Head-Fi: Covering Headphones, Earphones and Portable Audio
Support Head-Fi by starting your Amazon.com shopping by clicking here
Follow headfi on Twitter!
Follow Rocky Mountain Audiofest (RMAF) on Twitter!
Head-Fi Is Sponsored By:
Featured
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
Can Jam '09
(2009 International
Head-Fi Meet)
Impressions,
Reviews, Photos
Can Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss 1, 2, 3
dallan 1, 2, 3, 4
santacore 1, 2
nhat_thanh 1, 2
vpivinylspinner 1, 2, 3
amb 1
augustwest 1
eaglejo 1
johnsonad 1
shellylh 1
Jon L 1, 2, 3, 4
Germancub 1
zippy2001 1
IPodPJ 1
bhd812 1
Edwood 1, 2
abellaw 1, 2
minidiscs 1
atothex 1
HighLife 1
achristilaw 1
SiBurning 1, 2, 3, 4
SiBurning 5, 6, 7
LFF 1
Iron_Dreamer 1
doping panda 1
morphsci 1
ironbut 1
shaizada 1
jasper994 1, 2
jp11801 1
Uncle Erik 1
drubrew 1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Featured
Head-Fi's Sponsors
Featured
  #91 (permalink)
Old 01-05-2009, 07:29 PM
schubert's Avatar
Junior Head-Fi'er
Default
Originally Posted by tangent View Post
That counts as difficult. You owe yourself and your son a beer.
Case work is difficult (for me, anyway) - this was merely tedious. No beer - he's just working off his tuition!
ruZZ.il: What kind of problems did the transformer cause?
Tangent: The sturdier opamp sounds like an excellent idea. Maybe I'll order an OPA604 - if I look for others, are there any other parameters to keep in mind, besides JFET and high voltage?
  #92 (permalink)
Old 01-05-2009, 08:13 PM
n_maher's Avatar
Moderator
Resistorous Conflagorous
Default
Originally Posted by ruZZ.il View Post
Nate, Got any comparisons to a STEPS with the M^3? I need to get myself some sort of drill press too.. I strive to have holes that aligned
Not from me, the PS is for a friend. I don't own anything that uses a power supply below 250V anymore. And all the fab for that case was done with a hand held drill, it's too cold in the garage to justify using the press for little stuff like this. Measure twice, use a punch and drill carefully.
__________________
SB3/Arcam CD73 -> Hertsens Signature DAC -> Project Menace -> Woody HF-1 or HF-2
-Head-Fi Feedback-
d-_-b
  #93 (permalink)
Old 01-05-2009, 08:51 PM
tangent's Avatar
Contributor
Headphoneus Supremus:
Top Mall-Fi poster.
The "T" in META42.
Member of the Trade
Default
Low noise is probably the most important thing. I wouldn't go much higher than what the AD825 puts out, 12 nV/rt.Hz. The 604 is a little lower, at 10 nV/rt.Hz. You can get down to about 4nV or so if you look hard enough, though you might give up too much else.
Don't go experimenting if you don't have an oscilloscope. You need to test this carefully before accepting it. You're pioneering here.
__________________
"Give a man a fish and he eats for a day. Teach a man to fish and he knows what tackle to buy."
  #94 (permalink)
Old 01-05-2009, 10:18 PM
ruZZ.il's Avatar
500+ Head-Fi'er
Default
Well, I was using +/-15v AC and dropping it to about 26Vdc which is around a 10v drop for the regulator, which was causing quite some heat on it so I wasnt even fully biasing my M^3. Changing to a +/-12v cut the voltage drop by around 70%.. fully biased and still much less heat.
Nate: Ah. I guess I need a punch :P
__________________
mac->gamma1/alien DAC->(mini)Millet Hybrid Max/M³(+STEPS)->Ultrasone pl 750. input regarding
mini diyMod/Touch->DIY modLOD/TouchLOD->Mini³/PIMETA(+STEPS)->Ultrasone pl 750. output here.
  #95 (permalink)
Old 01-06-2009, 12:37 AM
n_maher's Avatar
Moderator
Default
This is pretty similar to the one that I use to mark holes before drilling. And a few thousand holes of practice doesn't hurt either.
__________________
-Head-Fi Feedback-
d-_-b
  #96 (permalink)
Old 01-06-2009, 02:50 PM
schubert's Avatar
Junior Head-Fi'er
Default
I have access to an oscilloscope, though I've never used one before. I could get one of the physics teachers here to show me how to use it, I suppose, but I'm not sure what I would be looking for in a power supply - it's not like I could send a square wave through it. Maybe I'll leave the experiments to you. If you try an OPA604 and it works, will you post the results?
I must have done something else wrong if ruZZ.il used the same transformer and the only problem he had was heat/inefficiency. Either that or I got a bad part somewhere. When the new transformer comes I'll start by removing the opamp and one end of R8 and see what happens. In the meantime I'm without my PPA...
  #97 (permalink)
Old 01-06-2009, 03:57 PM
tangent's Avatar
Contributor
Top Mall-Fi poster.
The "T" in META42.
