You are in ALO Audio's Premier Sponsor Forum at Head-Fi.org.
To get back to Head-Fi.org's Main Forums, click here.
Register FAQ Members List Calendar Mark Forums Read Today's Posts Search
Go Back   Head-Fi: Covering Headphones, Earphones and Portable Audio > Premier Sponsor Forums and Sponsor Forums > ALO Audio Premier Sponsor Forum
Reply
Thread Tools Display Modes
Old 09-10-2007, 03:10 AM   #161 (permalink)
KB
Premier Sponsor
ALO Audio
KB's Avatar
Profile
Default
Originally Posted by Pokato View Post
Ken, would the Cyro Dock works with the P-Vcap Dock?
Yes, thats pretty much what I have standard with the Vcap Dock.
Ken
__________________
Ken--The ALOaudio HF sponsored forum is HERE
Contact me at Audiolineout@gmail.com[/size][/color]
KB is offline
Old 09-10-2007, 06:42 AM   #162 (permalink)
100+ Head-Fi'er
bigizzy75's Avatar
Profile
Default
Ken for those people who already have a cryo dock all they need is a mini to mini could they have that instead to come with the portable Vcap upon request? Also does it have to be an Imod to work with the portable Vcap?
Thanks,
Izzy
__________________
[size="1"]
Source:5.5G 30GB Ipod, 1GB Creative Zen Stone
Amp: Rockhopper Audio Mini3
Headphones: Denon D2000, V-Moda Vibes GunMetal Black
Workout Rig: 1GB Creative Zen Stone >> Sweaty ibuds
TEAM SAINT ANSELM COLLEGE
bigizzy75 is offline
Old 09-10-2007, 11:48 AM   #163 (permalink)
1000+ Head-Fi'er
manaox2's Avatar
Profile
IM Contacts
Send a message via AIM to manaox2
Default
Thanks,
Izzy
It has to be an iMod. Otherwise, you are just adding stuff to the signal path which only lowers quality.
manaox2 is offline
Old 09-11-2007, 02:50 PM   #164 (permalink)
100+ Head-Fi'er
brospin's Avatar
Profile
Default
Ken,
Is it possible to build the portable V-Cap case with input and output on the same side of the case (both 1/8 jacks, RCA not needed)?
Also do you have plans to build a more portable case with smaller polyproylene cpacitors (I'm thinking of the rather small Auricaps), again with both input and output on one side?
brospin is offline
Old 09-11-2007, 02:58 PM   #165 (permalink)
KB
Premier Sponsor
ALO Audio
KB's Avatar
Profile
Default
Originally Posted by brospin View Post
Ken,
Brospin,
Yep, input and output on the same side is the better way to go in terms of function so you do not have to run the output cable all the way back around. I did the in and out on opposite sides on this first run of mine because I did not want to have to run the cap lead (which is like a coat hanger thick wire) all the way back on itself. Also that plate will be quite crowded inside and I am not sure if it is physically possible to cram all the hardware on the plate. However I do have a few here I am working on with the in and out on the same side so I will see soon.
Auricaps will work good also.
Cheers
Ken
__________________
KB is offline
Old 09-11-2007, 03:10 PM   #166 (permalink)
100+ Head-Fi'er
brospin's Avatar
Profile
Default
Thanks Ken for the quick answer. Auricaps have soft wires on both sides, so redirecting all connections to one side of the case should be easier. In addition they are much smaller than the V-Caps (not much more than 1 x 1 inch for 200V up to 5 uF). I really look foward to seeing an Auricap based small-sized dock adpater case on your website soon!!
brospin is offline
Old 09-14-2007, 05:27 PM   #167 (permalink)
100+ Head-Fi'er
penger's Avatar
Profile
Default
Wait... so does this mean you will be making a portable auricap 'dock' as well? Or are you still just tinkering with the original vcap design?
__________________
Headphones: Sennheiser HD-650 w/ SAA Equinox, Audio Technica ATH-A900Ti, Shure E2c, Shure E500 w/ PTH
Amp: Singlepower Extreme Platinum w/ external power supply
Sources: laptop -> Silverstone EB-01, iPod nano 4gb, iPod Classic 160gb, Sony DAV-S300
penger is online now
Old 09-14-2007, 05:36 PM   #168 (permalink)
KB
Premier Sponsor
ALO Audio
KB's Avatar
Profile
Default
I decided to stay with the Vcap caps but might explore a Auricap version some time down the road. Right now I am making the Vcap ones. I might adjust the placement of the outputs, thats all.
Thx
Ken
__________________
KB is offline
Old 09-14-2007, 05:54 PM   #169 (permalink)
100+ Head-Fi'er
penger's Avatar
Profile
Default
Ahhh I see. Thanks for the clarification Ken.
__________________
Old 09-15-2007, 08:07 PM   #170 (permalink)
500+ Head-Fi'er
WindowsX's Avatar
Profile
IM Contacts
Send a message via MSN to WindowsX
Default
Ken, this won't make anything much better. iPod's lineout is a bit too weak for large caps especially in classic. If you want to make it sounds real better, give a dedicated power supply source and you'll know what's the difference between home CD player and portable batteried power player.
__________________
Headphone isn't a toy.....use for music listening only!
There're people who can learn and people who can't...
WindowsX is offline
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0 Head-Fi.org
