Head-Fi: Covering Headphones, Earphones and Portable Audio
Support Head-Fi by starting your Amazon.com shopping by clicking here
Follow headfi on Twitter!
Follow Rocky Mountain Audiofest (RMAF) on Twitter!
Head-Fi Is Sponsored By:
Featured
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
Can Jam '09
(2009 International
Head-Fi Meet)
Impressions,
Reviews, Photos
Can Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss 1, 2, 3
dallan 1, 2, 3, 4
santacore 1, 2
nhat_thanh 1, 2
vpivinylspinner 1, 2, 3
amb 1
augustwest 1
eaglejo 1
johnsonad 1
shellylh 1
Jon L 1, 2, 3, 4
Germancub 1
zippy2001 1
IPodPJ 1
bhd812 1
Edwood 1, 2
abellaw 1, 2
minidiscs 1
atothex 1
HighLife 1
achristilaw 1
SiBurning 1, 2, 3, 4
SiBurning 5, 6, 7
LFF 1
Iron_Dreamer 1
doping panda 1
morphsci 1
ironbut 1
shaizada 1
jasper994 1, 2
jp11801 1
Uncle Erik 1
drubrew 1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Featured
Head-Fi's Sponsors
Featured
  #9106 (permalink)
Old 11-10-2009, 01:01 AM
Pricklely Peete's Avatar
Default
Originally Posted by Currawong View Post
Does the Zero still default, when you switch it on, to non-pre-out mode, sending the full signal out? If so, I wouldn't recommend it as a pre-amp.
Good point Curra.
The best way to avoid such a thing would be to switch the Zero on first before powering anything else up, engage the preamp section making sure that the Zero's vol pot is at min setting and then adjust from there.
Peete.
__________________
Cans :HD650, AKG 240M (HD650 DIY cables SE and Balanced)
Desktop amps : LD MK III (6H30P-i DR's + DIY mods, Jaycar DIY kit amp (major DIY mods), 2 X Audio-gd Compass (test prototype,final version), Audio-gd C-2C W/ Stepped pot Upgrade, Audio-gd Phoenix SS balanced preamp/headamp.
Transports: Auzen Prelude PCI 7.1 SC/ASIO native driver using Media Monkey (all EAC ripped FLAC/Wav), Vanguard CDM12 Pro (BNC mod), HK HD720 (completely upgraded), Audio-gd CD7 Transport.
Sources: FrankenDAC DIY 24/192 dac (HDAMs/Teflon/PIO cap mod), Compass DAC, See Corp Vintage UK TT(Mission arm/Ortofon OM20S MM cart), Yaqin MS12B tube phono preamp, TEAC V530X Tape deck, Audio-gd Reference 1 DAC. C2C DIY pot mod http://www.head-fi.org/forums/f6/ste...1/#post5846722
  #9107 (permalink)
Old 11-10-2009, 01:03 AM
EluamousNailo's Avatar
Head-Fi'er
Default
With mine, when it's turned on it's in pre-out mode, but you have to manually turn on the pre-amp/headphone out. I guess since I have mine hooked up to a receiver it doesn't matter for me personally.
__________________
Behringer UCA202(just for USB) > Zero DAC > Little Dot MKIII > HD650
Feedback
  #9108 (permalink)
Old 11-10-2009, 01:06 AM
Qonmus's Avatar
100+ Head-Fi'er
Send a message via AIM to Qonmus
Default
I still don't understand why this would be an issue in my scenario -- Zero DAC --> pre-amp output straight to a pair of audioengines. Would this work, or would there be issues if I forget to change the DAC to pre-out before powering on my speakers?
