Head-Fi's Sponsors
(Premier Sponsors bolded) |
Can Jam '09
(2009
International
Head-Fi Meet)
Impressions,
Reviews, Photos |
Can
Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss
1,
2,
3
dallan
1,
2,
3,
4
santacore
1,
2
nhat_thanh
1, 2
vpivinylspinner
1,
2,
3
amb
1
augustwest
1
eaglejo
1
johnsonad
1
shellylh
1
Jon L
1,
2,
3,
4
Germancub
1
zippy2001
1
IPodPJ
1
bhd812
1
Edwood
1,
2
abellaw
1,
2
minidiscs
1
atothex
1
HighLife
1
achristilaw
1
SiBurning
1,
2,
3,
4
SiBurning
5,
6,
7
LFF
1
Iron_Dreamer
1
doping panda
1
morphsci
1
ironbut
1
shaizada
1
jasper994
1,
2
jp11801
1
Uncle Erik
1
drubrew
1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook |
Head-Fi's Sponsors
| Headphone Amps (full-size) Discussion of desktop headphone amps. |
02-07-2008, 02:57 AM
Originally Posted by bada bing
I've been doing some rolling in my Zero.
One warning I have is that in my Zero, the LT1364 is exhibiting some signs of hi- freq oscillation. When used in the DAC section, LT1364 (two different chips) ran hot and also caused the LT1469's I had installed in the Amp section to run hot. The sound was okay, a touch too bright and the audible volume was somewhat diminished. It may be an issue with my board or it may be that LT1364 is borderline unstable in the Zero. Other than the issue with LT1364's my zero is impressing me.
Just a heads up for others rolling their zeros. High performance op amps can have issues in some amps and not others of the same version - like the old Pint portable and 8697's
Wow! That's a first! Question? Is your Zero broke in yet, or did you start swapping right away?
Thanks!
02-07-2008, 04:09 AM
100+ Head-Fi'er
It has about 30 hours on it.
The telltale that something is amiss with the LT1364 in the DAC is not that the LT1364 runs hot, but that it makes the LT1469's in the amp section run hot at equivalent volume level. When the 1364's (I tried both I had) were replaced with any other option, the LT1469's run much cooler. The LT1364 is throwing some inaudible oscillations downstream and loading the amp board. The sound isn't greatly hampered, although the combination isn't "great".
I don't necessarily think this is a problem for all Zero's, but mine does not like the LT1364. I don't believe there is any real defect in my unit, it sounds fine (actually better than fine) and I spent 15 minutes with a DMM checking everything that was obvious. Probably just a bit touchier than most Zero's about ultra fast opamps in the DAC section. I'm liking OPA627 in the DAC and LT1469 in the amp for now.
If you check the data sheet, the LT1364 is about as fast an opamp as is commonly available - 1000v/uS and probably is a bit touchy even though it is listed as unity gain stable.
If anyone else uses the 1364 in the DAC and 1469's in the amp, check the chip temps. If the 1469's are pretty warm, drop something besides a 1364 in the DAC and see if the 1469's don't cool off some without a change in volume. That is a give away there is some inaudible ultrasonics in the signal heating up the amp section.
02-07-2008, 04:21 AM
Ow, I agree with you. Something is up. But, your Zero isn't burned in yet either. I'm not sure how much or if at all, this could be playing into the audible part, not the heat part. I forget now what the temp was exactly, but the LT1469 was tested up to like 200c without artifacts or anomalies. I'm just concerned that your Zero hasn't had time to mature yet, that's all.
Maybe if you ran a different Opamp for now, then came back to it after 100hrs and see if the Zero gets along better with it, or not. I think it's worth a try.
02-07-2008, 05:19 AM
Hi I'm new to the thread, is there any published measurements on this DAC?
__________________
“I know I ask perfection of a quite imperfect world, and fool enough to think that’s what I’ll find.” – The Carpenters
Transport: ________________DC:
__Toshiba SD-3950____ -→ ____ Canare LV-77S ↘
Source : _ Transit : __ DC : ___ DAC : __ IC : _____________ Amp : __ Headphone :
__WinAmp ASIO → M-Audio Transit → Sys. Concept → Entech Number → Blue Jeans Cable → Little Dot II++ (v2) → Sennheiser HD650
_____________________________________ Premium Toslink Cruncher 203.2 _ Belden 1694A
FS: HeadRoom MAX amp with MAX DAC $2750 OBO
FS: Sennheiser HD650 + Cardas Upgrade Cable + HeadRoom Headphone Bag
02-07-2008, 05:27 AM
I've got one of mine under my MKIVse and the other under my MKV! They are almost exactly the same width and depth is almost the same as the MKIVse.
Very nice little units for sure! Let me know if you need more info!
02-07-2008, 05:39 AM
100+ Head-Fi'er
When I tested the 1364 in the DAC on my Zero, it ran hot. I only tested the DAC section and left the stock opamps in the headphone section. I had broken in my Zero for over 200 hours before rolling the DAC chip (1364). I did not like it and settled on the 1469 as DAC for now with the 1361's in the headphone section. This I DO like and I am breaking the 1469 in for awhile before trying another chip.
