Head-Fi: Covering Headphones, Earphones and Portable Audio
Support Head-Fi by starting your Amazon.com shopping by clicking here
Follow headfi on Twitter!
Follow Rocky Mountain Audiofest (RMAF) on Twitter!
Head-Fi Is Sponsored By:
Featured
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
Can Jam '09
(2009 International
Head-Fi Meet)
Impressions,
Reviews, Photos
Can Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss 1, 2, 3
dallan 1, 2, 3, 4
santacore 1, 2
nhat_thanh 1, 2
vpivinylspinner 1, 2, 3
amb 1
augustwest 1
eaglejo 1
johnsonad 1
shellylh 1
Jon L 1, 2, 3, 4
Germancub 1
zippy2001 1
IPodPJ 1
bhd812 1
Edwood 1, 2
abellaw 1, 2
minidiscs 1
atothex 1
HighLife 1
achristilaw 1
SiBurning 1, 2, 3, 4
SiBurning 5, 6, 7
LFF 1
Iron_Dreamer 1
doping panda 1
morphsci 1
ironbut 1
shaizada 1
jasper994 1, 2
jp11801 1
Uncle Erik 1
drubrew 1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Featured
Head-Fi's Sponsors
Featured
  #46 (permalink)
Old 03-28-2008, 07:06 PM
Default
Originally Posted by edvardd View Post
Has anyone tried MKIII as a preamp to powered studio monitors? if that is possible, I'm a bit confused about all this
(I'm buying MKIII mainly for my HD650)
The MkIII is a great pre-amp by all accounts. Replacing/upgrading the driver tubes from stock will also help you be able to tune the pre-amp to your exact preference (the preamp out is driven solely by the driver tubes).
- DoA
__________________
“I know I ask perfection of a quite imperfect world, and fool enough to think that’s what I’ll find.” – The Carpenters
Transport: ________________DC:
__Toshiba SD-3950____ -→ ____ Canare LV-77S
Source :    _  Transit :  __   DC :   ___      DAC :     __      IC : _____________ Amp :       __ Headphone :
__WinAmp ASIO M-Audio Transit  Sys. Concept   Entech Number    Blue Jeans Cable  Little Dot II++ (v2)  Sennheiser HD650
_____________________________________ Premium Toslink   Cruncher 203.2  _  Belden 1694A
FS: HeadRoom MAX amp with MAX DAC $2750 OBO
FS: Sennheiser HD650 + Cardas Upgrade Cable + HeadRoom Headphone Bag
  #47 (permalink)
Old 03-28-2008, 07:42 PM
Junior Head-Fi'er
Default
Originally Posted by Penchum View Post
Try this link and see if it works for you. Logon
i dont kno why i can't register, but thanks Penchum, maybe i try later
  #48 (permalink)
Old 03-28-2008, 08:11 PM
rpveld's Avatar
Head-Fi'er
Default
Hendry,
If you PM me your email address I can sent it to you.
__________________
Portable:
Headphones: Shure e4c, V-moda vibes, PX100, ATH-ES7
Source: iPod Classic 80, iAudio X5L
Amp: Headstage Lyrix Pro USB total
Cables: Microshar LOD, Cardas mini to mini
Home:
Headphones: HD 650 Blue Dragon, HFI 780 S2, MS-1, AKG K701, AKG K240 LP.
Source: PC, soundcard coax out.
Foobar 2000,Asio4all,Squeezebox Duet
Amp: LD MKV, LD MK III,
Dac: Beresford TC-7510, ZERO
Cables: BlueJeans IC RCA
  #49 (permalink)
Old 03-28-2008, 11:57 PM
Penchum's Avatar
Default
- DoA
X2! It is a great Pre-amp for sure. DoA, check this out from DavidZ on the LD site:
"To answer your question, actually all of the MK series amplifiers with pre-amplifier functionality (MK 2, MK 3, MK 4, and MK 4 SE) have the pre-amp signal routed through both the driver and power tubes." Post (#939)
I didn't know this either (until I found it), but some quick power tube swapping while using the pre-out to my T-amp, confirms this! Now I understand why it sounds so good.
  #50 (permalink)
Old 03-29-2008, 01:30 AM
LordofDoom's Avatar
100+ Head-Fi'er
Send a message via AIM to LordofDoom Send a message via MSN to LordofDoom
Default
Mmmm this amp sounds great, I can confirm that from my own "testing"
  #51 (permalink)
Old 03-31-2008, 06:26 PM
Junior Head-Fi'er
Default
I received a MK III today.
But I have a problem when I met the highest volume.
The volume decreases slightly, it does not ?
(setting gain: 10)
__________________
Headphones: AKG K530 / Beyer DT880pro '06
Amps: Little Dot MK III
Soundcards: Auzentech Xplozion -> Mod Opa 4562
  #52 (permalink)
Old 03-31-2008, 10:24 PM
Penchum's Avatar
Default
(setting gain: 10)
Double post. Try the other thread.
  #53 (permalink)
Old 04-01-2008, 09:47 AM
Junior Head-Fi'er
Default
- DoA
Not so. The preamp uses all 4 tubes. See the manual.
  #54 (permalink)
Old 04-01-2008, 10:26 AM
Junior Head-Fi'er
Default
is it true the standar power tube is 6H6PI ? can i change the tube without mod ?
  #55 (permalink)
Old 04-01-2008, 01:25 PM
Penchum's Avatar
Default
If you mean to change it to the 6H30PI, yes, you need the mod first. I would give the 6H6N-PI a chance first. It is really a nice sounding power tube. The driver tube rolling possibilities are great and net the most changes.
  #56 (permalink)
Old 04-01-2008, 02:02 PM
oatmeal769's Avatar
100+ Head-Fi'er
Default
Would you say that placing other driver tubes besides the stock ones will make it sound BETTER or just DIFFERENT? EX: I have a NOS set of Tung-Sol's I just found on Ebay. If they will make the amp better, I'd rather do the burn in process with them first. (Amp should be here today)
__________________
For Sale : PS Audio DL-III w. Cullen Level III mods
FLAC > Foobar/WASAPI > Belden 1694A Coax > PS Audio/Cullen DL-III-mod 3 DAC > Zu Gede > Zana Deux #90 > Cardas > HD 600
Head-Fi Feedback eBay Feedback
  #57 (permalink)
Old 04-01-2008, 02:16 PM
Penchum's Avatar
Default
Ow, well, it really doesn't matter in the end. Most folks like to burn-in with the original set, so they have a "default" reference. Then they roll to explore the changes. The Tung-Sols will sound better, once they are burned in too.
Considering that every tube set you put in the amp will need to be burned in, they will eventually get their 40-45 hours in the socket at some point. Those demanding tubes! They want their moment in the spotlight!
  #58 (permalink)
Old 04-01-2008, 02:24 PM
oatmeal769's Avatar
100+ Head-Fi'er
Default
Considering that every tube set you put in the amp will need to be burned in, they will eventually get their 40-45 hours...
So the tubes only need about 50 hours? That's not so bad, I read your review as +/- 144 hours, but I guess that was for the amp (capacitors, etc) only, right?
__________________
  #59 (permalink)
Old 04-01-2008, 02:28 PM
Penchum's Avatar
Default
Correct. The unit will be around 100-145, but tubes usually take only 40-45.
  #60 (permalink)
Old 04-01-2008, 02:30 PM
Junior Head-Fi'er
Default
so the stock power tube is good enough, right ? if change with 6H30PI, it will be change the amp character ?
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