  #9109 (permalink)
Old 11-12-2009, 10:23 AM
alex98uk's Avatar
Head-Fi'er
Default
Just bought one of these to use solely as a DAC to then go to my Little Dot MK III. I saw it was the newest '09 version, look forward to getting it
  #9110 (permalink)
Old 11-16-2009, 05:48 PM
Junior Head-Fi'er
Default
I need some help, i have the Zero DAC with the HDAM, LT1364, and upgraded volume pot from 2008, i didnt used for some time but i manage to buy a new motherboard for my pc and i have optical and coaxial on onboard sound, the problem is that i have sound only on the right side on my headphones, i tried the headphones directly to the card and they are working perfectly, i tried coaxial and optical connection to be sure is not the cables but still the same issue, i think my Zero DAC is broken and im noob, dont know anything about this, can you give me some advise, what can i try, im totally sure the problem is from Zero DAC because like i said i tried the headphones directly to the onboard card, i tried different cables, so the problem can be only from the Zero DAC.
  #9111 (permalink)
Old 11-16-2009, 06:01 PM
oatmeal769's Avatar
100+ Head-Fi'er
Default
I'd first check the 1/4" output jack inside. be sure it is solidly connected to the circuit board, and that the connections inside make good contact. Those jacks are pretty cheap.
__________________
For Sale : ZERO DAC with OPA-627 Op-Amps, and mods
FLAC > Foobar/WASAPI > Belden 1694A Coax > PS Audio/Cullen DL-III-mod 3 DAC > Zu Gede > Zana Deux #90 > Cardas > HD 600
Head-Fi Feedback eBay Feedback
  #9112 (permalink)
Old 11-16-2009, 06:41 PM
Junior Head-Fi'er
Default
1/4 jack is the problem, the biggest problem now is how i changed it?
  #9113 (permalink)
Old 11-16-2009, 08:33 PM
oatmeal769's Avatar
100+ Head-Fi'er
Default
Unfortunately, it isn't just a quick swap out of a switchcraft. You will need to desolder it carefully from the board, and replace it with the exact same type of input. Take it with you to the electronics store to be sure, most of those guys are pretty helpful (unless you go to Radio Shack, in which case don't listen to anything they say...).
it is probably just a simple 3 conductor TRS with a switching ground, but I haven't looked at it.
The good news is that the whole repair shouldn't cost more than about $3.50, assuming you have basic soldering tools.
__________________
  #9114 (permalink)
Old 11-16-2009, 08:37 PM
oatmeal769's Avatar
100+ Head-Fi'er
Default
double post
__________________
  #9115 (permalink)
Old 11-16-2009, 08:43 PM
crapback's Avatar
100+ Head-Fi'er
Default
I had a similar problem with my output jack. It actually had nothing to do with the solder connections. I would recommend trying some contact cleaner first before getting involved with swapping that thing. It has 8 tabs instead of pins and won't be much fun to replace. If it had a simple jack I would upgrade the thing but it's an annoying el cheapo.
I wasted about two hours thinking I screwed up my installation of a cheap attenuator because some oxidation on the jacks contacts were preventing right channel output. I even ordered the closest things I could find to replace the thing before I figured out the real problem. Luckily, they were only about $10 for 2 of them shipped.
__________________
Support your local donkey show.
  #9116 (permalink)
Old 11-16-2009, 08:54 PM
Junior Head-Fi'er
Default
The only problem im from Europe (Czech Republic), im thinking maybe LAWRENCE can send me a replacement part and i pay to him by paypal or something, ill try to send him a email.
  #9117 (permalink)
Old 11-16-2009, 08:55 PM
Junior Head-Fi'er
Default
Do you think i can find something similar online somewhere?
  #9118 (permalink)
Old 11-16-2009, 11:29 PM
crapback's Avatar
100+ Head-Fi'er
Default
This is the part I ordered. PC mount 1/4" jack Stereo 9 pin Fender amp 88-99 H507-A - eBay (item 180373875682 end time Nov-23-09 02:31:53 PST) It was not easy to find a replacement for the stock jack. I never did put one in though, as the contact cleaner took care of the problem. Try some of this stuff if you can first.
deoxit, great deals on Electronics, Musical Instruments on eBay!
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
