Head-Fi: Covering Headphones, Earphones and Portable Audio
Support Head-Fi by starting your Amazon.com shopping by clicking here
Follow headfi on Twitter!
Follow Rocky Mountain Audiofest (RMAF) on Twitter!
Head-Fi Is Sponsored By:
Featured
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
Can Jam '09
(2009 International
Head-Fi Meet)
Impressions,
Reviews, Photos
Can Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss 1, 2, 3
dallan 1, 2, 3, 4
santacore 1, 2
nhat_thanh 1, 2
vpivinylspinner 1, 2, 3
amb 1
augustwest 1
eaglejo 1
johnsonad 1
shellylh 1
Jon L 1, 2, 3, 4
Germancub 1
zippy2001 1
IPodPJ 1
bhd812 1
Edwood 1, 2
abellaw 1, 2
minidiscs 1
atothex 1
HighLife 1
achristilaw 1
SiBurning 1, 2, 3, 4
SiBurning 5, 6, 7
LFF 1
Iron_Dreamer 1
doping panda 1
morphsci 1
ironbut 1
shaizada 1
jasper994 1, 2
jp11801 1
Uncle Erik 1
drubrew 1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Featured
Head-Fi's Sponsors
Featured
  #31 (permalink)
Old 07-22-2008, 09:43 AM
rds's Avatar
rds rds is offline
Default
It looks like the guide still needs some work. I don't think C8-c12 are mentioned either. You need to refer to the schematic directly at this point.
__________________
_________
__^___|____ (feedback)
___________Last.fm
freedom's just a word when you've got no one left to hurt
  #32 (permalink)
Old 07-23-2008, 09:30 PM
rds's Avatar
rds rds is offline
Default
I'm planning to use this for C1:
Digi-Key - P11006-ND (Panasonic - ECG - ECQ-U2A124ML)
and these for C2:
Digi-Key - P4608-ND (Panasonic - ECG - ECQ-U2A472MF)
These seem to be appropriate caps. Am I missing anything?
__________________
_________
___________Last.fm
  #33 (permalink)
Old 07-23-2008, 09:43 PM
n_maher's Avatar
Moderator
Resistorous Conflagorous
Default
I'd have to look more closely at those parts and the schematic but what I did was reference back to the equivalent part on the STEPS project when it seemed appropriate. Maybe that's what you're doing, but I'm at work and can't tell for sure. If not, look to STEPS for confirmation since the pre-reg stage is pretty similar IIRC.
[edit]The pre-reg stage of the YJPS is essentially the same so for C1 you want something like part # P10730 and for C2 #P10992.
__________________
SB3/Arcam CD73 -> Hertsens Signature DAC -> Project Menace -> Woody HF-1 or HF-2
-Head-Fi Feedback-
d-_-b
  #34 (permalink)
Old 07-23-2008, 09:52 PM
rds's Avatar
rds rds is offline
Default
Yeah, I have looked at the requirements and it's really c2 I want confirmation on. My understanding is it is type Y and rated for 250 V AC power line. But since I haven't seen them used before in STEPS I want to confirm I'm not overlooking something.
__________________
_________
___________Last.fm
  #35 (permalink)
Old 07-24-2008, 03:15 AM
tangent's Avatar
Contributor
Headphoneus Supremus:
Top Mall-Fi poster.
The "T" in META42.
Member of the Trade
Default
Yes, the line filter caps are the same in YJPS as in STEPS.
Basically, the gaps in the current YJPS docs are just in areas where I don't think there are any surprises.
__________________
"Give a man a fish and he eats for a day. Teach a man to fish and he knows what tackle to buy."
  #36 (permalink)
Old 08-08-2008, 10:59 PM
rds's Avatar
rds rds is offline
Default
I'm getting 7.7V regulated. The only value I've change is r10 to 3.32k.
I'm getting no voltage drop across d6, so obviously that's a problem. Can't figure out why... yet.
Is there supposed to be a jumper from rsv to rsvj?
__________________
_________
___________Last.fm
  #37 (permalink)
Old 08-08-2008, 11:36 PM
error401's Avatar
1000+ Head-Fi'er
Send a message via AIM to error401 Send a message via MSN to error401
Default
Originally Posted by rds View Post
I guess I'm missing something here, but when the r3 and r4 values in the schematic set the lm317 output to ~10V how are you supposed to get above 10v output? The build guide recommends not changing r3 and r4. I'm trying to get 30V output and my r10 and r11 values are 3.32k and 1k respectively.
As I would have expected I get about 7.7V regulated since the 317 is putting out 10v. Should I just ignore the instructions not to change r3 and r4?
EDIT it seems having about 2.5k on r4 would fix things. Does that sound right?
