There is NO DOUBT you should not use the VCap dock with anything other than a 5.5g iMod. First, only a 5th gen iPod will fit, so no 4G ipod need apply. But more critically, there are huge caps in the signal path! These are needed for the 5.5G iMod, but would totally mess up the sound for anything else. If you really wanted to use this dock just for the looks (and it is beautiful, no doubt), you'd need to see if Ken would custom make you one without the VCaps themselves.
x3 or is it 4 on the hammond enclosure. Although getting wood would be great and does look so gooood, the metal dock would be more durable and probably would cost less. I have been mulling over the Imod for some time and the V Dock was the news that I was looking forward to...so far the quality of the sound is getting an excellent review from skylab. The Woody tho really does get the total price up there...although I have been looking at used $1200 and under CDPs...
-- The Vcap Dock was only designed for the 5G/5.5G iMods. Sure, you can use a stock 5G/5.5G iPod, but you will not get any benefit from it.
-- 4G iMods are a definite NO because the line-out of the modded 4G units exits from the 1/8" stereo jack on the top (formerally the headphone output) and the line-out from the dock connector is disabled.
-- Ken mentioned to me that he is working on a metal v-cap dock which will be more suitable for portable use (smaller) and less expensive.
I'm sure Ken will add more info to this thread when he gets a chance.
Best regards,
Vinnie
PS: My V-cap Dock has been accumulating the hours of burn-in and sounds even better! It really takes the sound quality of the 5G/5.5G iMod to the max. I know Ryan Clarin of 6moons.com is reviewing one and that review will be out later this month. I hope he puts it up against a much more expensive dedicated CD player because I know the iMod + Vcap Dock will hold its own just fine
__________________
_____________________________________________ "Remember - Audiophile friends don't let audiophile friends listen to MP3s... Only use Lossless or WAV files!" :-)
