Head-Fi's Sponsors
(Premier Sponsors bolded) |
Can Jam '09
(2009
International
Head-Fi Meet)
Impressions,
Reviews, Photos |
Can
Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss
1,
2,
3
dallan
1,
2,
3,
4
santacore
1,
2
nhat_thanh
1, 2
vpivinylspinner
1,
2,
3
amb
1
augustwest
1
eaglejo
1
johnsonad
1
shellylh
1
Jon L
1,
2,
3,
4
Germancub
1
zippy2001
1
IPodPJ
1
bhd812
1
Edwood
1,
2
abellaw
1,
2
minidiscs
1
atothex
1
HighLife
1
achristilaw
1
SiBurning
1,
2,
3,
4
SiBurning
5,
6,
7
LFF
1
Iron_Dreamer
1
doping panda
1
morphsci
1
ironbut
1
shaizada
1
jasper994
1,
2
jp11801
1
Uncle Erik
1
drubrew
1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook |
Head-Fi's Sponsors
| Headphone Amps (full-size) Discussion of desktop headphone amps. |
01-21-2008, 10:42 PM
1000+ Head-Fi'er
Originally Posted by Penchum
I think my #2 has the same thing. I just haven't got around to cleaning it yet. A little Deoxit and it will be over with.  The heavier knob should have no effect on the pot. It sure does make it smoother to operate.
Whats Deoxit? Is it the equivalent to WD40 over here in the UK? Like lubricant for cars? It sounds dead gritty and it annoys me!
01-21-2008, 10:46 PM
It's like a tuner cleaner, with just a tiny bit of lube in it. Most contact cleaners will work if they are friendly to plastic (make sure they are first).
01-21-2008, 10:49 PM
1000+ Head-Fi'er
Cheers i will do. Has it got a cheap vol pot in the zero? Thats probably why it does it. At least mine isn't the only one that does.
01-21-2008, 11:02 PM
I hadn't really got a close look at it. I expect it is just a standard pot, which will clean up nicely.
01-22-2008, 09:55 AM
1000+ Head-Fi'er
I need some clarifications on op-amps.
What is the difference between CN8, IN8, ACN8 and which one is the best to use?
For exemple: LT1469, which one of LT1469CN8, LT1469IN8#PBF and LT1469CN8#PBF should one use?
__________________
_____________________________________________
H X-fi XtremeMusic -> ASIO -> Optical -> Gamma2 / Zero dac (OPA-Earth) -> CK2III / Zero internal amp -> RS1 "brown headband" / HD600 '02 / K501 .v1 / HF-2
P Cowon D2 - Head-Direct RE0
Other Fiio portable amp / Playstation SCHP-1002
Gone: DT990 '05 32ohm, HD650 with Oehlbach cable / Meier Corda Headfive / MS2i / DT880 '05 250ohm / RS1 "buttonless" '08 / LD MKIII / Audio-Technica ATH-AD2000
Spotify
01-22-2008, 09:59 AM
1000+ Head-Fi'er
Originally Posted by Andreas_D
Mine is on the way too...I also ordered some samples from LT( 1 x LT1364, 2 x LT1469, 2 x LT1361) I hope they will send it to me...I'm very curious how will sound my K601 on Zero, I'm already impressed by their sq even unamplified...
I want to ask you something about burn in: is there a time limit for continuously burning in?
LE: I have another question: what differences are between:
LT1361CN8
LT1361CN8#PBF
LT1361CS8
LT1361CS8#PBF
Ah missed your post. Well CS8 is SOIC, so I do not think it's possible to use it without some kind of solder mod.
__________________
Spotify
01-22-2008, 01:25 PM
Originally Posted by Buster K
It's just a standard, non-sealed pot. It may very well be Alps.
Thanks BK, I hadn't had time to pop the top the last couple of days. It should clean up nicely then.  I'm glad you like the Zero, it sure had turned out to be the "bang for buck" winner!
01-22-2008, 03:41 PM
100+ Head-Fi'er
Originally Posted by king756
Did you order from Lawence?
I placed my order on 15 Jan so you should of heard something by now.
Just got back word from Lawrence including a beautiful sight, the tracking number. Now . . . more waiting.
__________________
He who loves head-fi will not be satisfied with head-fi;
Nor he who loves its crossfeed, with increase.
This too is folly.
Feedback | last.fm
01-22-2008, 05:23 PM
500+ Head-Fi'er
Yee-hah...I woke up to an email from him with a tracking # this morning too! I'm impressed considering that I didn't order mine until Friday (1/18) afternoon! Much better than I expected!
__________________
Portable: Rio Karma/ Creative ZVM 30gb & 60gb slim/ Sansa Fuze & Clip --> HeadStage Lyrix Pro --> Shure e4c/ hearyourself Alien C3
Desktop: Zero DAC --> X-Can v8/ SRM-313/ LD I+ --> D5000/ SR-404
Head-Fi Feedback
01-22-2008, 06:34 PM
Excellent! Don't forget to put in your LT requests now, if you had planned too.
01-22-2008, 06:38 PM
Head-Fi'er
Question regarding opamps..
Have received a pair of DY2000, its the metal version including two sockets
q: which foot/pin are supposed to go where...
Have also received a pair of LT1364CN8 (in an hopeless package.. meaning an "letter" with no protection = all the "pins" a bent in all directions..)
But I guess they can still be used.
01-22-2008, 07:28 PM
1000+ Head-Fi'er
Look at how the original op amps are, pull one out and replace it with the new one in ths same direction. There is a little white dot on most of them that defines the angle it should be. Just put your in the same way. Hope that helps.
Yeh you should be able to bend the pins back in, just be gentle they may snap off and also you have to be careful not to short them out.
01-22-2008, 11:43 PM
Banned
My Zero is apparently dented in the top right corner of the front aluminium panel. It could've been bad postal handling, even if the outer package doesn't show signs of heavy abuse.  Has someone noticed anything similar on theirs?
01-23-2008, 12:33 AM
100+ Head-Fi'er
I got an email from Lawrence with tracking number this morning as well. Yay!
01-23-2008, 01:58 AM
On my first one, there was additional sanding or burr removal on the top right, but it wasn't anything distracting, so I just didn't think too much of it. If your's is bad, you should snap a pic and send it to Lawrence.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
