Head-Fi: Covering Headphones, Earphones and Portable Audio
Support Head-Fi by starting your Amazon.com shopping by clicking here
Follow headfi on Twitter!
Follow Rocky Mountain Audiofest (RMAF) on Twitter!
Head-Fi Is Sponsored By:
Featured
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
Can Jam '09
(2009 International
Head-Fi Meet)
Impressions,
Reviews, Photos
Can Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss 1, 2, 3
dallan 1, 2, 3, 4
santacore 1, 2
nhat_thanh 1, 2
vpivinylspinner 1, 2, 3
amb 1
augustwest 1
eaglejo 1
johnsonad 1
shellylh 1
Jon L 1, 2, 3, 4
Germancub 1
zippy2001 1
IPodPJ 1
bhd812 1
Edwood 1, 2
abellaw 1, 2
minidiscs 1
atothex 1
HighLife 1
achristilaw 1
SiBurning 1, 2, 3, 4
SiBurning 5, 6, 7
LFF 1
Iron_Dreamer 1
doping panda 1
morphsci 1
ironbut 1
shaizada 1
jasper994 1, 2
jp11801 1
Uncle Erik 1
drubrew 1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Featured
Head-Fi's Sponsors
Featured
  #1471 (permalink)
Old 02-11-2008, 03:49 AM
kmel's Avatar
Head-Fi'er
Default
Originally Posted by aural1ty View Post
Somewhere back in the thread is was mentioned that high temp could be a sign of oscillating which I guess is true, but I don't think that's the case with the Zero and these opamps, they seem to work perfectly and I think it's just the huge power consumption difference. Looking at these numbers I understand the other seemed really hot after using the LT1057:
Supply Current Per Amplifier:
LT1057: 1.7mA typ - 2.8mA max
LT1361: 4.0mA typ - 5.0mA max
LT1469: 4.1mA typ - 5.2mA max
LT1364: 6.3mA typ - 7.5mA max
IMO the supply current is used even the opamp isn't amplify anything. I don't think that is the only cause of the high temperature.
I found following statement on physicsforums:
The only thing that will make an opamp hot is if its output current spec is exceeded, which you're not going to do when you pin the output open circuit one way or the other.
Let's take a look at the current output:
OPA2604: 35mA typ (standard Zero type)
LT1057: ???
LT1361: 34mA typ
LT1364: 60mA typ
LT1469: 22mA typ
If the Zero takes more than 22mA the LT1469 is running hot.
  #1472 (permalink)
Old 02-11-2008, 04:36 AM
Penchum's Avatar
Default
LT1057: ???
LT1361: 34mA typ
LT1364: 60mA typ
LT1469: 22mA typ
I'm following you here, but why would the LT1364 get even hotter? Or was the LT1469 hotter than the LT1364? Anyone?
Also, those are typical ratings. The maximum ratings require math beyond my capabilities and direct measurements from the Zero.
Anyone with a Zero, a good volt meter and math skills want to take a crack at it?
  #1473 (permalink)
Old 02-11-2008, 04:43 AM
edguetzow's Avatar
100+ Head-Fi'er
Default
LT1057: ???
LT1361: 34mA typ
LT1364: 60mA typ
LT1469: 22mA typ
I seem to recall that the 1364 ran very hot also. At 60mA it should not have begun heating up as compared to the stock OPA2604.
Seemed like it was just as hot as the 1469 but I am judging strictly by touch.
__________________
Go ahead, follow that "Yellow Brick Road"... 'cause no matter where you go there you are.
Foobar2K (KS/FLAC)-> AV-710 (coax)-> COMPASS Dac/Amp (Earth HDAM in DAC)-> Gilmore Lite/DPS-> Senn HD650
Portable: Cowon D2 > CrossRoads MylarOne Ruby x3i
  #1474 (permalink)
Old 02-11-2008, 05:15 AM
Penchum's Avatar
Default
I think you are right. I honestly hadn't given it much thought, beyond "that's hot". What is bothering me the most, is that I've been using one of my Zero's with the LT1364 in the DAC for a very long time now. I wonder if we should be worried or not.
  #1475 (permalink)
Old 02-11-2008, 05:20 AM
Penchum's Avatar
Default
I've also been using the LT1364 in my MK1 portable, with outstanding results! I really believe it is out performing the majority of portable amps on the market! Go figure!
  #1476 (permalink)
Old 02-11-2008, 07:56 AM
Henmyr's Avatar
1000+ Head-Fi'er
Default
Please do! I really enjoyed reading about your earlier opamp tests so I've been looking forward to your impressions of using the LT1469 in the DAC! I remember you wrote it was maybe the next one in line for trying.. Well, the LT1469 seems pretty hot for DAC duty so I say let it do it's thing!
I hit the wall right after the LME49720 test, and only heard the imperfections in the op-amps, the small colorations. I have taken a small break to get back on enjoying the music again as well as the zero. I will do the LT1469 test soon I think however. Have ordered two OPA627AP also to use as dac.
I'm using LT1469 in the dac now with LME49720 in the amp, and it is a good combination, as was LME49720(dac) + LT1469(amp).
