You are in ALO Audio's Premier Sponsor Forum at Head-Fi.org.
To get back to Head-Fi.org's Main Forums, click here.
Register FAQ Members List Calendar Mark Forums Read Today's Posts Search
Go Back   Head-Fi: Covering Headphones, Earphones and Portable Audio > Premier Sponsor Forums and Sponsor Forums > ALO Audio Premier Sponsor Forum
Reply
Thread Tools Display Modes
Old 09-25-2007, 01:44 PM   #201 (permalink)
100+ Head-Fi'er
ricthaman's Avatar
Profile
IM Contacts
Send a message via MSN to ricthaman
Default
well, I wanna buy an ipod touch as soon as it gets here but I'm a bit confused now about the SQ.
So I went to the local apple store with my brand new Futuresonics FS1's and plugged them into the new 6G ipod classic. There was some dance music on it like Earth wind and fire - boogie wonderland and some of that stuff.
I must say it sounded pretty good to me. I don't know if it's the earpieces that did it but it didn't annoy me. It shure could be better but it was fine to my ears. Good highs, bit recessed mids (the way I like it) and a good present bass. The bas wasn't very well defined or deep but average.
The one thing that I did notice is that the UI is a complete disaster. It was like it just didn't respond. For example: when playing a song, I pressed menu to go back to the menu but it just didn't do anything for at least 3-4 seconds. I mean, that's certainly no apple style. I'm working on a macbook now an it's one hell of a sweet machine and I just couldn't belive they come from the same manufacturer. The ipods UI was just very slow. It looked nice and coverflow was pretty nice but it was just a damn slow thing to handle.
I'll still be waiting for the ipod touch then....... Hope it's coming soon
greetz
__________________
Main rig: iPhone > Qables LOD > Meier audio 2Move > Ultimate Ears Triple.Fi 10
''The good that men do is oft interred with their bones, but the evil that men do lives on and on.'' - Bruce Dickinson
ricthaman is online now
Old 09-25-2007, 02:52 PM   #202 (permalink)
100+ Head-Fi'er
nytryder7's Avatar
Profile
Default
greetz
Did they have more than one unit on display that you could try? My 80g classic is very responsive. From startup to transition between screens, it shows no lag whatsoever.
__________________
My Feedback
nytryder7 is offline
Old 09-25-2007, 04:02 PM   #203 (permalink)
HeadphoneAddict's Avatar
Profile
IM Contacts
Send a message via ICQ to HeadphoneAddict Send a message via AIM to HeadphoneAddict Send a message via MSN to HeadphoneAddict Send a message via Yahoo to HeadphoneAddict
Default
greetz
There is an update that fixes slowdowns in the UI, likely not applied to the display model. My next post (typing now) will expound on the sound.
__________________
Originally Posted by Sovkiller View Post
There is no doubt that getting older is mandatory, but to mature remains still optional...
Larry Head-Fi Feedback
MAIN RIG: Marantz CD5001 > Synergistic Research Coax > Apogee mini-DAC with Sigma 11 PSU > ALO SXC XLR IC's > Single Power Square Wave XL balanced amp > HD600 with APS V3 balanced cable >>> ALO SXC mini-RCA IC > Woo GES > Sennheiser HE60 >>> or to Woo Audio Maxxed WA6 w/Sophia Princess rectifier/RCA 6DE7 > Grado RS-1 with APS V3 cable.
BEDSIDE RIG: Sony D-303 or iRiver H140 > Sysconcept.ca optical > HeadRoom Micro DAC > barqy silver plated copper mini-RCA > Travagans Red and Black > Edition 9 with APS V3 cable.
BASEMENT RIG: iBook > USB PICO > Dark Voice 336i "RCA5692/TS5998" > Denon D2000 APS V2 cable.
PORTABLE RIG: iMod 80gb 5.5G > barqy silver in silk LOD > ALO portable V-Cap dock > ALO Cryo Silver X mini-mini > RSA Predator > Livewires T1.
