Head-Fi's Sponsors
(Premier Sponsors bolded) |
Can Jam '09
(2009
International
Head-Fi Meet)
Impressions,
Reviews, Photos |
Can
Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss
1,
2,
3
dallan
1,
2,
3,
4
santacore
1,
2
nhat_thanh
1, 2
vpivinylspinner
1,
2,
3
amb
1
augustwest
1
eaglejo
1
johnsonad
1
shellylh
1
Jon L
1,
2,
3,
4
Germancub
1
zippy2001
1
IPodPJ
1
bhd812
1
Edwood
1,
2
abellaw
1,
2
minidiscs
1
atothex
1
HighLife
1
achristilaw
1
SiBurning
1,
2,
3,
4
SiBurning
5,
6,
7
LFF
1
Iron_Dreamer
1
doping panda
1
morphsci
1
ironbut
1
shaizada
1
jasper994
1,
2
jp11801
1
Uncle Erik
1
drubrew
1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook |
Head-Fi's Sponsors
| Headphone Amps (full-size) Discussion of desktop headphone amps. |
01-28-2008, 08:25 AM
Junior Head-Fi'er
<removed>
01-28-2008, 10:52 AM
Head-Fi'er
Just another question, how do you change the opamps? Does it involve advance stuff like soldering or is it just more like changing RAM on a PC motherboard plug n' play?
01-28-2008, 11:02 AM
Junior Head-Fi'er
<removed>
01-28-2008, 12:40 PM
Originally Posted by charley phogg
Yes, thanks for the explanation. I guess I have always assumed that since it had a DAC on board the amp would use it.... we all know what assuming gets you  .
Ya, my favorite is ASSuming.
01-28-2008, 12:43 PM
Originally Posted by magnetiq
quick question, can you use the RCAs to connect to the source and still use it as a headphone amp?
Nope, sorry. The RCA's are DAC output only. There is no by-pass. So this makes the Zero a "digital only" on inputs, which fits the majority of user's needs. Have a good one!
01-28-2008, 12:47 PM
snip
The Opamps are in sockets, so you pull one out, push one in. Very easy.
01-28-2008, 01:03 PM
Thank you for fixing this! and lets get on talking about the Zero's!
01-28-2008, 01:06 PM
Head-Fi'er
Oh... :/
Damnit I should payed more attention to your extensive talk about the opamps, didn't know it was that easy!!
Btw is the opamps used in the DAC, amplifying or pre-amp process? Man I truly an a noob at this still
01-28-2008, 01:10 PM
Originally Posted by ptiJean
<removed>
Thanks very much ptiJean! PM me and let me try to help with your situation, Ok? Thanks!!
01-28-2008, 01:13 PM
Head-Fi'er
You're a nice guy, I respect that!
Oh... :/
Actually, I'm not sure which "term" is used, because some of them have a pretty high output. I'm going to guess pre-amp process. Can someone correct me, if needed?
01-28-2008, 01:32 PM
Thanks! I PM'd you too.
01-28-2008, 02:53 PM
Head-Fi'er
Oh forgot to ask how many opamp slots are there? Just two right? Otherwise the amount of combinations would explode exponentially, that wouldn't be nice =/
01-28-2008, 03:09 PM
There is one Opamp for the DAC section. There are two Opamps in the Headphone board, L&R. We discovered some time ago that changing the DAC Opamp will change the sound of the DAC output and the headphone output.
If you change Opamps only in the headphone board, it will change only the output at the headphone jack.
So, when I was trying different combinations, I was indeed trying different combinations. That chart represents the better part of a long day! But, I think it will help some folks.
01-28-2008, 03:20 PM
Head-Fi'er
Ok. But since your chart shows combinations of two opamps at once, one DAC one Amp, you must have held one constant on the headphone board if it had two slots?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
