Head-Fi: Covering Headphones, Earphones and Portable Audio
Support Head-Fi by starting your Amazon.com shopping by clicking here
Follow headfi on Twitter!
Follow Rocky Mountain Audiofest (RMAF) on Twitter!
Head-Fi Is Sponsored By:
Featured
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
Can Jam '09
(2009 International
Head-Fi Meet)
Impressions,
Reviews, Photos
Can Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss 1, 2, 3
dallan 1, 2, 3, 4
santacore 1, 2
nhat_thanh 1, 2
vpivinylspinner 1, 2, 3
amb 1
augustwest 1
eaglejo 1
johnsonad 1
shellylh 1
Jon L 1, 2, 3, 4
Germancub 1
zippy2001 1
IPodPJ 1
bhd812 1
Edwood 1, 2
abellaw 1, 2
minidiscs 1
atothex 1
HighLife 1
achristilaw 1
SiBurning 1, 2, 3, 4
SiBurning 5, 6, 7
LFF 1
Iron_Dreamer 1
doping panda 1
morphsci 1
ironbut 1
shaizada 1
jasper994 1, 2
jp11801 1
Uncle Erik 1
drubrew 1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Featured
Head-Fi's Sponsors
Featured
  #7216 (permalink)
Old 10-13-2008, 02:43 AM
Currawong's Avatar
Send a message via AIM to Currawong Send a message via MSN to Currawong Send a message via Yahoo to Currawong Send a message via Skype™ to Currawong
Default
Originally Posted by Syu View Post
Hi,
I read Introduction to the Zero DAC and Headphone amplifier. - Head-Fi: Covering Headphones, Earphones and Portable Audio and was interested in it. Are there some comparative reviews between The "as far as you can go without soldering" ZERO and other famous AMPs or DACs like HD-1L, m902, P-1, Darkvoice 337, Benchmark DAC1 or Lavry DA10?
I have a Lavry on the way, so I'll let everyone know. The only comparison I've done is with an Apogee Duet, which it was fairly equivalent to if using just opamps. Using the HDAM, it's better than the Duet. I highly doubt it could out-perform a Benchmark DAC1 or Lavry. It would be interesting to see how far it can be made to go after mods though.
Originally Posted by StratCat View Post
My opinion:
A stock Zero can drive the K701 well enough to get a feel for it's sound-signature, and you can enjoy it for simple musical enjoyment, but I would likely use it as a starting point if interested in doing serious critical listening. I'm on the fence with this opinion, because, TBH, I currently DO thoroughly enjoy my K701's on my Zero's HP, and I do attempt to do some critical evaluation, too.
So honestly, I could easily live with this combo if I had to, and would likely remain happy if not hanging out here on Headfi!
Seriously!
But, TBH, I'll only be able to accurately describe the Zero's HPA vs an external amp when I get my LD 1+ that I ordered recently. The Zero HPA + K701 seems to be a perennial question around here, and hopefully I'll soon be able to provide a more critical response.
HTH
I'm sure I'd be still enjoying my old Quart 55Xs if I'd just bought a stock Zero in the first place. At the least, you're missing out on a lot of soundstage not having a dedicated amp.
__________________
"The trouble with most people is not what they don't know, but what they know for certain that isn't true." -- Mark Twain
MacBook Pro → Audio-gd Reference 3+1 → Phoenix → Sennheiser HD-800, Grado HF-2 or Parasound Zamp → Paradigm Titans + Van Den Hul or DIY cabling.
currawong.net | Head-fi Blog | Head-fi feedback | Twitter | Instant-message me
  #7217 (permalink)
Old 10-13-2008, 03:04 AM
StratCat's Avatar
100+ Head-Fi'er
Default
Hi Currawong -
I'm not sure I understand what your implying.
Are you saying you would NOT recommend using the stock Zero's HPA as a way to get started?
