amp on top of the DPS.
__________________
"When stupidity is a sufficient explanation, there is no need to have recourse to any other."
F e e d b a c k
03-06-2009, 02:49 AM
100+ Head-Fi'er
DPS below for me. Allows the amp to dissipate heat better, makes it easier to access the back panel and looks nicer as well IMO.
And yes, the DPS does make a difference to me  .
Here are some of my thoughts on the Balanced Desktop with PSU: A new addition to the family: Headroom Balanced Desktop - SGHeadphones
03-15-2009, 03:53 AM
Junior Head-Fi'er
I now have the amp on top of the DPS. It does make the amp easier to access in the back, but it is slightly harder to turn off the DPS. I have to reach up and over the stack to find the power switch. But even though I use the DPS power switch more often than I find the need to mess with the rear inputs/outputs of the amp, I still prefer this setup. It looks better, and the amp does run hotter than the DPS (although the heat doesn't seem like it will ever be a problem regardless).
Thanks for the input.
03-16-2009, 06:09 AM
Junior Head-Fi'er
Another DPS question.
When I turn the unit off, the green light stays on for a while before dimming and then finally going out. Is this normal? I want to make sure just in case this might be a reflection of something going wrong with an internal component.
edit: it takes around 30 seconds for the light to fade out entirely.
Reason: more info
03-16-2009, 11:00 AM
It's known as a large power supply capacitor and you wouldn't want to be doing without it...
03-16-2009, 09:26 PM
Junior Head-Fi'er
Sorry, I don't think I was clear enough in my previous post.
When I'm done using my desktop amp, I turn it off. Then I turn off my DPS. But after I turn the DPS off, the light stays on a lot longer (~30 secs) than I am used to seeing in electronic equipment.
I am just wanting to make sure this is not a sign of a problem. If this happens to other owners of the power supply then I am not worried., but if it particular to my unit only, then I need to take action.
03-16-2009, 09:34 PM
100+ Head-Fi'er
I also have the DPS and the led stays on for a while too after turning of the DPS.
The large power supply capacitor(s) slowly unload, nothing to worry about.
03-16-2009, 09:43 PM
Same thing happened with mine.
__________________
F e e d b a c k
03-16-2009, 11:13 PM
Garmentus Vulgaris & Headphoneus Supremus Premier Sponsor HeadRoom
Yupper! That's correct. Nothing to worry about.
__________________
Cheers!
Tyll (Like on the floor, only spelled different.)
I just blogged all over my keyboard.
03-17-2009, 03:28 AM
Junior Head-Fi'er
Great! I figured it was better to be safe than sorry.
Thanks for allaying my concern.
03-22-2009, 07:39 PM
Junior Head-Fi'er
Well, I have the DPS below the UDA because in fact the UDA runs heater than the Power Supply and this way I get better heat dissipation
Now my own question
Anyone knows if it is necessary to turn off both modules when you go to bed? or in fact doing so we are shorting the DPS and UDA useful life ??
Anyone knows?
__________________
...... Phones protect my music from neighbors late at night
Phones: AKG K702, AKG K701, Senn 600, Senn 580, expecting Senn 800
Sources: dCS P8i CD-SACD player and PC (Soundblaster XFi), via Toshlink to MaxDAC
Amp(s): HeadRoom Ultra Desktop with MaxDac, Rega Ear, Creek OBH-11
03-22-2009, 09:50 PM
Anyone knows? .gif)
It's prolly technically better to turn off the amp first, and then the PS.
Most likely damage during power down is one (either the positive or negative) power supply shuts down before the other. Because the amps are DC coupled, when one rail shuts down before the other it's possible to get some fairly big DC offsets at the output that might push DC through the headphones and damage them.
If you power down the headphone amp first, its smaller capacity power filtration sections deplete faster than if you were to turn off the power from the desktop power supply.
Me? I just turn off the power supplies. But I'm supposed to stress test stuff.
__________________
Cheers!
03-22-2009, 11:49 PM
Junior Head-Fi'er
OK Tyll ..... so you mean:
"Do what I say and not what I do ...... "
But... the other side of the question is:
I should leave the DPS and the Ultra Desktop always ON or ... we must turn them off when we go to bed... what you think ..... or ... better...what you do?
Wait for your ilumination....
__________________
03-23-2009, 01:01 AM
Humble opinion is about all you're going to get from this one of what everybody's got:
Don't leave them on, it's a waste of juice.
They sound fine from the moment you turn them on.
__________________
Cheers!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
Powered by vBulletin® Version 3.8.4 Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
