You are in ALO Audio's Premier Sponsor Forum at Head-Fi.org.
To get back to Head-Fi.org's Main Forums, click here.
Register FAQ Members List Calendar Mark Forums Read Today's Posts Search
Go Back   Head-Fi: Covering Headphones, Earphones and Portable Audio > Premier Sponsor Forums and Sponsor Forums > ALO Audio Premier Sponsor Forum
Reply
LinkBack Thread Tools
  #76 (permalink)
Old 01-05-2009, 06:33 PM
hockeyb213's Avatar
Send a message via AIM to hockeyb213 Send a message via MSN to hockeyb213
Default
couldn't you make the lod a little bit longer to relieve stress on the connectors?
__________________
Cheers!
Brad
ultraportable: iphone 32 gig 3gs > jh-13
portable rig: Imod 5.5 80gb>piccolino / singularity carbon lod>alo vcap dock> (piccolino mini-mini on the way) / singularity mini-mini>p-51>JH-13 with crystal piccolino all wrapped in a hippocase
On the way: RSA Shadow
My Feedback:hockeyb213
  #77 (permalink)
Old 01-05-2009, 06:52 PM
raffy's Avatar
100+ Head-Fi'er
Default
Originally Posted by palestofwhite View Post
Hi,
Actually I'm quite worried about the 18G SXC cables. I'm not sure if it'll fit the i-Qube and 5.5G iMod nicely.
If you stack the iMod which has the line out in the middle of the unit, and the i-Qube which has the input jack to the left of the unit, the SXC wires may have to twist sideways which I don't know if they're going to cause strains on both the dock and the line-in.
Regards.
If I'm not mistaken, you can ask Ken to make a slightly longer LOD to prevent stress on jacks on both the iMod and iQube.
__________________
Home Rig:
5.5g iMod/woody V-Cap Dock or Headamp Pico USB DAC ---> SP Extreme (Tung-Sol VT-231/GEC 6AS7G) ---> Grado HF-1 / Grado HF-2
My Feedback: http://www.head-fi.org/forums/f12/raffy-327673/
  #78 (permalink)
Old 01-05-2009, 07:08 PM
palestofwhite's Avatar
100+ Head-Fi'er
Default
Hi raffy,
Thanks for the information, I'd be glad to do so if it does not cost considerably more. Will drop Ken an e-mail soon.
Regards.
__________________
Could have been better.
  #79 (permalink)
Old 01-05-2009, 07:49 PM
Lamenthe's Avatar
100+ Head-Fi'er
Default
Thanks for the help guys and good news for my wallet. Thought I'd have to buy a separate one just for my nano. Palestofwhite's got me worried about the cable length now though lol. I'm probably going to be running the same setup of iQube + iMod.
  #80 (permalink)
Old 01-05-2009, 09:01 PM
raffy's Avatar
100+ Head-Fi'er
Default
Hi raffy,
Regards.
No problem. For all we know, the stock length might be enough anyway
__________________
Home Rig:
  #81 (permalink)
Old 01-06-2009, 08:00 AM
100+ Head-Fi'er
Default
Hi,
And now I'm in a dilemma... to custom or not? Vinnie will take 3 weeks to do my iMod. I still have plenty of time to consider... now for some serious thoughts...
Regards.
__________________
  #82 (permalink)
Old 01-07-2009, 10:31 PM
Lamenthe's Avatar
100+ Head-Fi'er
Default
Hi,
Regards.
Just received my Cryo cable and the stock length is nearly a perfect fit for a 30gb ipod 5.5 + iQube and that's with a .2cm protective barrier between the two. There is very slight pressure, but nothing to worry about.
On the other hand if you're getting a 80gb modded (assuming it's considerably thicker) then it might be worth the extra length just to be safe. Either way I'm sure Vinnie knows the best length for the job.
  #83 (permalink)
Old 01-08-2009, 08:54 AM
100+ Head-Fi'er
Default
Thanks for the advice! I just got my Paypal refund today and I was ready to purchase. Luckily I read your post first.
I have already dropped Ken a mail and we'll see how it goes.
__________________
  #84 (permalink)
Old 01-09-2009, 06:37 AM
100+ Head-Fi'er
Thumbs up
I have received my ALO Cryo SXC 18G iMod cable this morning via FedEx priority and it only took about 2-3 days to be shipped here (Singapore). I was impressed with how Ken treated the item with proper packaging and care when it comes to shipping.
The LOD itself, I feel (yes I can), is a product built with pride and love. The level of attention given into the making and finish is truely remarkable. I really appreciate the final touches like the ALO labeling and treatment used throughout the various parts of the item. I must also commend that the braids implemented are really even and very professionally done.
