Head-Fi's Sponsors
(Premier Sponsors bolded) |
Can Jam '09
(2009
International
Head-Fi Meet)
Impressions,
Reviews, Photos |
Can
Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss
1,
2,
3
dallan
1,
2,
3,
4
santacore
1,
2
nhat_thanh
1, 2
vpivinylspinner
1,
2,
3
amb
1
augustwest
1
eaglejo
1
johnsonad
1
shellylh
1
Jon L
1,
2,
3,
4
Germancub
1
zippy2001
1
IPodPJ
1
bhd812
1
Edwood
1,
2
abellaw
1,
2
minidiscs
1
atothex
1
HighLife
1
achristilaw
1
SiBurning
1,
2,
3,
4
SiBurning
5,
6,
7
LFF
1
Iron_Dreamer
1
doping panda
1
morphsci
1
ironbut
1
shaizada
1
jasper994
1,
2
jp11801
1
Uncle Erik
1
drubrew
1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook |
Head-Fi's Sponsors
| Headphone Amps (full-size) Discussion of desktop headphone amps. |
03-31-2009, 10:24 AM
Junior Head-Fi'er
Thank you so much at all!!
03-31-2009, 11:12 AM
Originally Posted by les_garten
Typical Grado Hater Statement!
Lol, no. If you aren't getting the sound you like from your headphones, then buying different ones is the sensible thing to do.
__________________
"The trouble with most people is not what they don't know, but what they know for certain that isn't true." -- Mark Twain
04-05-2009, 12:55 AM
100+ Head-Fi'er
Hey, sorry I couldn't find an answer from searching, but, which OPA2604 is the correct one to use for the Zero? There are like 7 from this website
__________________
Feedback: Head-Fi||eBay
Gone but not forgotten: SR-60, A700, money in my wallet
Current: Xitel MD-Port > Zero DAC/Amp > AD700, DT770/80
04-05-2009, 01:01 AM
OPA2604 is the original opamp that the Zero comes with.
__________________
04-05-2009, 01:07 AM
100+ Head-Fi'er
Opps I meant OPA627.  Which one on that list is the correct one?
From a cursory search I gather the OPA627AP is the one with the legs that doesn't require soldering? Am I correct?
__________________
04-05-2009, 04:00 AM
Just purchased one of these babies to use with my Ultrasone Pro 900. Any particular op-amp combo I should use?
__________________
Cans/IEM:PL30, PL50, WM2, Westone 3, UE TF10pro, KSC75, iGrado, Ultrasone Proline 900, Stax SR-404
Portable Amplifiers:Home-made CMOYs, PD XM5, FiiO E3/E5 (Proto + Final)
Home Amplifiers: Whiplash Audio Pimeta, Zero DAC
Source: iRiver H332, FiiO S3, 8GB Clip, 4GB Fuze, 16GB Cowon D2, 4G 16GB Nano, 80GB 5.5G Video
Feedback: Head-Fi eBay
WTB: Entry-level Stax amplifier, Cheap Sansa Fuze LOD (V2)
04-05-2009, 06:51 AM
You need to put two on a browndog adaptor (see the FAQ in my sig). Some eBay sellers sell them already assembled, either using the SOIC (small ones that have to be soldered) or DIP8 (works in sockets) versions. Just search ebay for "opa627 browndog". Beware though that there are a few fakes out there. "tubebuyer" usually sells the genuine ones, from experience. The Browndog online store sells them too, but they aren't cheap. A HDAM from Audio-gd would probably work out cheaper and sound better.
__________________
04-05-2009, 09:07 AM
I'm going to order some sample op-amps to try, specifically the LT1364 + LM4562 combo, and just need to confirm the part numbers since I'm newb at this. I'm guessing you just need to sign up on the website even though you're not with a company or anything?
LT1364 - LT1364CN8#PBF PDIP
Lm4562 - LM4562NA MDIP 8 pin
How many do I need. Also, whilst I'm at it, what other samples should I order?
__________________
04-05-2009, 10:38 AM
Both the LT1364 and LM4562 are dual channel opamps, so 3 of each would be enough. The LT1364 gets quite hot in the DAC section of the Zero though, so it's best kept to the headamp section. The LM4562 can be used in either though.
__________________
04-05-2009, 12:29 PM
Ordered 2 LT1364 and 5 LM4562. How does that combo sound?
__________________
04-05-2009, 02:39 PM
Should be fine. I ordered 5 LM4562 and they only sent me 3 by the way, but it's enough.
__________________
04-05-2009, 11:36 PM
Ah, I was actually asking how does that combo of op-amps sound.
Should've phrased the question better. My bad.
__________________
04-05-2009, 11:51 PM
Good question........I have a LM4562 that came stock with my Auzen Prelude SC. What I remember of it is this, good overall frequency extension but a little glassy in the upper mids, the treble a bit tipped up and steely the bass however nicely extended with very good weight and control.
It comes up short against the Earth HDAM in other words.....but is a decent performer none the less. To artificial sounding to my ears though. I actually prefer the old 627BP over it (LM4562).
The LT1364's are a well known quantity in the H/Amp of the Zero and do very very well there. They are not a good candidate for the DAC OPA slot though as they quickly overheat in that spot. Thermal issues cause IC based OPA's to become unstable in a hurry the stock 2604 is better suited to the electrical properties of that section , that being said it's an ordinary performer SQ wise and is usually replaced right away because of that. But you already knew that having followed this gargantuan thread no doubt
I hope that helped you a little.
Peete.
__________________
Cans :HD650, AKG 240M (HD650 DIY cables SE and Balanced)
Desktop amps : LD MK III (6H30P-i DR's + DIY mods, Jaycar DIY kit amp (major DIY mods), 2 X Audio-gd Compass (test prototype,final version), Audio-gd C-2C W/ Stepped pot Upgrade, Audio-gd Phoenix SS balanced preamp/headamp.
Transports: Auzen Prelude PCI 7.1 SC/ASIO native driver using Media Monkey (all EAC ripped FLAC/Wav), Vanguard CDM12 Pro (BNC mod), HK HD720 (completely upgraded), Audio-gd CD7 Transport.
Sources: FrankenDAC DIY 24/192 dac (HDAMs/Teflon/PIO cap mod), Compass DAC, See Corp Vintage UK TT(Mission arm/Ortofon OM20S MM cart), Yaqin MS12B tube phono preamp, TEAC V530X Tape deck, Audio-gd Reference 1 DAC. C2C DIY pot mod http://www.head-fi.org/forums/f6/ste...1/#post5846722
04-06-2009, 09:07 AM
^What other op-amp samples should I get?
And how many HDAMs would I need to order, and more specifically which one (My first home DAC unit, be gentle  )?
__________________
04-07-2009, 08:30 AM
Those of you who purchased a Zero from wsz0304, how long does shipping take?
Its been 2 business days now, and still no reply to emails or a tracking number............
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
