Head-Fi: Covering Headphones, Earphones and Portable Audio
Support Head-Fi by starting your Amazon.com shopping by clicking here
Follow headfi on Twitter!
Follow Rocky Mountain Audiofest (RMAF) on Twitter!
Head-Fi Is Sponsored By:
Featured
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
Can Jam '09
(2009 International
Head-Fi Meet)
Impressions,
Reviews, Photos
Can Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss 1, 2, 3
dallan 1, 2, 3, 4
santacore 1, 2
nhat_thanh 1, 2
vpivinylspinner 1, 2, 3
amb 1
augustwest 1
eaglejo 1
johnsonad 1
shellylh 1
Jon L 1, 2, 3, 4
Germancub 1
zippy2001 1
IPodPJ 1
bhd812 1
Edwood 1, 2
abellaw 1, 2
minidiscs 1
atothex 1
HighLife 1
achristilaw 1
SiBurning 1, 2, 3, 4
SiBurning 5, 6, 7
LFF 1
Iron_Dreamer 1
doping panda 1
morphsci 1
ironbut 1
shaizada 1
jasper994 1, 2
jp11801 1
Uncle Erik 1
drubrew 1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Featured
Head-Fi's Sponsors
Featured
  #1066 (permalink)
Old 01-25-2008, 01:46 AM
100+ Head-Fi'er
Default
Originally Posted by Penchum View Post
Ow Poop! My adapters are as wide as deep. They don't fit! Guess I'll have to find a couple like yours then! Got a link or something for all of us? Thanks man!
You can buy Single-to-dual Op-AMP Adapter - DIP version from (browndog) cimarrontechnology.com Single-to-dual Op-AMP Adapter - DIP version (p/n 021001) - 021001
Then solder ic socket to the adapter yourself, ic socket you can buy from radioshack.
Parts you need are 2 x Single-to-dual Op-AMP Adapter - DIP version and 4 x IC socket DIP.
If you are too lazy to do all this i believe "HiFlight" a member on this forum sells them already made for about $15 pm him for exact price.
Cheers
  #1067 (permalink)
Old 01-25-2008, 03:02 AM
Penchum's Avatar
Default
Cheers
Thanks! It just didn't occur to me that more than one size adapter was out there. If you try the AD797s in the headphone amp, keep an eye on them for the first few minutes and make sure they don't heat way up too quickly, or if the highs sound funky. They didn't work well in the DAC at all. It sure would be nice if they did work in the headphone amp! I seem to have enough (with different adapters) to pull it off later.
  #1068 (permalink)
Old 01-25-2008, 08:48 AM
Head-Fi'er
Default
Does the amp require 220V to operate? I notice it says that on the back. It comes with a US power plug, so I'm assuming they are made to operate at 120V.
  #1069 (permalink)
Old 01-25-2008, 10:47 AM
100+ Head-Fi'er
Default
Mine came with the appropriate US plug but its also switchable from 115 or220 on the back.
  #1070 (permalink)
Old 01-25-2008, 12:20 PM
fault151's Avatar
1000+ Head-Fi'er
Default
There is heaps of space in there unless your version is different to my. I took a few photos with my only 2 x AD797 on browndog.
How does it sound with the ad797's? Do you have them in he dac as you only showed one set installed in the pics?.
__________________
My Audio/design blog
  #1071 (permalink)
Old 01-25-2008, 03:47 PM
100+ Head-Fi'er
Default
Yeah i only got one set so i couldnt try it in the headphone board i just put it in to take the pics to show there is room inside.
I have not try it in the DAC i believe Penchum has, i think he said it didnt work to well.
  #1072 (permalink)
Old 01-25-2008, 03:50 PM
100+ Head-Fi'er
Default
Hey Penchum let us know on how AD797s sound in the headphone board when you get a chance with the new adapters.
  #1073 (permalink)
Old 01-25-2008, 04:40 PM
fault151's Avatar
1000+ Head-Fi'er
Default
Yeh i wanted to try the opa627 in the headphone amp, but since i discovered the set up i'm using, i'm not going to bother.
__________________
  #1074 (permalink)
Old 01-25-2008, 07:52 PM
Head-Fi'er
Default
Well darn. Mine doesn't.
I suppose I better go find a step up transformer.
  #1075 (permalink)
Old 01-25-2008, 08:37 PM
Penchum's Avatar
Default
Can you take a pic of the back end and post it for us too see?
Thanks!
  #1076 (permalink)
Old 01-25-2008, 08:38 PM
Penchum's Avatar
Default
I forgot, or missed something. What combination did you finally go with?
Thanks!
  #1077 (permalink)
Old 01-25-2008, 08:43 PM
Penchum's Avatar
Default
On the previous page, I put a pic of the adapters I have for you too see. When I tried the AD797s in the DAC, the highs were really strange. Like they were uncontrolled or something. I liked everything else greatly, but those highs were so not proper. Then I was told and I looked it up, that they weren't unity gain stable, and this was the cause of the strange highs. They also got very hot. So I took them out of the testing loop.
  #1078 (permalink)
Old 01-25-2008, 09:23 PM
Head-Fi'er
Default
  #1079 (permalink)
Old 01-25-2008, 10:01 PM
Penchum's Avatar
Default
If I'm not mistaken (and I may be) doesn't that mean 220 is the maximum voltage it can take? Shouldn't this work with his 110V? Someone?
  #1080 (permalink)
Old 01-26-2008, 01:59 AM
100+ Head-Fi'er
Default
To me, thats saying its strictly a european version. U.S. you should see 110 or 120 at 60hz. Usually when they are switchable it will list both ratings. I would check into this further before trying a step-up transformer, as I don't think the transformer will change the frequency, I could be wrong.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
