You are in HeadRoom's Premier Sponsor Forum at Head-Fi.org.
To get back to Head-Fi.org's Main Forums, click here.
Register FAQ Members List Calendar Mark Forums Read Today's Posts Search
Go Back   Head-Fi: Covering Headphones, Earphones and Portable Audio > Premier Sponsor Forums and Sponsor Forums > HeadRoom Premier Sponsor Forum
Reply
LinkBack Thread Tools
  #91 (permalink)
Old 08-18-2007, 10:05 PM
lextek's Avatar
Default
Headroom has some real, interesting goodies. I have the the Micro w/DAC on preorder. I'm wondering how much I would be giving up to the Desktop Portable w/DAC.
__________________
As long as it sounds good. That's what matters!
  #92 (permalink)
Old 08-19-2007, 01:44 AM
mrarroyo's Avatar
Default
As I understand it the 2007 Micro Amp/Dac portable is the equivalent (sound quality wise) of the current desktop module and micro dac. Did I understand it correctly?
__________________
Miguel
Feedback at: http://www.head-fi.org/forums/f12/mrarroyo-139426/
  #93 (permalink)
Old 08-19-2007, 11:07 AM
Default
Yes and no.
The desktop module was a design based around the OPA2134 for all active stages, feeding a Diamond Buffer output stage. The 2134's weren't biased toward class A, however there was a small amount of bias in the buffer. It was originally designed to run off a +/- 15V power supply, however can function well down to about +/- 7V I believe.
The 2007 Micro Amp design uses the AD8397 as gain and output stage (I'm not sure what handles the crossfeed...). There is no diamond buffer as the output current potential of the 8397 is sufficient to drive headphones directly. The 8397 does have class A bias applied to it, to improve sound quality. It is designed to run off the dual cell LiIon battery, which provides +/-3.7V.
I can't comment on the sound of the new Micro, as I haven't heard it, so am only commenting on some technical implications here. I would expect that the 8397 design would be almost as good as, but possibly slightly different from the Desktop Module.
__________________
HeadRoom Module Archive Thread: http://www.head-fi.org/forums/f5/hea...8/index11.html
  #94 (permalink)
Old 08-19-2007, 11:11 AM
Default
A fair bit in the amplifier electronics (much less in the DAC), but then look at the price and size/weight difference. The Desktop Portable is a sort of ultimate transportable - for people who want the absolute best on the the move and are prepared to sacrifice some convenience to get it.
__________________
  #95 (permalink)
Old 08-22-2007, 10:32 PM
n4k33n's Avatar
100+ Head-Fi'er
Default
Are there any new improvements in the 2007 microdac over the older one? (besides placement of plugs and switches)
  #96 (permalink)
Old 08-23-2007, 02:58 PM
elnero's Avatar
Default
One thing I would love to see on the new Portable Micro Amp is a line input on the rear of the unit in addition to the one on the front.
  #97 (permalink)
Old 08-28-2007, 09:33 PM
Head-Fi'er
Default
The new micro line does look awesome.
__________________
"A person is smart. People are dumb, panicky, dangerous animals and you know it."
  #98 (permalink)
Old 09-03-2007, 06:06 AM
Torula Yeast's Avatar
100+ Head-Fi'er
Default
Regarding The Sloth's and Ty's suggestion that if I upgrade in the Micro line, I should leapfrog past the Micro Home and go straight for Micro Max: Recently I read in the amps forum that the benefits of the Max, if I'm understanding correctly, are in conjunction with its use with a DAC. Since I'm running analogue, what might that do for the likelihood that I'd notice any sort of difference with the Micro Max vs. my '06 Micro?
__________________
Cheers,
Robin Michael
iPod 5.5g 80 gig w/256k tracks > HeadRoom Micro with Desktop upgrade > Grado GS-1000s > A nice chianti
LISTEN SAFE. LISTEN LOW, er, low!
  #99 (permalink)
Old 09-03-2007, 02:59 PM
Chri5peed's Avatar
Default
Originally Posted by PITTM View Post
To be honest, I have always wished that my MicroDAC wasnt portable. Dont get me wrong, I love the thing and its awesome, but I think it would have been a better product if it had full sized rca jacks and used the battery storage part of the chassis to either put a power supply inside or beef up other parts. I havent used it portably a single time since ive gotten it.
Neither have I. Could've been an option? Or maybe rechargeable.
__________________
Sources:foobar w/FLAC[Vista64/WASAPI] > Juli@ > Optical > Headroom MicroDAC/Headroom MicroAmp
Portable Sources:32GB Cowon S9, 16GB Cowon D2+ w/32GB Verbatim Class 6 SDHC
Headphones:Sennheiser HD 650[Cardas],
Sennheiser HD 595/50Ω, Audio-Technica ATH-ESW9, Audio-Technica ATH-A900, Koss KSC-75
Last.fm
I'm disabled, so expect a few typos.
  #100 (permalink)
Old 09-13-2007, 02:00 AM
100+ Head-Fi'er
Default
*le bump*
__________________
Cheers,
Robin Michael
  #101 (permalink)
Old 09-13-2007, 04:36 AM
kamcma's Avatar
Head-Fi'er
Default
"when the Brick is plugged in and charging the Lithium Ion Battery does it run off the Battery Supply or the Brick when in use?"
Sorry, this question was asked back on the first page, and I read through and didn't quite see an answer. (It totally may have been in there, and I just didn't see/understand it.)
Can the Portable Micro Amp w/DAC be used in a plugged-in state? I personally don't care about portability and battery life, I plan to only be using this next to a computer (since that will be my source, not any portable music player).
  #102 (permalink)
Old 09-13-2007, 12:08 PM
Default
I hear an Ultra Micro calling my name....
__________________
An ex-pro rock guitarist, so I know what live music REALLY sounds like!
  #103 (permalink)
Old 09-13-2007, 11:08 PM
Default
Yes it can. It will still be running the electronics off the batteries however, so SQ is unaffected (that's a good thing...).
__________________
  #104 (permalink)
Old 09-14-2007, 05:58 AM
100+ Head-Fi'er
Default
Does anyone know how much the astrodyne power supply improves sound quality?
  #105 (permalink)
Old 09-14-2007, 03:21 PM
Default
Not a great deal if your current PSU has enough 'juice', which it almost certainly does.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2 Head-Fi.org
