Head-Fi: Covering Headphones, Earphones and Portable Audio
Support Head-Fi by starting your Amazon.com shopping by clicking here
Follow headfi on Twitter!
Follow Rocky Mountain Audiofest (RMAF) on Twitter!
Head-Fi Is Sponsored By:
Featured
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
Can Jam '09
(2009 International
Head-Fi Meet)
Impressions,
Reviews, Photos
Can Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss 1, 2, 3
dallan 1, 2, 3, 4
santacore 1, 2
nhat_thanh 1, 2
vpivinylspinner 1, 2, 3
amb 1
augustwest 1
eaglejo 1
johnsonad 1
shellylh 1
Jon L 1, 2, 3, 4
Germancub 1
zippy2001 1
IPodPJ 1
bhd812 1
Edwood 1, 2
abellaw 1, 2
minidiscs 1
atothex 1
HighLife 1
achristilaw 1
SiBurning 1, 2, 3, 4
SiBurning 5, 6, 7
LFF 1
Iron_Dreamer 1
doping panda 1
morphsci 1
ironbut 1
shaizada 1
jasper994 1, 2
jp11801 1
Uncle Erik 1
drubrew 1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Featured
Head-Fi's Sponsors
Featured
  #106 (permalink)
Old 09-11-2007, 07:22 PM
ezkcdude's Avatar
500+ Head-Fi'er
Default
Originally Posted by bearmann View Post
Greetings,
I'm very interested in this DAC. But wondering if/how "Ballsie" will decrease the sound-quality?! I've read a comment at the diyaudio-thread, that the only advantage of the OPUS is his balanced out ... so if you'll use the Ballsie it's quite unspectacular/worthless. What do you think? - Is the Opus still interesting if you'll use unbalanced out?
Best regards,
bearmann
If that's what is being said, I don't agree. Whether a DAC is balanced or not is only one part of the equation. If a mediocre DAC could be made great just by making it balanced, wouldn't they all be that way? Sure, a DAC may be generally improved by adding a balanced output, but it also depends on how it is implemented. Simply because a DAC is balanced does not make it great. And vice-versa, of course. You must understand the entire DAC topology, and not just focus on one aspect like balanced or unbalanced. If the Opus is a good DAC (and I can't make that judgement not having heard it), then it is not just because it is balanced. It is the overall design. Making the balanced-to-single-ended conversion should not make an otherwise great DAC poor or mediocre (maybe just a teenie weenie less great). IMHO, YMMV.
__________________
There are 10 kind of people in the world - those who understand binary and those who don't.
ShinyMetal
Site| RSS |Forum
d(-_-)b | [:] :)
last.fm Music Profile
  #107 (permalink)
ezkcdude's Avatar
500+ Head-Fi'er
Default
double post, sorry.
__________________
ShinyMetal
Site| RSS |Forum
d(-_-)b | [:] :)
  #108 (permalink)
Old 09-11-2007, 08:10 PM
tomb's Avatar
Member of the Trade
Beezar
Default
I agree in priciple with what you've said - but I was wondering the same thing as Bearmann. If you study the Ballsie, you'll see that the Wolfson DAC's quad outputs are funneled through two sets of opamps in series - two LM4562's and an LME4974. Using a USB input card is even further extending things - they employ a second PCM2707 DAC and state that the USB card for the OPUS can be used as a "single-ended, mid-level, standalone DAC" by itself. So, if you're wanting a USB-input, stereo source DAC similar to an Alien - only "high end," you'd have to add three opamps and another DAC into the signal path of the OPUS.
There may not be anything bad with any of that, but it seems we're taught to avoid opamps in order to be king of the hill these days, and the PCM 2707 seems to really confuse things.
So, not trying to cause trouble, but I think Bearmann's question was a good one, perhaps.
  #109 (permalink)
Old 09-11-2007, 08:21 PM
FallenAngel's Avatar
Default
I thought that the USB input is handled by the PCM2707 and then I2S is sent to the WM8740 DAC. The "standalone DAC" is referring to using the DAC inside the PCM2707 and getting line level analog output from there, this would not be a "preferred intended" use of the Opus, in fact, it bypasses it. Under normal circumstances, that PCM2707 is just a USB receiver, nothing more.
As for the Ballsie, I have no idea how it's done or why it's done that way. But then again, it's not surprising since I don't know balanced to single ended conversion architecture.
__________________
Home: ESI Juli@ (I2S) -> Buffalo32 -> Balanced Dynalo / Melos Maestro / SinglePower MPX3
Headphones: HP-2, RS-1, SR-200, Sennheiser HD-600, HD-650, Denon D-5000, AKG K271
Portable: 240GB diyMod 5.5G -> V-Cap Dock -> PPAS -> UE700
Work: EMU0404 PCI -> Buffalo24 -> Balanced CKK-III -> Manufaktur DT770/600
Feedback
Digital Audio Primer
  #110 (permalink)
Old 09-11-2007, 08:26 PM
tomb's Avatar
Member of the Trade
Beezar
Default
I only referenced the PCM2707 stand alone because they imply "mid-level". Maybe that would have some effect on degrading the USB processing since it is in the path (lower level subroutines)? Again, it may just not be optimum to take an OPUS and turn it into a single ended, but that's the reason I thought it was a good question. I added the USB question because that's how I'd like to use it.
I hardly know any of the architecture, period.
  #111 (permalink)
Old 09-11-2007, 08:33 PM
Pars's Avatar
Can Jam '10 Organizer
Default
Originally Posted by error401 View Post
DigiKey carries the Amveco 70063 (TE70063-ND), a 15V+15V 25VA unit for $21.13 USD if you often order from them.