__________________
Signal Path: Asus P5K-E > Xitel USB TOSLINK > Tianyun Zero DAC/Amp (OPA2604 + LT1364) > LD 1+ (6JI + LT1364) > Cans
Cans Owned: AKG K701 | Denon AH-D2000 | Grado SR225 | Senn HD280Pro
Cans Gone: HD595 | ATH-A700 | ATH-AD700 | SR325i | DT880-250 '05
Mod Path: Zero DAC -> LM4562/LT1364 (In House)/OPA626 or HDAM | Zero Amp -> ALPS Pot (In House) | LD 1+ -> Sylvi Gold 408A's (On Order)/M8161 + LM4562 (In house)/OPA627
  #7218 (permalink)
Old 10-13-2008, 04:14 AM
Pricklely Peete's Avatar
Default
Can't help you there (yet). But I do know using the HPA will definitely load your LT1364's (Oestensibly assisting any burn-in).
I'm not sure if the vol pot in pre-amp mode adjusts the gain in the DAC or HPA op amps.
You could test this by removing the LT1364's leaving the sockets unpopulated, and seeing if you can adjust the volume in pre-amp mode. If you still can, then obviously the LT1364's are out-of-circuit in pre-amp mode and you'll have to drive some phones to load the LT1364's.
Does this make sense?
Edit: Oops...hope I'm not stepping on your toes, Peete
Don't worry about it SC.
I'm almost certain the opamps in the H/Amp have to be installed in order for the circuit to function. I'm also willing to bet the LT1364's are responsible for gain in preamp mode. I believe the dac section opamp is fixed level gain for the analog output in pure DAC mode.
I could be wrong about that, but makes the most sense to me.
Can anyone confirm the configuration of the H/Amp opamps when engaged ( to drive either output ) ?
Peete.
__________________
Cans :HD650, AKG 240M (HD650 DIY cables SE and Balanced)
Desktop amps : LD MK III (6H30P-i DR's + DIY mods, Jaycar DIY kit amp (major DIY mods), 2 X Audio-gd Compass (test prototype,final version), Audio-gd C-2C W/ Stepped pot Upgrade, Audio-gd Phoenix SS balanced preamp/headamp.
Transports: Auzen Prelude PCI 7.1 SC/ASIO native driver using Media Monkey (all EAC ripped FLAC/Wav), Vanguard CDM12 Pro (BNC mod), HK HD720 (completely upgraded), Audio-gd CD7 Transport.
Sources: FrankenDAC DIY 24/192 dac (HDAMs/Teflon/PIO cap mod), Compass DAC, See Corp Vintage UK TT(Mission arm/Ortofon OM20S MM cart), Yaqin MS12B tube phono preamp, TEAC V530X Tape deck, Audio-gd Reference 1 DAC. C2C DIY pot mod http://www.head-fi.org/forums/f6/ste...1/#post5846722
  #7219 (permalink)
Old 10-13-2008, 04:26 AM
StratCat's Avatar
100+ Head-Fi'er
Default
Agreed.
That makes the most sense to me too, Peete.
If no one answers this definitively by the time I get my LD 1+, I'll check it out using the method I stated. I'd really like to learn more about the architecture and signal path of my Zero, and the new amp, too. I get the feeling the LD 1+ is going to be a nice compliment to the Zero WRT rolling and modding on-the-cheap...it has an op amp stage, along with the tubes, too!
__________________
  #7220 (permalink)
Old 10-13-2008, 04:29 AM
cybertron's Avatar
100+ Head-Fi'er
Send a message via ICQ to cybertron Send a message via AIM to cybertron Send a message via MSN to cybertron Send a message via Yahoo to cybertron Send a message via Skype™ to cybertron
Default
Well, its been a little while since I read this thread but I did a while back and I hope my information is still accurate. I just ordered my Zero with op amp upgrades, Alps pot, and HDAM from Lawrence. I hope that was a wise choice.
