Head-Fi: Covering Headphones, Earphones and Portable Audio
Support Head-Fi by starting your Amazon.com shopping by clicking here
Follow headfi on Twitter!
Follow Rocky Mountain Audiofest (RMAF) on Twitter!
Head-Fi Is Sponsored By:
Featured
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
Can Jam '09
(2009 International
Head-Fi Meet)
Impressions,
Reviews, Photos
Can Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss 1, 2, 3
dallan 1, 2, 3, 4
santacore 1, 2
nhat_thanh 1, 2
vpivinylspinner 1, 2, 3
amb 1
augustwest 1
eaglejo 1
johnsonad 1
shellylh 1
Jon L 1, 2, 3, 4
Germancub 1
zippy2001 1
IPodPJ 1
bhd812 1
Edwood 1, 2
abellaw 1, 2
minidiscs 1
atothex 1
HighLife 1
achristilaw 1
SiBurning 1, 2, 3, 4
SiBurning 5, 6, 7
LFF 1
Iron_Dreamer 1
doping panda 1
morphsci 1
ironbut 1
shaizada 1
jasper994 1, 2
jp11801 1
Uncle Erik 1
drubrew 1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Featured
Head-Fi's Sponsors
Featured
  #751 (permalink)
Old 08-11-2008, 01:53 AM
Ech0's Avatar
100+ Head-Fi'er
Default
I was hooking up the S/PDIF Module this evening and checked for resistance between signal and ground on the S/PDIF_IN once I was done. There was resistance between the two. So, I pulled the wires off and removed the board. Checked again, still had resistance between signal and ground (no solder bridges). It's only on the S/PDIF_IN side.
I "assume" this isn't normal. Any thoughts?
__________________
ArchLinux HTPC :: M-Audio Audiophile 24/96 :: ALSA
DAC: Opus w/Metronome & Ballsie
Amps: Beta22 / 3 Channel :: Millet Max :: SOHA
Heaphones: JVC DX1000 :: Sennheiser HD650 :: Beyerdynamic DT770 :: Sennheiser HD280
  #752 (permalink)
Old 08-11-2008, 01:55 AM
100+ Head-Fi'er
Default
This s normal as long as it 75 ohms.
  #753 (permalink)
Old 08-11-2008, 03:17 AM
Ech0's Avatar
100+ Head-Fi'er
Default
Indeed it was 75 ohms.
This puzzles me a bit, but, I'm glad I'm good to go. Thanks for the fast response Russ. I can't wait to finish this baby up.
The packaging was outstanding as I've read before. Someone must be a little obsessive.
__________________
  #754 (permalink)
Old 08-11-2008, 04:07 AM
manaox2's Avatar
Send a message via AIM to manaox2
Default
Originally Posted by Russ White View Post
There is no ballsie involved. Those are Three IVYs.
The two IVYs on the right are configured for mono DACs (either Opus or COD). They have balanced only outputs.
The IVY on the left is simply doing balanced to single ended conversion. This way you can have SE outputs that are the sum of balanced output at the same level as the balanced output. The best way to get a clean SE signal is to sum the balanced signal.
The text expands on this a bit.
Cheers!
Russ
Just wondering if all three of these could be powered properly off of one or two LCBPS with one of the recommended Lindberg transformers? (Not along with the DAC too of course)
__________________
'Head-fi Beginner's Guide' | 'Last.fm'
Head-Fi feedback
  #755 (permalink)
Old 08-11-2008, 04:14 AM
100+ Head-Fi'er
Default
Just one LCBPS with one of those dual secondary transformers is just fine for all three. But two would work too.
Cheers!
Russ
  #756 (permalink)
Old 08-11-2008, 04:23 AM
Beefy's Avatar
1000+ Head-Fi'er
Default
Actually, I've been wondering about something similar to this as well......
I was planning to run both 'channels' of an LCDPS from a single 15V 7.5VA secondary winding (one channel VD for Buffalo, one channel OTTO and LEDs). But with losses from two sets of rectifiers and two regulators, I'm wondering whether it will be enough.
