Head-Fi's Sponsors
(Premier Sponsors bolded) |
Can Jam '09
(2009
International
Head-Fi Meet)
Impressions,
Reviews, Photos |
Can
Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss
1,
2,
3
dallan
1,
2,
3,
4
santacore
1,
2
nhat_thanh
1, 2
vpivinylspinner
1,
2,
3
amb
1
augustwest
1
eaglejo
1
johnsonad
1
shellylh
1
Jon L
1,
2,
3,
4
Germancub
1
zippy2001
1
IPodPJ
1
bhd812
1
Edwood
1,
2
abellaw
1,
2
minidiscs
1
atothex
1
HighLife
1
achristilaw
1
SiBurning
1,
2,
3,
4
SiBurning
5,
6,
7
LFF
1
Iron_Dreamer
1
doping panda
1
morphsci
1
ironbut
1
shaizada
1
jasper994
1,
2
jp11801
1
Uncle Erik
1
drubrew
1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook |
Head-Fi's Sponsors
11-06-2008, 04:05 PM
100+ Head-Fi'er
Originally Posted by MASantos
Tangent, I can't see the image you posted above. Do other members see it?
http://tangentsoft.net/elec/yjps/bitmaps/board-1.1.png
EDIT
n_maher got it first
__________________
PC (WASAPI) → AMB/Mr.X γ1 (W.I.P) → Pure Silver m-RCA D.I.Y → Millett Hybrid MiniMAX D.I.Y (W.I.P) / AMB Mini³ D.I.Y → Sennheiser HD-650 / Grado RS-80
11-06-2008, 05:38 PM
Contributor  Headphoneus Supremus: Top Mall-Fi poster. The "T" in META42. Member of the Trade
Originally Posted by n_maher
Tangent's url just got cut off.
No, tangent just proved to himself that he still does occasionally post a URL publicly that points to his private web server.
__________________
"Give a man a fish and he eats for a day. Teach a man to fish and he knows what tackle to buy."
11-06-2008, 06:27 PM
1000+ Head-Fi'er
Just a random idea...
I wonder if it might be useful to include a spot for a current sensing resistor before the output. Would be very handy for testing amps.
11-06-2008, 06:51 PM
The point of this supply over something more typical is extremely low output impedance. You can't put a resistor on the output directly, or you'll wreck that. You could work out some kind of jumper scheme, but even that adds more resistance to the output.
If you install a Molex KK connector on the output, you can rig up an alternate version with such an inline resistor, or simply break the circuit with it so you can insert an ammeter.
__________________
11-10-2008, 09:07 PM
Gerbers away.
__________________
11-21-2008, 04:40 AM
__________________
11-21-2008, 10:33 PM
500+ Head-Fi'er
Tangent: will you be offering a kit for this (as opposed to the boards only) and also, will it be possible to do a dual rail supply with it?
Fran
11-22-2008, 01:57 AM
Sorry, no. Too many parts, many of them expensive. I wouldn't have a problem selecting a set of parts, but the expense and difficulty of kitting them in a sane fashion...<shudder>...
Sure, but it would be inefficient. You'd end up with at least two YJPS boards, and either one or two transformers, depending on how you want to work that. If that's your goal, I think you'd be better off going with one of the small transformer-less Jung regulator boards that already exist.
And no, there won't ever be an inherently "dual" version of the YJPS, with everything on a single board. It's not my niche.
__________________
11-22-2008, 02:13 AM
100+ Head-Fi'er
Those are pretty impressive numbers on that sheet of paper...
11-22-2008, 07:10 AM
Yes, that's rather the point of showing them.
I especially like the fact that the regulated output value didn't change at all when going from no load to a 105 mA load.
I haven't yet done LNMP testing, this is just my raw DMM readings. (My LNMP is broken at the moment. Grrr.)
__________________
11-25-2008, 04:47 PM
Junior Head-Fi'er
Application question
I hope an application question is OK here, even though this seems to be mostly a design thread. I need a new power supply for my Sota turntable - would the Young-Jung supply be appropriate for this use? Some details - my current supply puts out 25VDC (no regulation) and the motor momentarily draws around 150 mA while accelerating (occasionally up to 220 mA) and then settles to less than 50 mA. I'm looking for a lower cost high-performance alternative to Sota's "electronic flywheel", which is $300.
Thanks!
11-25-2008, 10:21 PM
I don't see why this wouldn't work, but then, I've never built or even modded a turntable.
__________________
11-25-2008, 10:57 PM
Junior Head-Fi'er
OK thanks Tangent, I'll go ahead. And thanks in general for all your work on the PPA etc - I built a PPA and a STEPS and I love them!
11-28-2008, 08:53 PM
100+ Head-Fi'er
I have a question about the filter that precedes the toroid in the schematic. Can this filter be applied to any electronic device's power supply?
11-28-2008, 11:59 PM
1000+ Head-Fi'er
It's basically identical to the circuit used in inexpensive line filters (e.g. http://www.cor.com/pdf/K.pdf), but with a beefier choke. You can use it for any circuit, provided you observe part ratings. Make sure you use line-rated components (C1 must be class X, C2 class Y) for safety.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