__________________
Any society that gives up a small amount of freedom for a small amount of security loses both and deserves neither. -Ben Franklin
  #7221 (permalink)
Old 10-13-2008, 06:46 AM
Default
A wise choice indeed. The Burson Audio cap mod should be done right away to your HDAM if you have a good 1uf >50V rating film and foil cap (or NOS PIO etc).
The difference it makes with the HDAM is well worth the effort. It's only drawback is burn in time required at 350 hours.
The tweak seems to give the HDAM that last bit of refinement needed for decay, transient speed, cymbal attack and decay as well as highly controlled macro and micro detail, dynamics etc...it also seems to add to the quality of bass and it's delineation. 3D sound stage is also improved a little.
Penchum has been studying this seemingly innocuous mod at length and is better placed to comment further. Take it away Pench
Peete.
__________________
  #7222 (permalink)
Old 10-13-2008, 06:57 AM
Currawong's Avatar
Default
Hi Currawong -
Not at all, just putting things into perspective. I used Quart 55Xs out of my Mac's headphone output for over 10 years, which is a crazy thing to do by head-fi standards, as they are painfully hard to drive headphones with massive diaphragms, totally unsuited to the role I was using them. However, I liked them a lot. When I first started into buying head-fi gear, I got my Little Dot MKV, followed by re-cabled K701s. I was arse-backwards in a sense because the 701s revealed that my computer as a source sucked, seriously. After the Apogee Duet came the upgraded Zero after I realised the Duet was to dry and analytical-sounding for the K701s. What I'm saying is, if I'd gone in reverse, and bought the Zero upgraded at first, it would have satisfied me a lot with my Quarts possibly without me experiencing what effect each component in the chain has.
People often ask "Will the Zero drive my headphones ok?" - What do they mean by "ok"? It's rather like all the threads where people are talking about buying K701s for their soundstage when they are not going to plug them into an amp or use a source that will allow the K701 to have a big soundstage.
__________________
  #7223 (permalink)
Old 10-13-2008, 07:44 AM
StratCat's Avatar
100+ Head-Fi'er
Default
Ah, O.K., I was confused...it would seem we ARE singing off the same page after all.
Exactly. To sound "reasonable" is tremendously subjective, like so much in audio.
I think perhaps the best way for me to approach responses to questions like this in the future would be to inquire as to where the poster is currently, gear and listening wise, and where the poster *thinks* s/he'd like to go (their desired end result), since we have a pretty disparate group here in Headfi WRT current listening perspectives and expected upgrade results.
I was very fortunate in that nearly immediately upon entering this hobby I realized I needed an inexpensive "sacrificial" test-bed in order to successfully demo and evaluate cans, starting with thier purchase firstly, and then I could fill in the rest of my system to fit my chosen can(s).
Funny thing though, now that I have the cans I like, I don't see myself sacrificing the test-bed anytime in the too near future!
Thanks again for the reply.
__________________
  #7224 (permalink)
Old 10-13-2008, 08:17 AM
Junior Head-Fi'er
Default
How do you guys think this DAC will work with my home audio setup? I will use my AMP10 from 41hz.com and a dvd player as a source. Does the ZERO make a good preamp+ DAC or is it strictly good for only headphones?
High Grade 24bit/192khz DAC with fully assembled kits - eBay (item 120314358106 end time Oct-13-08 01:00:00 PDT)
or
http://cgi.ebay.com/High-End-24bit-1...d=p3286.c0.m14
I saw these and it is made by the same guy I think.. Would that be a better option?
Thanks
  #7225 (permalink)
Old 10-13-2008, 12:57 PM
Currawong's Avatar
Default
Those kits require a box to put them in, which you'd have to modify, and a power supply. The Zero just requires that you plug it in and turn it on.
The Zero is the same as a headphone amp as it is a pre-amp. The output is just directed depending on whether you've got headphones plugged in or not.
__________________
  #7226 (permalink)
Old 10-13-2008, 01:11 PM
Head-Fi'er
Default
Hi all!
