Dear, KB and Vinnie. I tried both trick and found the best ones. It's not neccessary to concern about my opinions but I just want to share good things I found. If you think that's the best of yours, keep it.
But for me, no matter how hard you try with battery powered output, it will NEVER beat any so called $1500 digital CD player, none of them.
Sorry you are not more open minded!
__________________ Main Source: Apple TV (160gb) Main DAC: Musical Fidelity TRIVISTA 21 Main Amp: Ray Samuels Raptor (Silver#001) Main Cans: Beyer DT990 (600ohms) Tubes: (Vintage 1965 12AU7 Amperex, Vintage Tung-Sol) Power Cables:(ALO Audio) Interconnects:(Madrigal CZ Gels)
I just want to contribue giving good things for the community to people who can do it. We even tried jensen caps ($50 per unit) or bigger black gate caps but it doesn't seem to perform as expected. But when I change the plan to make pre+buffer for improving signal, it sounds a lot better and not only for iMod but also laptop lineout too.
If you think that just caps alone can turn iPod to miracle 1k CDP, you are so wrong and I really can't admit that.
P.S. It seems vcap dock uses some sort of pcb with pre+buffer but I thought it was mini output jack. Sorry for arising this misunderstanding. Anyway, you should use stand IEC for power cord tweaks.
__________________
Headphone isn't a toy.....use for music listening only!
There're people who can learn and people who can't...
Batteries are meant for "gadgets" while the real hi-end systems only have "power supply" that can make system really shine with good power cords and power system (plugs, outlet, ground, etc.).
Vinnie,
He just dissed your whole company's theory. Ouch. Thats messed up...
Vinnie,
Interesting to consider the Hubble Telescope (or most solar powered satellites) as a gadget. I guess only satellites with plutonium reactors are real satellites.
Moderator: Headphoneus Supremus: The first to organize an International Head-Fi Meet (2006)
I suppose the $3000 Sunderland Ph.D battery powered phono stage is lower on the food chain than mid-fi :blink:
__________________
-My house was built for lovin'...not a theater of war.
-Realize it's harder to find your own voice, then to follow one, already in the air.
Music is my recreational drug...I need a dose, everyday!
Yeah, and the $25,000 battery powered ASR Emitter II power amp
is just a gadget as well.
What can I say... some people get it and some people don't
__________________
_____________________________________________ "Remember - Audiophile friends don't let audiophile friends listen to MP3s... Only use Lossless or WAV files!" :-)
Although I'm new here. I just wanna say. Are your so called $1500 CD players portable, WindowsX? At least Vinnie and Ken are making an effort to make products which improve SQ as well as being portable. Well of course you can't compare an iMod with Portable V-Caps with High end CD players as they are in two different categories. What people here want is good SQ and portability.
I'm crazy enough, I'd still compare. Whats to lose?