__________________
Go ahead, follow that "Yellow Brick Road"... 'cause no matter where you go there you are.
Foobar2K (KS/FLAC)-> AV-710 (coax)-> COMPASS Dac/Amp (Earth HDAM in DAC)-> Gilmore Lite/DPS-> Senn HD650
Portable: Cowon D2 > CrossRoads MylarOne Ruby x3i
02-07-2008, 05:43 AM
Yep. I think that was a great combo too.  It has really good low end, right?
02-07-2008, 05:49 AM
100+ Head-Fi'er
Yeah! I really like the bass in this combo. For me, it is tight and well defined. I can hear the bass guitar notes cleaner and clearer in relation to the drums in rock music.
Can still hear the pick on the strings as well. Good residual on notes and it doesn't muddy up the mids for me. Still not "perfect" but very satisfying!
Good night!
__________________
02-07-2008, 09:42 AM
100+ Head-Fi'er
I did have briefly my Zero under my LD and I think that may have cause the OPA627 to broke and DY2000 to malfunction. MKIV SE makes a lot of heat throughout the case and it warms the already warm Zero even more. I have to make some kind of rack for them to allow the air circulate freely.
__________________
X-Fi --> Zhaolu 2.5A (Zapfiltered) --> Audioquest King Cobra XLR --> Audio-gd C2C (Discrete Dual Mono SS) --> Denon AH-MD5000 (JMoney pads) + Grado HF-2 #419
Owned: Corda Headfive #483, Heed Canamp, Darkvoice Figaro, Zero DAC, K701, SA5000, SR-225, Yamaha YH-1 "Chocolate Donut", K500, K340, Little Dot I+, MKIV SE, Grado RS-2, RS-1, Alessandro MS-Pro
My Feedback
02-07-2008, 12:44 PM
I'll be darned! I'll check that out today with my temp gun. I don't want to have my own "meltdown" here in my home office!
02-07-2008, 04:49 PM
100+ Head-Fi'er
i upgraded my soundcard finally
the bass has never been deeper, and never this clear, im not sure if it's placebo but it seems now that the Zero is sounding better than ever.
gift and a curse though, my mo3s sound crap now all of a sudden, but my flacs are seem clearer. heh.
opamp rolling next!!
__________________
H Asus Xonar D2 > ASIO > Darkvoice 332 > Darth Beyer V3 Closed (Ebony/BlackGold) / Sennheiser HD650
P Nokia N95-2 > Shure SE530
02-07-2008, 05:32 PM
1000+ Head-Fi'er
What is the most natural, neutral, cleanest, airiest, most uncolored, good bass presence and texture, not overpowering treble, most transparent and purest op-amp combination for the zero you've(anyone) found yet? Natural and airy and clean are key-words.
I just can't seem to get the sound to be all that. My previous best combination was LME49720(dac) + LT1469(amp), but I sensed a very slight warm coloration in the mids and a small flowing effect which devoured a lot of the air (the flowing effect(made the music "flow" effortless) was very pleasant, but the slight air lost made it very hard to breath), so in the end I couldn't stand it and had to change.
The stock does a lot of things right, but I want a little bit more detail, but the coloration, or UNcoloration is very good, as is the air.
My favorite (for the moment) favorite combination is LT1469(dac)+LME49720(amp) and it sounds very good, but I think I hear the slight midrange coloration of the LT1469 shine through.
It might be that in the end, beyers, grados/alessandros, or me in general just don't love the LT sound, so I might have to turn to OPA627 or similar.
Any suggestions?
__________________
_____________________________________________
H X-fi XtremeMusic -> ASIO -> Optical -> Zero dac (OPA-Earth) -> Zero internal amp -> RS1 "brown headband" / HD600 '02 / K501 .v1 / HF-2
P Cowon D2 - Head-Direct RE0
Other Fiio portable amp / Playstation SCHP-1002
Gone: DT990 '05 32ohm, HD650 with Oehlbach cable / Meier Corda Headfive / MS2i / DT880 '05 250ohm / RS1 "buttonless" '08 / LD MKIII / Audio-Technica ATH-AD2000
Spotify
02-07-2008, 06:13 PM
100+ Head-Fi'er
can i use LT1469 in dac and also in headphone amp? three lt1469 in the zero.
__________________
Phones: HD650, HD485
Source: M-Audio 192, Zero Dac, Constantine+
Amp: DV332 (CV4010, Ulys 6S19P-V
Gone: HD595, DV336i
02-07-2008, 07:42 PM
1000+ Head-Fi'er
I use LT1469 in my dac for the moment, but it is really really hot. If I touch it with my finger I will burn myself, thats how hot it is. Is that bad? I have the LT1469IN8 so it should withstand higher temperature than LT1469CN8 but still.
__________________
Spotify
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