Member of the Trade
Default
In this case, oscillation. It'll be dead obvious. You just hook the scope probe across the output (ground clip to TP3, probe tip to TP6), set it for AC coupling, and set the bandwidth and vertical settings so you can see the scope noise, typically a few mV. That's all you should see; just a nice fuzzy line a few mV high. If it's oscillating, you'll probably see a huge periodic waveform; at the very least, enough high-speed "ripple" that it pokes up over the scope noise.
Do the test with the supply just sitting there idle, then put a dummy load across it, re-test, then put a real load on it and re-test.
__________________
  #98 (permalink)
Old 01-06-2009, 07:46 PM
schubert's Avatar
Junior Head-Fi'er
Default
So I'm not in danger of frying the oscilloscope by feeding all 30V or so directly into it?! I suppose then that "AC coupling" puts a capacitor in the path or some such thing to block DC? If I'm not liable to commit "oscilloscopicide" maybe I'll try it.
Would a power resistor work as a dummy load?
  #99 (permalink)
Old 01-06-2009, 10:17 PM
tangent's Avatar
Contributor
Top Mall-Fi poster.
The "T" in META42.
Member of the Trade
Default
Depends on the scope and the probe you use with it. A decent scope will have the input voltage limit printed on the front of the scope near the probe connection. The most common probe type is a 1/10x passive probe, which on the 10x setting cuts the signal down by 10x. So, if the scope says 30V but you use a 10x probe, you're still fine. Switch the probe to 1x, and you're right on the edge of damaging the scope.
Yes.
Yes.
__________________
  #100 (permalink)
Old 01-07-2009, 01:49 PM
schubert's Avatar
Junior Head-Fi'er
Default
I looked at the scope again, and it has a limit of 600V, so there's no problem there. I was puzzled by one thing - appended to the voltage limitation was "(P.P + DC)". Any idea what the "P.P" is? The manual to this thing has long since disappeared (as has the probe!)
  #101 (permalink)
Old 01-07-2009, 02:30 PM
tangent's Avatar
Contributor
Top Mall-Fi poster.
The "T" in META42.
Member of the Trade
Default
AC peak-to-peak, plus DC offset.
__________________
  #102 (permalink)
Old 01-09-2009, 04:22 AM
schubert's Avatar
Junior Head-Fi'er
Default
OK, I replaced the transformer and retested, with virtually the same result (except of course about 10V less) - still around 1.6 volts down over the LM317. I removed the opamp and lifted R8 - same result, 1.6V (also same result everywhere else). I suppose that pins it down to the LM317 - I'll replace that and post again with the results.
  #103 (permalink)
Old 01-09-2009, 11:04 PM
Junior Head-Fi'er
Default YJPS is up and running
I have mated the YJPS with the USB/DAC. It works.
The DAC is drawing about 290ma at 12vdc. No noise, no voltage sag, Maybe the heat sink are a tad too warm. I had to size them to fit inside the case so they are a bit shy of the correct size.
The PS has really helped the sound on the DAC. I am quite happy...
Thank you Warren
Phil
Santa Fe, NM
Sir, May I have another?
  #104 (permalink)
Old 01-10-2009, 03:50 AM
tangent's Avatar
Contributor
Top Mall-Fi poster.
The "T" in META42.
Member of the Trade
Default
Good to hear it.
There are some more things I want to do before I make the next run. Changes so far:
- Enlarged the mounting holes in the corners of the board
- Added separate test points for CGND and RGND, so you can test the three main sections of the circuit separately. (Changes most of the TP numbers, unfortunately.)
- Lots of tiny little part positioning tweaks and such
Still left to do:
- While assembling my first YJPS v1.1, it seemed to me that the VOUT and jumper pad scheme is probably a touch on the complex side. I want to look back at it and see if I can simplify it, or at least make it more elegant.
- Add another hole to each of the big film caps, C1-C3, allowing use of 12.5mm pitch caps.
- I'm considering moving at least D2 and Q1 to the other side of Q2 so you have the option of laying the transistor down flat for low-profile cases. I'd probably move R5 and R6, too if I did this. You can already do this with U1.
- The heat sink mounting holes are too small. They're going to be enlarged to allow at least #4 screws.
- I'm thinking of adding a zener/SCR type crowbar across the output of the supply to force the fuse to blow if you go over a safe output voltage for the op-amp, to prevent a recurrence of the problem Schubert's having.
Anything else for the wishlist?
__________________
  #105 (permalink)
Old 01-10-2009, 04:07 AM
schubert's Avatar
Junior Head-Fi'er
Default
Replaced LM317 - no change. Still -1.5V over LM317 with no op amp or R8 in circuit. -1.1V over TP5-TP6. D2 does not light. Any ideas?
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tangent STEPS Power Supply Built by Rockhopper Audio chesebert Cables, Speakers, Tweaks, Accessories For Sale / Trade 3 07-10-2007 06:53 PM
breadboarding a Tangent Cmoy, Power balance problems chuck94022 DIY (Do-It-Yourself) Discussions 10 09-12-2005 02:20 AM
Tangent Easy Power Supply 00940 DIY (Do-It-Yourself) Discussions 14 01-05-2004 02:52 PM
Jung multiloop amp...power supply notes stereth DIY (Do-It-Yourself) Discussions 3 06-05-2003 06:48 PM
What determines a good power supply vs. a great power supply? RockysDad DIY (Do-It-Yourself) Discussions 8 05-22-2003 03:18 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
