Head-Fi's Sponsors
(Premier Sponsors bolded) |
Can Jam '09
(2009
International
Head-Fi Meet)
Impressions,
Reviews, Photos |
Can
Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss
1,
2,
3
dallan
1,
2,
3,
4
santacore
1,
2
nhat_thanh
1, 2
vpivinylspinner
1,
2,
3
amb
1
augustwest
1
eaglejo
1
johnsonad
1
shellylh
1
Jon L
1,
2,
3,
4
Germancub
1
zippy2001
1
IPodPJ
1
bhd812
1
Edwood
1,
2
abellaw
1,
2
minidiscs
1
atothex
1
HighLife
1
achristilaw
1
SiBurning
1,
2,
3,
4
SiBurning
5,
6,
7
LFF
1
Iron_Dreamer
1
doping panda
1
morphsci
1
ironbut
1
shaizada
1
jasper994
1,
2
jp11801
1
Uncle Erik
1
drubrew
1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook |
Head-Fi's Sponsors
07-30-2007, 11:58 PM
1000+ Head-Fi'er
I did notice that the dac boards have regulators on board for both digital and analog supplies onboard, I am still curious though. My plan was to build the sigma22 and try it to see if theres a difference, and if there wasn't I would just change a few parts out to use for my future beta22. After reading some more I think I understand how it works a bit better now. I still have so much to learn
07-31-2007, 12:18 AM
500+ Head-Fi'er
Not all is lost. Get the sigma22 for your future project and use the positive rail to power the analog supply of the dac and see if it makes a difference. If it does then you may want to upgrade to the sigma11's down the road. Just make sure the sigma22 is configured to supply 6-7volts for the dac (calculations are on the AMB website) to keep the onboard LDO regulator(s) from dissipating too much heat.
Renato
__________________
__________________________________________________ ________________________________
Sources: Cambridge Audio Azur 840C / Music Hall CD-25 / Marantz CD-67SE / E-Sound CD-E5 / Sony XA20ES / CI Audio VDA-1
Amps: Aikido 6CG7-6H30 Tube Amp / Sol Headphone Amp
Cans: HF2 / MS-PRO / MS-2i / MS-1 / K340 / K1000
07-31-2007, 12:33 AM
Headphoneus Supremus Member of the Trade: S² Audio
Location: I'm a displaced Alaskan living at the beach in Port Aransas, Texas.
It's like a whole other language that I don't speak.  Thank goodness you guys do!
Datos and dovetails I know!
07-31-2007, 12:46 AM
1000+ Head-Fi'er
No worries, I'm picking up a sigma11 or two for my squeezeboxes, so not all is lost either way
07-31-2007, 01:00 AM
1000+ Head-Fi'er
I'm learning that language slowly yet surely too!
07-31-2007, 01:12 AM
500+ Head-Fi'er
Nate (n_maher) built some for squeezboxes. If i remember correctly there was a change to the configuration for 5Volts. I think it's in the sigma22 thread on headwize.
~R~
__________________
07-31-2007, 01:18 AM
500+ Head-Fi'er
Steve I feel ya! Ben had been helping me and I really have no idea what I am doing with this stuff. The Opus sounds trully amazing balanced through a speaker rig. I really don't care for it with headphones much but I can't wait to build one for the speakers! Thankfully he left it with me for a couple of weeks to play with.
I emailed Jeff at GlassJar and Ti about the Sigma 22 board. I'll probably use the Twisted Pear power supply to start until you guys perfect the Sigma 11 build and use a shielded transformer and a copper housing for now.
BTW, who else sells shielded transformers other than Avrel? Excuse me as I am a NOOB when it comes to this  I have a strong desire to build this and fast
07-31-2007, 02:05 PM
500+ Head-Fi'er
This is from Ti in response to the Sigma 11 boards being used for the Opus DAC.
" You can configure the sigma11s to output 7.5VDC by using the 9V configuration, except use BAX55C7V5 zener diodes for D5."
08-04-2007, 01:17 PM
1000+ Head-Fi'er
Originally Posted by philodox
The Zapfilter is just a high quality analog output stage.
I just noticed Twisted Pear has a line driver that would fit the bill as a line driver: http://www.twistedpearaudio.com/txd/txd.aspx I wonder how it would compare vs the zapfilter
08-04-2007, 02:10 PM
Headphoneus Supremus Moderator Resistorous Conflagorous
~R~
Yup, I've built 3 or 4 now. There is 5V specific information on amb's site now too.
__________________
SB3/Arcam CD73 -> Hertsens Signature DAC -> Project Menace -> Woody HF-1 or HF-2
-Head-Fi Feedback-
d-_-b
08-04-2007, 03:04 PM
1000+ Head-Fi'er
Master of the Squeezebox Sigma you are, Nate
08-04-2007, 05:25 PM
Ha! I'm sure it won't stay that way for long.
And I had quite the interesting visit with Brian from Twisted Pear yesterday. All I can say is keep your eyes on these guys. They've got some really cool stuff planned in the near future.
__________________
-Head-Fi Feedback-
d-_-b
08-04-2007, 05:32 PM
Head-Fi'er
Just because there's been more than one voltage said to be optimal for the Opus power supply, let me quote directly from the Opus documentation.
"The Opus is designed to utilize separate analog and digital power supplies from 6.5V to 15V. They do not need to be regulated, but a good dual regulated supply like the LCPS is recommended. There are two on-board voltage regulators to provide power to the DAC. If you use the LCPS adjust both output voltages to 7.5 for good results. This will provide more than enough voltage drop for the on-board LDO VREGs while not making them dissipate more power than required."
Just a note about pre-regulators, which is what you guys are planning on using the Sigma 11 for. These things need not be so elaborate to get the DAC to operate well. Depending on what sound you're looking for, an even simpler regulator could give you better results. A less regulated supply using a simple pass transistor without any feedback could give you looser, fuller bass and more overall warmth. I tend to like these more for pre-regulator use, but that's just me.
On that note, I do like the circuit topology of the Sigma series regulators, which feature very good stability into various loads. But man, for the current that the Opus or two Opuses are going to be drawing, TOTALLY overkill  But heck, going overkill is one of the advantages of DIY. Have fun guys.
08-04-2007, 10:00 PM
Can you hint at all in what direction they're going? More amps, more steppers, more DACs?
__________________
aka LightMeDark and yhamez on other forums
feedback
08-05-2007, 03:32 AM
Yeah, that was just evil to drop that hint and run!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
