You are in HeadRoom's Premier Sponsor Forum at Head-Fi.org.
To get back to Head-Fi.org's Main Forums, click here.
Register FAQ Members List Calendar Mark Forums Read Today's Posts Search
Go Back   Head-Fi: Covering Headphones, Earphones and Portable Audio > Premier Sponsor Forums and Sponsor Forums > HeadRoom Premier Sponsor Forum
Reply
LinkBack Thread Tools
  #16 (permalink)
Old 08-09-2008, 09:45 AM
lisnalee's Avatar
Default
I've just bought the DPS for my desktop balanced amp. When i switch it on i can hear a slight hum coming from it, is that normal?
My last amp was a gilmore lite with Dps and it was totally silent, which is making me think there might be a problem with it.
__________________
Home Rig:. Sony SACD •♫• Technics SU-V303 •♫• AKG K1000
Portable Rig:.Sony X1050 •♫• Livewires SPC recable / Ms1000i
Feedback: Head-Fi..ebay
  #17 (permalink)
Old 08-09-2008, 10:51 AM
The Monkey's Avatar
Default
Did you try setting the ground lift to "float"?
__________________
"When stupidity is a sufficient explanation, there is no need to have recourse to any other."
F e e d b a c k
  #18 (permalink)
Old 08-09-2008, 12:56 PM
Quaddy's Avatar
Default
my DPS was ordered in the same order as lisnalees, and he sent it onto me, if anything i would have thought i would have had a 'hum', as my old electrics here produce an AC hum through my logitech subwoofer.
but in testing, putting my ear really near the dps, with all other electrical noise closed down from other sources, i can confirm it is deadly silent, i think lisnalee may be talking about a hum coming from the DPS externally, not whilst using headphones?!? - otherise, as you said, the float option would be of help as lisnalee is well aware of.
lets hope its able to be sorted and interesting to hear what HR have to say.
lisnalee, can you confirm if its external hum?, ie. you can hear a hum without headphones on, emanating from the DPS - or is it the introduction of the DPS into the balanced amp that is making hum through the headphones?
__________________
DAC1 Pre & Sen HD800 or RWA TEAC AL700P & AKG K1000
Head Direct HiFiMAN HM-801|PCM1704UK |& Sony PFR-V1
Portable rig... ;-)
Grand PianoReed & Pipe OrganGlockenspielBass Guitar
Double Speed GuitarTwo Slightly Distorted GuitarsMandolin
Spanish Guitar & Introducing Acoustic GuitarPlus...Tubular Bells
Quaddy is a sax addict and a midnight caller fanboi & jack killian wannabe, "Good night America… wherever you are."
  #19 (permalink)
Old 08-09-2008, 01:31 PM
lisnalee's Avatar
Default
Thanks Quaddy for your input .
I probably should have explained the problem in better detail, i was just up and hadn't had the morning wake up coffee, but yes the hum is coming from the unit itself.
I cant hear it while listening with headphones which i guess is a good thing. I did try the float option which made no difference but from what i gather from the manual it would only help it if i was hearing though the headphones.
But i'd just feel better if someone else's sounded the same.
__________________
  #20 (permalink)
Old 08-09-2008, 07:31 PM
The Monkey's Avatar
Default
Got it now, I misunderstood the first time, sorry. I do not recall hearing any noise at all coming from my DPS.
__________________
F e e d b a c k
  #21 (permalink)
Old 08-09-2008, 07:57 PM
lisnalee's Avatar
Default
I think i'll email HR on Monday to see what they reckon, just to be on the safe side.
The humming is'nt that loud, but if no one else is doing it then perhaps there's a fault with mine.