I was just delivered Earth, Moon and Sun v2 HDAMs several hours ago. I have tried to compare Sun and Moon in the DAC section and I must say that I am impressed by the sound of both. The overall improvement over the OPA627AU is really huge. At first listen, all is improved in all frequencies - the texture, space, details, musicality... Now I have some hard work to do in the next several weeks - to listen and compare the HDAMs
My first impressions (only after 2 hours on Moon and 2 hours of Sun v2) - Zero with HDAM in DAC > MAC AgQ IC > LD MKV > Sennheiser 600 (with Cardas cable):
1. Both HDAMs are much better than OPA627au.
Comparison: (please take the following information rather as a quick first comparison between Moon and Sun v2 and not as a general characterization of their sound, even if it can say something about this)
2.Moon: very smooth, highly detailed and balanced sound, music (jazz) flows very consistently with no weak point, applaus passages sounds much more real than Sun
3. Sun v2: less smooth, less balanced, more dynamic (I am not sure yet if in all frequencies), more "impact" of percussions, more action, "sharper" sound, but sommetimes maybe too sharp for my ears (i.e. saxophone and persussions), applaus is considerably worse/not so real as with the Moon
From Sun v2 and Moon I personally prefer the Moon much (more), especially because of its superb balanced, non-disturbing, solid smooth, very detailed and dynamic sound at all frequencies at the same time... On the other hand, there is something about the Sun than doesnt fit to my ears (or to my listening chain), maybe the "sharpness", maybe the less balanced sound, I am not sure yet... I must confirm this and more in the long term listening. And something can change over time, of course. Consider, I have only 2 hours listening experience with both HDAMs (same music for comparison).
More testing in progress...
Enjoy my english If something unclear, tell me
Last edited by seaice; 10-13-2008 at 02:19 PM. Reason: several language improvements
  #7227 (permalink)
Old 10-13-2008, 02:44 PM
bundee1's Avatar
Default
You're English is good enough to give us a great impression of those 2 HDAMs. Have you tried the Earth yet? My unit arrived 5 minutes ago so Im letting the Zero rest while I make a cradle for it.
Thank you for the first impressions.
__________________
SB3>>VH Audio Pulsars>>Zero DAC>>Winsome Labs Mouse>>Synergistic Research Alpha Speaker Cables>>JM Labs Chorus 706 speakers.
  #7228 (permalink)
Old 10-13-2008, 03:09 PM
Head-Fi'er
Default
I am testing the Earth just now (2-3 hours). I must say, that at first listen it is the most neutral HDAM of this trio (in the very positive way - I do not hear any weaknesses so far). In the near future I will focus on Earth vs. Moon comparison, because these are my favourite HDAMs for now - though they sound differently, neither has any weakness to my ears (setup). What is the Sun concerned, there is something that I sense as little, very little obtrusive (but even the Sun is still better than OPA 627). I am not sure what it is, I must sometimes listen several albums that I know exactly note by note... And there is still many I plan to test with these HDAMs - Senn 580/650 (with ordinary cable), AKG K701...
  #7229 (permalink)
Old 10-13-2008, 04:26 PM
cybertron's Avatar
100+ Head-Fi'er
Default
Hmm, was just reading Currawong's introduction to the ZERO and I fear I may have made an impulsive purchase. Here is my setup, maybe you guys can tell me if i should have just gone with an amp.
my primary source is my computer using the crappy onboard Realtek soundcard. From there I go optical cable to my Logitech Z-5500 speakers, and i have my ATH-A900LTD's plugged into the z-5500 control module.
I've been relatively happy with this setup but I do not have anything else to compare it too. Would I have been better off just getting a Little Dot, or other amp? I spent $250 including shipping for my updated zero w/ alps, 1 hdam, and opamp upgreade.
__________________
  #7230 (permalink)
Old 10-13-2008, 07:15 PM
Junior Head-Fi'er
Default
I don't mind making a case. And those transformers included are ready to plug into the wall. How do the DAC performances differ? Are they the same chip? How would the Zero DAC compare to say a $800 DAC?
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