That's the PCB mount transformer... the standard toroid (non-PCB mount) is the TE62063-ND at $24.98 each. http://dkc3.digikey.com/PDF/T073/P2145.pdf
  #112 (permalink)
Old 09-11-2007, 09:09 PM
bearmann's Avatar
100+ Head-Fi'er
Send a message via ICQ to bearmann
Default
Greetings,
at first to state this clear: I've no idea about the whole dac-architecture in detail. My knowledge ends somewhere between the fact, that you need a receiver for the spdif-stream through usb and an (integrated) I/V-stage at the DAC-chip itself.
I've probably the same problem as tomb...
All my rig is single ended and the Opus DAC seems to be a really nice and reasonable priced diy-dac. BUT is it still worth the ~$300 (dac, usb, ballsie, psu) if you will use it "only" single ended?!
I know that wether a ballsie nor a zapfilter will decrease the soundquality of the Opus in that way, that'll be on AlienDAC level ...
And I know that the PCM2707 is only used to transform the spdif-stream through usb to I²S and in that fact it's not acting like a PCM2707-based DAC (like AlienDAC and so on) ...
I simply don't have the technical background to judge if it's intelligent to build a balanced DAC (with all the effort) and use it then just single ended?! This question stays ... or is it redundant?!
best regards,
bearmann
__________________
foobar2000 > AlienDAC > CK²III > HD595
  #113 (permalink)
Old 09-11-2007, 09:45 PM
ezkcdude's Avatar
500+ Head-Fi'er
Default
Balanced-to-single-ended conversion can be performed with a single op amp per channel. Just take a look at my ezDAC design! That's how I did it. Like you guys, I too am somewhat scared by the prospect of several op amps in a row. Seems like bad things can happen. However, there are plenty of real-world designs out there using several op amps per channel, and at the same time, loved by audiophiles. These folks may also point out that using a single op amp, as in my design, also has its pitfalls. Indeed, even using a single resistor for I/V (again as I have) may be the simplest and seemingly most "pure" design, but it has flaws as well. There is no perfect design. For example, you may increase dynamic range at the expense of linearity. Or you may increase noise at the expense of frequency response. These are totally random examples, and may not actually be the case, but hopefully, you see my point.
__________________
ShinyMetal
Site| RSS |Forum
d(-_-)b | [:] :)
  #114 (permalink)
Old 09-14-2007, 01:36 PM
BrianDonegan's Avatar
100+ Head-Fi'er
Default
Couple small points:
You can use the Opus single-ended without the Ballsie, by just using the +OUT and GND from each channel. It will be -6dB (half of a balanced signal), but no op-amps, if that's what you are after. You just need a bit more gain afterwards.
The Ballsie uses one op-amp for Bal->SE conversion (LM4562). The quad-opamp (dual 4562) is used as a low-pass filter. The caps for the filter are through-hole and shipped un-mounted, so the filtering is optional. You can feed the Ballsie a balanced signal, and take balanced out after the filter, without using the Bal-SE converter, or use both. You can also feed the Ballsie from a dual-mono balanced setup.
If you do not need the Ballsie for SE, why did we make it? Options. Balanced or SE Output Buffer, optional Output LP filter (500kHz).
As for the PCM2707, we called it "mid-range" because the WM8740 is a better DAC, so it's relative. We were both suprised at how good it is though. I use a USB board as my PC headphone amp now at work. Bus powered makes it simple (not ideal, but simple). Sounds fantastic compared to the sound card in my work machine, which is not hard to do.
It's all about options for us, and not dictating how the modules will be used.
  #115 (permalink)
Old 09-14-2007, 01:59 PM
MASantos's Avatar
Default
I didn't know that you could get SE without the ballsie, but then I haven't studied the shematic that well yet. This certainly is good news since it removes complexity(read price).
__________________
For Sale: RCA-RCA interconnects!
CEO of Head-fi Portugal! Top Portuguese poster!
"If Rimes were Valiums I'd be confortably numb"- Bradley Nowell
Team AKG701, Team DIY, Team Gin Drinkers
My Feedback
  #116 (permalink)
Old 09-14-2007, 02:01 PM
100+ Head-Fi'er
Default
Using only one output will decrease the signal by 3 dB, not 6 dB. The main thing however is that it will also decrease the dynamic headroom and signal to noise ratio by 3 dB.
  #117 (permalink)
Old 09-14-2007, 02:11 PM
100+ Head-Fi'er
Default
3dB in power, 6dB in voltage - voltage really being the more appropriate.
  #118 (permalink)
Old 09-14-2007, 02:17 PM
n_maher's Avatar
Moderator
Resistorous Conflagorous
Default
As far as I know you can always use a balanced source single ended provided that you're willing to live with the lower output levels. As Brian said, that's really just a function of how much gain you need/have downstream. Me, using my balanced DAC single-ended hasn't presented an issue at all and I'd forgo using the ballasie unless you really need the maximum output level from the DAC.
__________________
SB3/Arcam CD73 -> Hertsens Signature DAC -> Project Menace -> Woody HF-1 or HF-2
-Head-Fi Feedback-
d-_-b
  #119 (permalink)
Old 09-14-2007, 02:27 PM
100+ Head-Fi'er
Default
That and the common mode rejection of noise.
  #120 (permalink)
Old 09-14-2007, 02:50 PM
100+ Head-Fi'er
Default
Or an output buffer (SE or balanced) and/or want to LP filter.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