The LM317 floats above the regulator output voltage. As you can see in the schematic, ADJ is connected to Vout rather than ground as would normally be used. As written, the schematic keeps the LM317's output at ~2.3V above the regulated output at all times. This is the design mentioned by Jung in the 'Improved Positive/Negative Regulators' article on his site. It also appears in the National LM317 datasheet in the 'typical applications' section as a 'tracking preregulator'.
Because the prereg tracks the output, there's no need to adjust the resistors, it will always be 2.3V above the output, which gives enough headroom for the pass device to do its job.
__________________
http://audio.gotroot.ca/
Home [speaker] ~ PC » AlienDAC » 41hz AMP5 » Mission 770
Home [cans] ~ PC » MiniDAC » MiniVol » CK²III » Beyer DT-770 Pro80
Portable ~ Zune 30GB » Mini³ » K81DJ
In progress designs ~ AD1955 'MiniDAC' ~ DIY DTS Decoder
Completed designs ~ Itsy Bitsy TPA6120 Amp ~ MiniPow Bipolar Supply ~ MiniVol Volume Control
  #38 (permalink)
Old 08-08-2008, 11:50 PM
rds's Avatar
rds rds is offline
Default
Thanks error401, I went back I figured this out. Now it seems the issue is that I need to jumper rsvj and rsv as well as rscg and rsrg. Sound right?
__________________
_________
___________Last.fm
  #39 (permalink)
Old 08-09-2008, 12:05 AM
error401's Avatar
1000+ Head-Fi'er
Default
Yes. RSV and RSRG are the sense network input and ground respectively. The Jung design allows remote sensing, so if you wanted to you could connect RSV to the output at the load, and RSRG to the ground at the load. This lets the regulator compensate for lead impedance and so on. Jumpering them just connects the sense network directly at the regulator, as with most regulators you're probably familiar with.
Note: I'm going by the schematic here, I don't have one of these particular boards/designs built up.
__________________
  #40 (permalink)
Old 08-09-2008, 01:37 AM
n_maher's Avatar
Moderator
Default
Sure sounds right to me and looks to be how I've got mine configured.
__________________
-Head-Fi Feedback-
d-_-b
  #41 (permalink)
Old 08-09-2008, 01:41 AM
rds's Avatar
rds rds is offline
Default
Ok, thanks guys. I'll jumper those points. If you don't see me around again, then you know this is in fact not the right way to do it.
__________________
_________
___________Last.fm
  #42 (permalink)
Old 08-09-2008, 03:00 AM
n_maher's Avatar
Moderator
Default
If you're worried I'll pull mine tomorrow and photograph it for you. I can't see the jumpers on the bottom so I can't confirm 100% for you.
__________________
-Head-Fi Feedback-
d-_-b
  #43 (permalink)
Old 08-09-2008, 07:58 AM
rds's Avatar
rds rds is offline
Default
Thanks Nate - everything seems good.
But if you do confirm that your jumpers are the same I'd appreciate it.
Also, another wish list board change is making Vout a larger diameter.
__________________
_________
___________Last.fm
  #44 (permalink)
Old 08-10-2008, 01:10 AM
kipman725's Avatar
500+ Head-Fi'er
Default
I found your previous collection of articles on the super regulator and notes quite interesting tangent. How does it compare with high end lab supplies etc for its noise?
*is it at the point where to further reduce supply noise would be running up against physical limits such as Johnson noise?
__________________
sound blaster 24bit> PE Congress amp > HD650's
Cmoy(long ago), Follower + Flasher
  #45 (permalink)
Old 08-10-2008, 04:52 AM
tangent's Avatar
Contributor
Top Mall-Fi poster.
The "T" in META42.
Member of the Trade
Default
If we believe my 0.007 mV measurement, that's about 22 nV/rt.Hz over the measurement bandwidth of an LNMP. That's about equivalent to a 30K resistor. Pretty decent, considering how many parts are in the regulator.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tangent STEPS Power Supply Built by Rockhopper Audio chesebert Cables, Speakers, Tweaks, Accessories For Sale / Trade 3 07-10-2007 06:53 PM
breadboarding a Tangent Cmoy, Power balance problems chuck94022 DIY (Do-It-Yourself) Discussions 10 09-12-2005 02:20 AM
Tangent Easy Power Supply 00940 DIY (Do-It-Yourself) Discussions 14 01-05-2004 02:52 PM
Jung multiloop amp...power supply notes stereth DIY (Do-It-Yourself) Discussions 3 06-05-2003 06:48 PM
What determines a good power supply vs. a great power supply? RockysDad DIY (Do-It-Yourself) Discussions 8 05-22-2003 03:18 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