LAPTOP RIG: MacBook > USB iBasso D2 > RS-1 or Edition 9 with APS V3 cable.
FS: Stax SRM-1 Mk2 Pro
HeadphoneAddict is offline
Old 09-25-2007, 05:36 PM   #204 (permalink)
Profile
IM Contacts
Default
greetz
iTouch vs 5.5G ipod, no mod - this is not a lossless vs 320kbps VBR mp3 discussion.
I find the sound is pleasing through the headphone jack, but just like the 5.5G 80gb, it loses if you compare it to an iRiver optical out into an iBasso D1 DAC/AMP with the same 320kbps VBR files. Sorry, but I am hard pressed to hear the difference between lossless and 320kbps files on the same DAP. To me the point of the DAP is to carry many albums more easily than a few CD's. Yes, when I want the most accurate I pull out the CD player, and I can hear an improvement with concentrated listening, but 320kbps VBR are sooo close that for all intents and purposes I don't need lossless on my DAP to enjoy the music.
HEADPHONE JACK: VOLUME: Right now my iTouch is driving my HD600's at 100% volume with no distortion to a normal listening level, but to play loud with HD600's it needs an amp. It does drive my HD600's slightly louder than my 5.5G 80gb does. My 2G ipod nano would distort trying to drive these headphones to normal listening levels, at least the last time I checked. The touch will likely drive Shure E500's to damaging levels.
SOUND STAGE: with live recordings is a little bit compressed vs 5.5G (while the iRiver H140 improves on both). The touch's stage is more immediate and forward, having some of the spacial cues I hear with other sources, but everything seems closer, like being on stage and sitting at the piano instead of in the 1st row. ONE KEY ISSUE with the touch, I can't place the string bass in Jazz at the Pawnshop - it should be clearly to the rear left stage as with the 5.5G ipod, but I can't clearly put it on the stage when listening the touch.
SOUND and BALANCE: The touch is quick and punchy, and it is brighter and more detailed than my 5.5G 80gb. It sounds very different with AB comparison to my 80gb via headphone jack. The 5.5G 80gb has less treble, a hump in the upper mids, but a wider sound stage. Listening to the 5.5G you don't say, "hmmm this has a upper mid humps and rolled off highs", till you compare it to something else like the touch.
Via headphone jack, the iTouch may be more suited to Rock, Electronic, and other non-live music.
SWITCHING TO LOD to iBasso D1: SOUND STAGE opens up on both, but the iTouch does improve a lot more than it should. I think I like the touch better than the 5.5G 80gb with same dock, amp and program material I wasn't expecting that. Shouldn't it be closer my friend's 6G classic that I tested before?
So, I moved on to listen to the Tord Gustavsen Trio in stead of Jazz at the Pawn Shop. Same thing, I like the touch better via LOD than the 5.5G via LOD. I can clearly place the string bass where it belongs now,
SOUND BALANCE makes up for a still slightly narrower sound stage now, since the stage has at least improved vs headphone jack. Everything seems more detailed (tactile) and brighter - Cymbals and snares don't sound as dull. Bass is quicker.
iTouch wont replace my iRiver optical or especially a CD player optical to iBasso's DAC, but it does give my 5.5G a run for the money via headphone jack, and beats it via LOD till I get it iModded.
__________________
Old 09-25-2007, 10:41 PM   #205 (permalink)
IPodPJ's Avatar
Profile
IM Contacts
Send a message via Yahoo to IPodPJ
Default
Originally Posted by mirumu View Post
Vinnie already commented on that idea. There's already a company doing that and look what they charge.
http://www.head-fi.org/forums/3257698-post52.html
No, I was saying put a mini optical TOSlink line-out in the iPod itself, not in a dock. Where to put it? Do what Apple does in all of their computers -- make the audio line out/headphone port a combo analog/optical port.