__________________
_____________________________________________
H X-fi XtremeMusic -> ASIO -> Optical -> Zero dac (OPA-Earth) -> Zero internal amp -> RS1 "brown headband" / HD600 '02 / K501 .v1 / HF-2
P Cowon D2 - Head-Direct RE0
Other Fiio portable amp / Playstation SCHP-1002
Gone: DT990 '05 32ohm, HD650 with Oehlbach cable / Meier Corda Headfive / MS2i / DT880 '05 250ohm / RS1 "buttonless" '08 / LD MKIII / Audio-Technica ATH-AD2000
Spotify
  #1477 (permalink)
Old 02-11-2008, 10:08 AM
Head-Fi'er
Default
Hi Henmyr,
i've just seen that you're using this unit as amp too, with a Beyer DT-990, a headphone i know pretty well.
Can you tell me how does it sounds, compared to the Meyer dedicated amp?
Thanks in advance
  #1478 (permalink)
Old 02-11-2008, 01:52 PM
Henmyr's Avatar
1000+ Head-Fi'er
Default
Originally Posted by strologu View Post
Hi Henmyr,
Thanks in advance
They are very similar. At first, when the zero was new, it was very clear and sharp, much more clear than H5, but now after burn-in it's more mellow than before, and approching the H5 more and more.
With LME49720 (same as LM4562) (dac) + LT1469 (amp) the tonality is also very similar to H5, although the zero is just slightly very slightly more clear.
I have a hard time comparing the two (especially with dt990, as they have a very significant signature), but I would say that they are about equals.
The soundstage might be slightly larger than the H5, depends on what Op-amps are in.
The H5 has a very natural sound and good timber, something which the zero is just slightly slightly very slightly worse than H5 (this might be corrected with the right op-amp combination).
Overall, I have a very hard time to declare a winner during my short test.
There might be a very good op-amp combination for zero with dt990 which puts it significantly ahead, but I haven't found that for dt990 yet (and maybe never will, as I'm getting closer and closer to selling them).
This was tested with the DT990. With dt880 and ms2i, I think (must listen more) that I prefer the zero.
I hope that the zero will clear up with more burn-in, because I liked the clear sound it had in the beginning very much. I'm hoping OPA627 will bring some air also.
__________________
Spotify
  #1479 (permalink)
Old 02-11-2008, 02:32 PM
mrarroyo's Avatar
Default
Has anyone compared this Zero Dac w/ an Oritek modded Zhaolu? Thanks.
__________________
Miguel
Feedback at: http://www.head-fi.org/forums/f12/mrarroyo-139426/
  #1480 (permalink)
Old 02-11-2008, 02:56 PM
Head-Fi'er
Default
Hi Henmyr,
thanks a lot for your answer. So also the built-in amp is a little-killer one
I'm gonna buy a unit with OPA627 on DAC, but i'm really confused about which opamp for amp section, do you have any suggestion?
My phones are the Sony mdr-7506, that are a bit brilliant..
Thanks in advance
  #1481 (permalink)
Old 02-11-2008, 03:09 PM
Head-Fi'er
Location: The land of Leonardo Da Vinci, Galileo, Columbus, Antonio Meucci, Guglielmo Marconi and Enrico Fermi
Default
I wonder how many gullible people would be willing to pay additional $700 for such negligible mods compared to the original Zhaolu, it costs 7 times more
Get a life (and a Zero, of course...)
  #1482 (permalink)
Old 02-11-2008, 03:34 PM
Henmyr's Avatar
1000+ Head-Fi'er
Default
Hi Henmyr,
Thanks in advance
The op-amps in the amp are very dependent on the op-amp in the dac, so I can't know at this moment which op-amp will be best with OPA627 in the dac. I find the LT1469 and LME49720 (same as LM4652) to be the best overall so far for the amp with dt880/ms2i/dt990.
EDIT: Do not neglect the stock op-amp combination, as I find it to very enjoyable with every headphone.
__________________
Spotify
  #1483 (permalink)
Old 02-11-2008, 04:47 PM
Pete7's Avatar
Send a message via MSN to Pete7 Send a message via Yahoo to Pete7
Default
How about just an unmodded Zhaolu?
__________________
Portable: Westone ES2/ Yuin PK2> iBasso D3/ Graham Slee Voyager> ALO Cryo SXC 22 g dock> Ipod 120gb Classic
Home: Grado HF-2/ Allesandro MS2i/ Senn HD580 w/Cardas Cable> Little Dot Mark V/Firestone Little Country> Soloz Audio 16 Conductor Master Reference Silver> Sony DVP-S9000ES
Feedback: http://www.head-fi.org/forums/f12/pete7-141567/
  #1484 (permalink)
Old 02-11-2008, 04:51 PM
Pete7's Avatar
Default
Haven't been around very long,eh? The last time I checked Ori sent out a brand new modded unit for close to $450. Discrete output isn't what you'd call a "negligible" mod, like say swapping out an op-amp.
__________________
  #1485 (permalink)
Old 02-11-2008, 05:02 PM
Head-Fi'er
Default
Hi Henmyr,
i've just e-mailed Lawrence to ask which one he recommend with the OPA627 in the dac..he suggest me another opa627 in the amp section..but i'm not sure i've understand well..another OPA627 in the amp?? Is it possible?
It's another interesting point of view
Just one more question: when you tested the Meier h5 vs the Zero internal amp, did you used the stock op-amps?
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