So Russ: do you have any approximate figures for current/power draw for OPUS, IVY and Buffalo at the recommended supply voltages?
  #757 (permalink)
Old 08-11-2008, 05:40 AM
manaox2's Avatar
Default
Cheers!
Russ
Thanks for that, I am considering it when I get ready to purchase the Joshua Tree when it finally comes back into stock.
__________________
Head-Fi feedback
  #758 (permalink)
Old 08-14-2008, 03:57 AM
Ech0's Avatar
100+ Head-Fi'er
Default Opus up and running....
Many thanks Brian & Russ for this fantastic DAC. It was a fun build and I really like the modules concept for flexibility of parts desired, but, it also made the layout attractive, IMO. Once I got the settngs configured properly the DAC w/my amp combo is dead silent when no music is being sent through. I've only listened to the opus for a short while but the clarity is the first thing I noticed. It was as if my previous DAC muffled the sound. My previous setup struggled on some highs particularly female vocals. Sorry, for the poor word choice I've not had a lot of experience having only listened to a marginal amount of gear.
Anyway, the only issue I had was following the recommended setting for each module I ended up w/static only. I found the answer at the Twisted Pear website (forum). Someone else experienced this issue and Russ suggested changing the OSR setting on the Opus to "+". The manual (version 2.0) recommends leaving this switch open. Though I'd mention it might help someone else.
Setup is as follows: S/PDIF > Metro > Opus > Ballsie
Thanks again guys and I'll post pics tomorrow for anyone interested.
Edit: The static issue was with the Metronome set 192khz output.
__________________
  #759 (permalink)
Old 08-18-2008, 06:59 AM
Bozz_Keren's Avatar
500+ Head-Fi'er
Location: In my nice comfortable chair, listening to my Cans
Default
hi, i'm newbie in DIY and want to ask something
what's the difference between Ballsie and IVY module?
thanks
__________________
Home: Valab NOS DAC -> Analog OCC IC -> Little Dot MK IV -> AKG K500 / Edifier C3
Portable: Sony A-826 4GB -> Yuin PK1
Wishlist: Beta22, SET Tube Amp
Team Tube VS SS
Feedback
  #760 (permalink)
Old 08-23-2008, 02:47 AM
Head-Fi'er
Default
thanks
page 66
laziness is the worst sin
  #761 (permalink)
Old 08-27-2008, 07:56 PM
ezkcdude's Avatar
500+ Head-Fi'er
Default
I'm trying to recommend the Opus DAC to someone, but the website says all the modules are "Out of Stock". Is that the case?
__________________
There are 10 kind of people in the world - those who understand binary and those who don't.
ShinyMetal
Site| RSS |Forum
d(-_-)b | [:] :)
last.fm Music Profile
  #762 (permalink)
Old 08-27-2008, 07:59 PM
BrianDonegan's Avatar
100+ Head-Fi'er
Default
I am on a bit of a vacation (actually getting ready to sell our house). I will have the site back online in a few days, with most things back in stock.
__________________
Abiding Diax's Rake
  #763 (permalink)
Old 08-31-2008, 06:56 AM
dgbiker1's Avatar
500+ Head-Fi'er
Default
Finished... for real this time... until I get a metronome...
__________________
Headphones: AKG K701 --- Grado SR225 --- B&O A8 --- Atrio M8
Amps: Little Dot MKIII --- AMB M^3 --- AMB Mini^3 --- CMoy/TLE
Sources: Opus --- 3G iPod Nano --- 4G iPod Rockboxed --- Acer Aspire 1
Other: Meier Crossfeed
  #764 (permalink)
Old 08-31-2008, 07:05 AM
penger's Avatar
500+ Head-Fi'er
Default
Sweet!
__________________
Feedback
  #765 (permalink)
Old 09-10-2008, 12:16 PM
Junior Head-Fi'er
Default
Has someone ever tried the Opus DAC combined with a Zapfilter?
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
