Head-Fi: Covering Headphones, Earphones and Portable Audio
Support Head-Fi by starting your Amazon.com shopping by clicking here
Follow headfi on Twitter!
Follow Rocky Mountain Audiofest (RMAF) on Twitter!
Head-Fi Is Sponsored By:
Featured
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
Can Jam '09
(2009 International
Head-Fi Meet)
Impressions,
Reviews, Photos
Can Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss 1, 2, 3
dallan 1, 2, 3, 4
santacore 1, 2
nhat_thanh 1, 2
vpivinylspinner 1, 2, 3
amb 1
augustwest 1
eaglejo 1
johnsonad 1
shellylh 1
Jon L 1, 2, 3, 4
Germancub 1
zippy2001 1
IPodPJ 1
bhd812 1
Edwood 1, 2
abellaw 1, 2
minidiscs 1
atothex 1
HighLife 1
achristilaw 1
SiBurning 1, 2, 3, 4
SiBurning 5, 6, 7
LFF 1
Iron_Dreamer 1
doping panda 1
morphsci 1
ironbut 1
shaizada 1
jasper994 1, 2
jp11801 1
Uncle Erik 1
drubrew 1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Featured
Head-Fi's Sponsors
Featured
  #121 (permalink)
Old 01-27-2009, 05:45 PM
tangent's Avatar
Contributor
Headphoneus Supremus:
Top Mall-Fi poster.
The "T" in META42.
Member of the Trade
Default
Have you been cleaning the board?
__________________
"Give a man a fish and he eats for a day. Teach a man to fish and he knows what tackle to buy."
  #122 (permalink)
Old 02-02-2009, 03:09 AM
schubert's Avatar
Junior Head-Fi'er
Default
Well, no, I hadn't been, though it was on my list of things to try. So I gave it a thorough scrubbing, but there was no change.
I measured all the voltages I could think to measure and put them on the schematic. I included voltages I had measured with no op amp installed. I also included a few I had made with the op amp installed but not powered - I temporarily replaced Q2 with a new part (no change) and when I reinstalled the old one I didn't get the pin soldered to the top trace that led to op amp pin 7, so the op amp had no power for a while (it was soldered to the bottom trace, though). I've looked over this quite a bit, but without knowing the voltages for a healthy unit it's hard for me to try to pinpoint the problem.
If nothing sticks out as being obviously of culprit nature I'll start pulling parts one at a time. One thing I noticed, which may or may not mean anything - when first plugged in D2 stays lit for about as long as it would take to charge a capacitor. Could a capacitor be causing problems? Perhaps I'll replace C8-11 one at a time.
I realize all these numbers don't exactly add up right - my meter is no great shakes.
  #123 (permalink)
Old 02-11-2009, 12:20 AM
sachu's Avatar
Default
I could really use a board for a power supply build for my Scott Nixon USB DAC. I want to move away from using the SLA batteries and put in a nice solid power supply. This seems perfect.
An idea on the parts cost for this project?
Can you get a 5 V output from this design?
  #124 (permalink)
Old 02-11-2009, 12:29 AM
Beefy's Avatar
1000+ Head-Fi'er
Default
I don't think that this is available yet. Have you considered a σ11?
__________________
Sources: DIY Buffalo DAC, DIY γ1 DAC, iPod Classic 80Gb
Amps: DIY MMM/σ11, DIY Millett Mini MAX
Phones: Audio Technica ATH-AD900 and ESW9, UE SuperFi 5Pro
Head-Fi Feedback
  #125 (permalink)
Old 02-11-2009, 12:57 AM
sachu's Avatar
Default
I have..i just don't think the sigma11 is good enough for a digital supply.
  #126 (permalink)
Old 02-11-2009, 01:00 AM
Beefy's Avatar
1000+ Head-Fi'er
Default
Why not? Tangent reports 7µV noise. AMB reports less than 12µV. Both are far superior to commercial designs.
__________________
Head-Fi Feedback
  #127 (permalink)
Old 02-11-2009, 01:46 AM
sachu's Avatar
Default
I was thinking more on the lines of using a programmable shunt regulator on the likes of TL431, a transistor, a few resistors and coupling caps to get a good enough PSRR . I need a rock steady PSU at 5V with very low noise as this is the supply to the receiver and the interpolation filter on my DAC...
I understand that the error amplifier in the sigma11 is basically what is governing the PSRR.The other supply I am considering is COlin's regulator that is being discussed here.
I don't need a super high current regulator design, 300mA would be plenty enough. I would even settle for half that.
The parts cost on the sigma11 is not too bad, abt 20$ considering that it would go into my existing DAC case...
  #128 (permalink)
Old 02-11-2009, 02:55 AM
tangent's Avatar
Contributor
Top Mall-Fi poster.
The "T" in META42.