__________________
  #22 (permalink)
Old 08-09-2008, 08:06 PM
Quaddy's Avatar
Default
definitely, i would be doing the same! i just feel a bit guilty that mine is seemingly ok, and you unbeknownst to you, were keeping the 'hummer' and sending me the clear one.
at least its not your amp that maybe would have to go back!
if your dps needs to go back and you have sold your astrodyne by then, you can borrow my astrodyne to tide you over, just let me know.
man i need a different surface space now with all this big old desktop rig
__________________
Portable rig... ;-)
  #23 (permalink)
Old 08-09-2008, 09:24 PM
lisnalee's Avatar
Default
Thanks Buddy
It's at times like this, with the generosity of others that make me really appreciate being a part of Head-Fi.
__________________
  #24 (permalink)
Old 08-10-2008, 07:50 AM
The Monkey's Avatar
Default
Just to add a little bit: this is why you buy from HR. They take pride in their equipment and will figure out the problem.
__________________
F e e d b a c k
  #25 (permalink)
Old 08-10-2008, 01:15 PM
PFKMan23's Avatar
Default
It might just be straight off transformer hum. Not a groundloop or anything quasi complicated.
__________________
Parasound D/AC 1600HD --> --> Audio Technica ATH-AD2000/Sennheiser HD580(EA Senn cable/Oracle)
My various Headfi heroes:
sacd lover, Grandenigma1, Voltron, tkam, EdipisReks, grawk, neilvg, Ripley, Filburt....
WTB/WTT (for): Headamp GSX
My Feedback
  #26 (permalink)
Old 08-12-2008, 09:37 PM
JorgeC's Avatar
Premier Sponsor
HeadRoom
Default
I think i'll email HR on Monday to see what they reckon, just to be on the safe side.The humming is'nt that loud, but if no one else is doing it then perhaps there's a fault with mine.
Howdy Lisnalee,
Hopefully, Service Manager MikeO. (BigWurm) in HeadRoom repair has given you the low-down on our next move... Rest assured if anything's wrong, we'll promptly get that DPS back to perfect silent operation asap!
Cheers,
Jorge
HR Sales/Product Manager
  #27 (permalink)
Old 08-13-2008, 03:12 PM
lisnalee's Avatar
Default
Originally Posted by JorgeC View Post
Howdy Lisnalee,
Cheers,
Jorge
Hi Jorge.
Yeah, ive been speaking to Mike and he has offered to take a look at it if I send it over.
Thanks for the great customer service.
Damian
__________________
  #28 (permalink)
Old 08-16-2008, 04:12 AM
kboe's Avatar
100+ Head-Fi'er
Default
Hey I had a question about using the Desktop Power Supply for the Micro Amp and DAC. I read in a review that Headroom dose not recommend placing the micros on top of the Power Supply. Is this true and if so why?
  #29 (permalink)
Old 08-16-2008, 05:05 AM
JorgeC's Avatar
Premier Sponsor
HeadRoom
Default
Hello Kboe,
Hmmm, not sure why that would be -- other than maybe the Micros are smaller-sized units & may perhaps slide off the larger rounded DPS chassis if not secured (?) ... Certainly, there's no heat build-up, vibration, or other issues since the DPS is designed to have our 'fully-loaded' Desktop Amp or Balanced Desktop stacked above it!
Cheers,
Jorge
  #30 (permalink)
Old 09-04-2008, 01:31 PM
nkoulban's Avatar
100+ Head-Fi'er
Default
I also have the DPS with the HRB amp and dac with Steffan Audio cables and a HD650. I feed it from a macbook pro via the optical out... sonic bliss!
__________________
*** It's Only Music ***
Home Digital Rig: MacBook Pro->iTunes->Optical Out->Stello DA100S->Headroom Balanced->Balanced Modded HD650->Equinox Balanced Cables
Home Analogue Rig: Technics SL1210M5G KAB Mods->Denon DL103R->Cinemag SUT->Project PhonoBox II SE->Headroom Balanced->Balanced Modded HD650->Equinox Balanced Cables
Portable Rig: iPhone 3G 16S ->Westone 3 or iPhone 3G 16S ->LOD->Minibox E+->Westone UM3X
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2 Head-Fi.org