Now for the sound, I have only plugged it into my 4G Nano and i-Qube to let it burn in before the iMod comes back from Vinnie (hopefully, 2 weeks later). I can sense some improvement over the DIY 22G I have with me, right out of it's sealed packaging, and I really want to see how burning in can help the Blackgates. I see a true potential in this product and it does better than my Ultimate Link Silver Master-i line out dock (24G pure silver).
As described, it produces the highs that are comparable to Silver, but also compensates and add to the lower spectrum of the sound as to what copper should. It gives a fuller sound without losing the details, which I really appreciate, especially when used with my ER4P/S and i-Qube.
My only main concern will be to reform the wires so that it can fit the 5.5G 80GB iMod and the i-Qube. I'm thinking of applying some heat using warm air from a hair dryer. Is this step of heating to soften the wires and then to reform them, a recommended procedure? Please advice.
Lastly, I would like to thank Ken for being such a pleasure to do business with. He answers to all my questions (no matter how ridiculous they are) and never fail to give good advice. I will definitely turn to him for any cable related issues.
__________________
  #85 (permalink)
Old 01-12-2009, 08:47 AM
100+ Head-Fi'er
Default
After some burn in, things get smoother. Lamenthe, how did you re shape your wires to fit the i-Qube and 5.5G?
__________________
  #86 (permalink)
Old 01-12-2009, 10:14 PM
KB's Avatar
KB KB is offline
Premier Sponsor
ALO Audio
Default
palestofwhite,
Thank you, you are too kind. I would gently heat the wires with the hair dryer until that are warm to the touch, you do not need to get them too hot. Then just plug everything in the way you want it to be and hold them that way until the wires cool. They will remain in that shape.
Ken
__________________
Ken @ ALO
www.ALOaudio.com
www.32ohmAudio.com
Home of audiophile Grade Cables
The ALOaudio HF sponsored forum is HERE
Contact me at Audiolineout@gmail.com
Headphones; my personal "Cone of Music", amen!
Me
  #87 (permalink)
Old 01-30-2009, 01:30 AM
Head-Fi'er
Send a message via MSN to verjuno
Default
i wanna buy sxc cable
  #88 (permalink)
Old 02-03-2009, 01:13 PM
tnmike1's Avatar
1000+ Head-Fi'er
Default
Originally Posted by tnmike1 View Post
Don't know. Ken made the Imod Jmbo Cotton dock which I currently have. Only problem is, the jack is huge, as is my Switchcraft plug on my Apuresound Ety 4p which means I lose tons of space on the front of my Hornet amp. BUT my Jumbo is well broken in and mellow.
So--do I drop about 200 for a new dock, or keep the Cotton Jumbo?? Don't know. Still thinking about it
Thought about it Sold the Cotton Jumbo. Now listening to the new cable. Wonderful sound right out of the box. Now for that long-term burn-in
__________________
I can't see how the human race is going to survive now that the cost of living has gone up $2 a quart--W.C. Fields
  #89 (permalink)
Old 02-07-2009, 06:48 AM
musicmaker's Avatar
1000+ Head-Fi'er
Default
Edit: Just realized there is a SXC DIY thread. Posted my comment there
__________________
Sources: Cambridge Audio Azur 640C, RWA iMod 5.5 80gb w/ DIY Sonicap dock, iRiver ihp-140
Amps: KICAS Caliente, SR-71, MiniBox-E+
Phones: Sony MDR-CD3000, Sennheiser HD600 w/ APS v3 cable, HD25-1 II w/ Vampire, Koss KSC-75
Cables: All DIY. See my Flickr photostream
My Feedback:
head-fi
ebay
  #90 (permalink)
Old 03-08-2009, 01:24 PM
Head-Fi'er
Default
Hi , currently i'm using the ALO UPOCC Cryo 22AWG LOD.
By changing to SXC 18AWG , what additional improvement will i get to hear?
thanks
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
FS: ALO 780J (ALO modded 780s w/JL Cryo wire) Morph201 Headphones For Sale / Trade 6 06-06-2008 01:51 AM
FS: TTVJ Millet Hybrid, ALO Jumbo Cryo & ALO SR60's Know Talent Amplification For Sale / Trade 4 01-18-2008 05:56 PM
anybody know how the ALO cryo x silver compares to the jumbo cryo dock? SpinalLove Portable Source Gear 2 07-24-2007 09:50 PM
help!!! Comparison between ALO cryo, silver-cotton and cryo jumbo. doty Cables, Power, Tweaks, Speakers, Accessories (DBT-Free Forum) 0 07-24-2007 12:43 PM
go with ALO cryo x silver or jumbo cryo dock? opinions appreciated SpinalLove Cables, Power, Tweaks, Speakers, Accessories (DBT-Free Forum) 0 07-23-2007 05:48 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2 Head-Fi.org