Member of the Trade
Default
Fully loaded, with case and all, something like $90. I haven't really priced it out...that's just based on the old STEPS cost of $70 for something similar, plus the additional costs here. Might even be closer to $80.
Sure. You need to change the voltage reference, probably the op-amp, and maybe the gain setting resistors. You need an op-amp that will itself run well on 5 V, and for the rest I recommend a 2.5 V reference and a gain of 2. This is covered in the YJPS docs, but I haven't tried it, so you'd be pioneering. Jung covered this in the original 1995 series of articles, and recommended the AD848 for the op-amp.
__________________
  #129 (permalink)
Old 02-11-2009, 03:28 AM
sachu's Avatar
Default
thanks for the reply tangent.
The parts cost is inclusive of the transformer I presume? I already have a transformer with a separate secondary winding of 0-6V..after rectification I should get around 7V DC. Would that be enough to use as input to the design?
Do you have any more boards left ? Does p-2 p wiring have any effects on your design?
  #130 (permalink)
Old 02-11-2009, 04:29 AM
tangent's Avatar
Contributor
Top Mall-Fi poster.
The "T" in META42.
Member of the Trade
Default
Fully loaded, yes. Nothing left out.
No. The Jung 2000 design is a "high drop-out" regulator. To get 5 V out, you might need as much as 10 V unregulated. This makes it less than 50% efficient at such low voltages, I know. If you want efficiency, there are many other designs to choose from.
No. I'm still tweaking the design. What with that work ongoing and manufacturing time, we're a month or two away from seeing final boards.
Are you asking what would happen if you made it on a perfboard? It's a fairly "fast" design, so it benefits from a good, tight PCB layout. If you switched to a slow op-amp, it could tolerate a big sloppy layout, but then you'd lose a lot of the performance advantages.
__________________
  #131 (permalink)
Old 02-11-2009, 05:09 AM
sachu's Avatar
Default
Yeah, I was hoping to use the separate winding on the transformer for further isolation between the analog and digital supplies. is there any detriment in using the same secondary taps for both digital and analog sections of the DAC?
Dang..this is the limitation that I am facing with the Toole regulator boards on diyaudio.com too.
yes..that is exactly what I asked. It is interesting that a few years back I had read one of the many Analog Devices application notes which said that most prototyping they did for fast designs were point to point.
With the minimal use of wires I wonder if point to point would be fast enough.
  #132 (permalink)
Old 02-11-2009, 07:07 AM
tangent's Avatar
Contributor
Top Mall-Fi poster.
The "T" in META42.
Member of the Trade
Default
Oh, probably, but I'm not the right guy to ask. I've done nearly zero digital audio DIY.
The issue is parasitics. The document you're talking about probably referred to ratsnest type builds, where you take a copper-clad board, tie that to some solid ground, then build your circuit in the air above it, with connections to ground as needed, and everything else held up above the board only by the stiffness of the wires. You still have to keep details in mind like minimizing the distance of bypass caps from the nodes in the circuit that need to be bypassed. Other than that, this keeps parasitics very very low: thick wires for low L's and R's, and air dielectric makes for low C's.
This sort of build doesn't hold up well to vibration. It's good for prototyping and hackery.
__________________
  #133 (permalink)
Old 02-11-2009, 07:13 AM
sachu's Avatar
Default
That is exactly what I am referring to The use of a copper board to build the circuit.
I built a diode ring mixer with trifilars a couple of quarters back using a copper board and the rest of the stuff suspended in the air....wa quite fun and worked lke a charm..agree with you about the vibrations and such.
  #134 (permalink)
Old 02-11-2009, 09:09 AM
tangent's Avatar
Contributor
Top Mall-Fi poster.
The "T" in META42.
Member of the Trade
Default
Perfboard fixes the structural problems, but adds a lot of parasitics. This is what I was warning against above. It's not a guarantee of failure, just a risk.
__________________
  #135 (permalink)
Old 04-29-2009, 08:18 PM
PJPro's Avatar
Head-Fi'er
Default
Did schubert ever sort out his problem?
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tangent STEPS Power Supply Built by Rockhopper Audio chesebert Cables, Speakers, Tweaks, Accessories For Sale / Trade 3 07-10-2007 06:53 PM
breadboarding a Tangent Cmoy, Power balance problems chuck94022 DIY (Do-It-Yourself) Discussions 10 09-12-2005 02:20 AM
Tangent Easy Power Supply 00940 DIY (Do-It-Yourself) Discussions 14 01-05-2004 02:52 PM
Jung multiloop amp...power supply notes stereth DIY (Do-It-Yourself) Discussions 3 06-05-2003 06:48 PM
What determines a good power supply vs. a great power supply? RockysDad DIY (Do-It-Yourself) Discussions 8 05-22-2003 03:18 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