__________________
____________________________________________
Headphones Denon AH-D5000 (modded)
Amp/DAC Meier Audio Corda Opera :::
Transport ESI Juli@ ::: Vista → Foobar 0.9.5 → EAC extracted PCM → ASIO 2.0 → SSRC@96/Ultra → ESI Juli@ → S/PDIF :::
Power Virtual Dynamics Master LE 2.0 Power Cord (Amp/DAC) ::: Cobalt Cable Ultimate Power Cord (PC) ::: API PowerWedge I
Interconnects Virtual Dynamics Master LE 2.0 Digital IC ::: Cobalt Cable Ultimate Digital Coax
:::::::::::::::::: Cobalt Cable Ultimate Audio Interconnect Pair ::: ALO 6" iPod LOD ::: Qables 15" Silvercab iPod LOD
Portable Source iPod Classic (6g) 80gig, with Agent18 Hardshell Acrylic Case:::
Accessories Audio Technica AT-HPS500 Headphone Stand ::: Woo Audio Silver Headphone Stand
IPodPJ is offline
Old 09-26-2007, 12:37 AM   #206 (permalink)
Profile
IM Contacts
Default
Stereophile or Audiophile magazine reviewed one (MSB iLink http://www.msbtech.com/products/iLink.php ) and felt it was as good as ANY digital source with lossless material, even vs the original CD.
I was all ready to want one till I saw the price
__________________
Old 09-26-2007, 12:43 AM   #207 (permalink)
1000+ Head-Fi'er
Profile
Default
HeadphoneAddict,
I totally agree with your assessment of the Touch SQ! A few here have been giving it a bad rap, but I don't agree with them at all.
__________________
HOME/PORTABLE SOURCE: Apple 16Gb iPhone, IPod Video 30Gb
CABLES: My own custom built Cardas LOD for iPhone
AMP: Qables iQube
IEM: Ultimate Ears UE-11's
flashbak is offline
Old 09-26-2007, 03:51 AM   #208 (permalink)
Profile
IM Contacts
Default
Originally Posted by flashbak View Post
HeadphoneAddict,
I actually haven't read any comments about the Touch yet - I'll have to drop by the Source forums and take a look. It's good to have some confirmation that what I am hearing isn't just me, but that others can hear the same thing.
I have plenty of DAP's. But, I bought the touch for the web-browser and wide screen multi-media capabilities so that I can sell my Nokia 770 internet tablet. The missing mail app on the Touch isn't a big issue because all my pop mail can be accessed via a web interface.
The additional feature of Wi-Fi iTunes store was nice - I downloaded a KT Tunstall album in 256K AAC non-DRM right from my bed last night, and could listen to it right away without trudging to the family room to sync with the iMac.
__________________
Old 09-26-2007, 03:53 AM   #209 (permalink)
1000+ Head-Fi'er
Profile
Default
I know....It is a really neat device!
__________________
AMP: Qables iQube
flashbak is offline
Old 09-26-2007, 08:27 PM   #210 (permalink)
1000+ Head-Fi'er
spraggih's Avatar
Profile
Default
I find the sound is pleasing through the headphone jack, ...
HEADPHONE JACK: VOLUME: Right now my iTouch ...
SOUND STAGE: with live recordings is a little bit compressed vs 5.5G ...
SOUND and BALANCE: The touch is quick and punchy, and it is brighter and more detailed than my 5.5G 80gb...
Thanks for taking the time to document your findings on the iTouch sound.
__________________
empirical FREEWAY | chord DAC64 | rudistor RPX-33 | apple: TOUCH iPod 5
audio technica W11JPN | UE11 Pros | sony: "Eggos" IR DS4000
ONCE OWNED
akg: 26P K701 | sony: CD3000 (already miss them) SA3000 | sennheiser HD555 | grado: SR60 SR80 SR225 | klipsch IMAGE, Custom-3
bel canto DAC3 (nice!) | lavry DA-10 | headroom MICRO-DAC | musical fidelity: X-DAC v3 X-10 TUBE BUFFER | stello DA220
larocco PRII (wish I still had it) | corda ARIA | norm GO-VIBE v4 | headamp PICO
My Feedback
I feel blessed knowing how many things have gone right knowing how many things could have gone wrong.
spraggih is offline
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Forum Jump
