01-04-2009, 02:02 AM
1000+ Head-Fi'er
Originally Posted by palestofwhite
I should be ordering an iMod SXC line out dock soon. My iPod is on it's way to RWA for iMod.
HUH??? What did I miss?? Went on the ALO website and didn't see the Imod SXC LOD. Is it available?? How much??? 18g or 22g??
__________________
I can't see how the human race is going to survive now that the cost of living has gone up $2 a quart--W.C. Fields
01-04-2009, 02:11 AM
Second from the top HERE
Thanks
Ken
01-04-2009, 06:10 AM
100+ Head-Fi'er
I will be ordering one next week! I actually had a DIYed SXC 22G (non iMod) from a local appreciator. It sounded really good with my 5.5G.
Now that I've sent my 5.5G to RWA for an iMod, and I really wanted to see what an 18G SXC with Blackgates and Cryo treatment can do.
__________________
Could have been better.
01-04-2009, 10:27 AM
1000+ Head-Fi'er
Thanks
Ken
DUUUH--was looking under the "cable" sections. Thanks.
__________________
01-04-2009, 02:21 PM
100+ Head-Fi'er
So... tnmike1, going for one as well?
__________________
01-04-2009, 08:47 PM
500+ Head-Fi'er
Hi,
i own one Jumbo Cryo x Silver iPod Dock and want to know what are the main sound differences bw it and ALO Cryo SXC 18G cable ?
Does it worth the jump, because for me cosmetic issue (patina) on the copper cables is not a problem.
Thank you.
__________________
The best is yet to come !
RWA Imod-ALO Vcaps and cables (jumbo cryo) -RSA Hornet - Grado GS 1000.
Predator in burning process...
waiting for ALO X cryo silver cables.
All burn'in with my greats Burn'in plugs.
Heard the sound but don't forget the Music.
01-04-2009, 09:25 PM
1000+ Head-Fi'er
Don't know. Ken made the Imod Jmbo Cotton dock which I currently have. Only problem is, the jack is huge, as is my Switchcraft plug on my Apuresound Ety 4p which means I lose tons of space on the front of my Hornet amp. BUT my Jumbo is well broken in and mellow.
So--do I drop about 200 for a new dock, or keep the Cotton Jumbo?? Don't know. Still thinking about it
__________________
01-04-2009, 09:53 PM
^ why don't you have the Ety cable reterminated to an smaller 1/8" plug. Or you could look for an SR71 to accomodate both of your current plugs. Lastly use your Reference, it should be able to accomodate both plugs.
01-04-2009, 10:56 PM
Originally Posted by Rico67
Hi,
Thank you.
See post #5 http://www.head-fi.org/forums/4780321-post5.html
01-05-2009, 05:00 AM
100+ Head-Fi'er
This might be a silly question, but does the iMod Cable ALO SXC Cryo work with regular ipods as well? Just want to know before I damage something trying it out.
01-05-2009, 06:01 AM
100+ Head-Fi'er
Hi,
According to Ken (ALO) and Vinnie (RWA), the iMod cables will work for normal iPods but non-iMod cables should not be used on an iMod.
As to what the blackgates in iMod cables can do to the normal iPod, I'm not sure.
I will be getting an SXC 18G iMod LOD soon and hope for my iMod to be done in the next few weeks so I can share more with you.
Regards.
__________________
01-05-2009, 09:03 AM
100+ Head-Fi'er
Hi,
As to what the blackgates in iMod cables can do to the normal iMod, I'm not sure.
Regards.
Regards.
some say caps, even on a normal ipod, improve the sound nontheless - I believe it shouldn't damage anything, but I haven't tried.
01-05-2009, 01:22 PM
500+ Head-Fi'er
Mathematical, it's never good to add caps in the signal path...
it's decrease the coupling caps value and increase the frequencie break point.
So as there are soon caps in the regular ipod, it's not a good idea to use an imod cable.
__________________
01-05-2009, 03:34 PM
1000+ Head-Fi'er
Have used my Jumbo Imod Cryodock on my Nano for long time. No problems, no worries. Just kinda big for the little Nano
__________________
01-05-2009, 06:24 PM
100+ Head-Fi'er
Hi,
Actually I'm quite worried about the 18G SXC cables. I'm not sure if it'll fit the i-Qube and 5.5G iMod nicely.
If you stack the iMod which has the line out in the middle of the unit, and the i-Qube which has the input jack to the left of the unit, the SXC wires may have to twist sideways which I don't know if they're going to cause strains on both the dock and the line-in.
Regards.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
Similar Threads
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
FS: ALO 780J (ALO modded 780s w/JL Cryo wire)
Morph201 |
Headphones For Sale / Trade |
6 |
06-06-2008 01:51 AM |
FS: TTVJ Millet Hybrid, ALO Jumbo Cryo & ALO SR60's
Know Talent |
Amplification For Sale / Trade |
4 |
01-18-2008 05:56 PM |
anybody know how the ALO cryo x silver compares to the jumbo cryo dock?
SpinalLove |
Portable Source Gear |
2 |
07-24-2007 09:50 PM |
help!!! Comparison between ALO cryo, silver-cotton and cryo jumbo.
doty |
Cables, Power, Tweaks, Speakers, Accessories (DBT-Free Forum) |
0 |
07-24-2007 12:43 PM |
go with ALO cryo x silver or jumbo cryo dock? opinions appreciated
SpinalLove |
0 |
07-23-2007 05:48 PM |
Powered by vBulletin® Version 3.8.4 Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
