Head-Fi's Sponsors
(Premier Sponsors bolded) |
Can Jam '09
(2009
International
Head-Fi Meet)
Impressions,
Reviews, Photos |
Can
Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss
1,
2,
3
dallan
1,
2,
3,
4
santacore
1,
2
nhat_thanh
1, 2
vpivinylspinner
1,
2,
3
amb
1
augustwest
1
eaglejo
1
johnsonad
1
shellylh
1
Jon L
1,
2,
3,
4
Germancub
1
zippy2001
1
IPodPJ
1
bhd812
1
Edwood
1,
2
abellaw
1,
2
minidiscs
1
atothex
1
HighLife
1
achristilaw
1
SiBurning
1,
2,
3,
4
SiBurning
5,
6,
7
LFF
1
Iron_Dreamer
1
doping panda
1
morphsci
1
ironbut
1
shaizada
1
jasper994
1,
2
jp11801
1
Uncle Erik
1
drubrew
1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook |
Head-Fi's Sponsors
| Headphone Amps (full-size) Discussion of desktop headphone amps. |
03-19-2008, 02:30 PM
Originally Posted by Ihatepopupads
Thanks Hans, where is the amp made ?
The PCB is made and bestucked in Hongary.
Casing is Dutch made (a local CNC company around the corner) and final assembly here at my place.
Casing and local assembly are done here which is more expensive but gives me better control over the quality.
Rgds
Hans
__________________
iQube V2 available now, read all about it here
Find our cables and DIY parts webshop here: www.qables.com
03-19-2008, 02:41 PM
Originally Posted by Dexdexter
So, in the event of such an occurrence, do you keep spare tabs on-hand? They look easy enough to replace if one can manage to safely disassemble the chassis.
Well Dex, yes I do keep spare ones, as for all parts. But opening the unit more then only the battery lid in principle voids warranty. Second you will not be able to remove the volume knob without the proper tools. If you try, chances are very high you will damage the housing and/or knob. Without removing the volume knob you cannot remove the PCB and thus remove the two rear end tabs.  .
In case it happens just send it in for repair. I will be very lenient on the fees ok?
Hans.
__________________
03-19-2008, 02:49 PM
Rgds
Hans
Thanks for the excellent info, I just want to be sure about things as moon audio isn't doing returns on the pre- sale iQubes. I was going to keep the iQube for myself and give my son my mini box e+  If the blasted dollar wasn't so weak I wouldn't hesitate. One thing I have found is all the vendors I have delt with on head-fi are A++, and its really cool to have a dialog with the main man! Makes me feel more secure about those $$ purchases.
Now the other problem... my wife- whats that thing? Oh nothing just a headphone amp. wife - another one? how much was it? Not much, I just traded in my other one and paid a little extra , cough , cough. Or another good reply,- I finally used that amazon gift card you got me for x-mass...
03-19-2008, 04:30 PM
That's it! The iQube and CanAmp share a small degree of Hungarian heritage.
Which reminds me that I took some shots of the business side of the iQube at the meet:
03-19-2008, 05:32 PM
1000+ Head-Fi'er
Sweet Jesus ! People were not kidding about what it takes to open the iQube for battery replacement. I spent 15 minutes last night and gave up with achy hands. Trial II today.
__________________
Sources: Cambridge Audio Azur 640C, RWA iMod 5.5 80gb w/ DIY Sonicap dock, iRiver ihp-140
Amps: KICAS Caliente, SR-71, MiniBox-E+
Phones: Sony MDR-CD3000, Sennheiser HD600 w/ APS v3 cable, HD25-1 II w/ Vampire, Koss KSC-75
Cables: All DIY. See my Flickr photostream
My Feedback:
head-fi
ebay
03-19-2008, 07:32 PM
Yeah, it's some sort of evil rite-of-passage that Hans devised especially for his valued iQube customers...
From Post #79:
Open the top side (the one with the single clip at the rear). Press it partially closed again (with your thumb over the portion where there isn't a clip underneath) until you hear a very slight "click". There should be a discernible gap of about 1mm between the cover and the chassis.
Now, pull upward on the opposite side with your 4 fingers, working them front-to-back, back-to-front. It should "click" and eventually come free.
With the cover off, try the clip massaging technique as I outlined above.
03-19-2008, 07:47 PM
1000+ Head-Fi'er
Thx Dex. I actually saw that. Trouble is, I still haven't gotten through step 1 (Open the top side w/ single clip at rear). It is extremely tight.
__________________
My Feedback:
head-fi
ebay
03-19-2008, 08:10 PM
1000+ Head-Fi'er
Sorry, meaningless post but I ave to say good man Dex, I have used your massaging advice and now it is an utter breeze to open this baby up.
Nice one mate.
__________________
Team University of Manchester
....... .............. ......... 1824
my feedback
03-19-2008, 09:48 PM
Hi Musicmaker, are you sure you are trying to open the correct side?
You should first open the bottom lid and at the side with the on/off switch, this is where only one notch is located. The gain switch side has two.
It is really the bottom side, if you can read the word iQube on the side it is the lower lid!
Hang in there. the first time is the hardest but once you have mastered the trick it is real easy!! really, believe me.
rgds
Hans
__________________
03-19-2008, 10:09 PM
mm, one of the early mistakes I made was to press down on the middle rail of the chassis (with the "iQube" logo engraved on it), instead of the rubberized battery compartment cover. Could that possibly be what you're doing?
In any case, try this:
Hold the iQube in your two hands with the bottom of the unit (the battery cover) facing outwards. Place both of your thumbs directly over the area where the first, lone clip is located (the bottom corner closest to the "output" jack, shown below circled in green).
Push downward and outward simultaneously. The first side should come free, allowing you to complete the procedure as outlined above.
03-19-2008, 10:22 PM
Headphoneus Supremus: Reviewerus Prolificus
While I *love* the sound of the iQube, the fact remains that the battery access is a total drag. So I put in rechargeables, and I will never open the thing again, problem solved
__________________
PLEASE NOTE: Due to the volume of PM's I have been receiving in connection with my reviews, I no longer have the time to answer PM's from people with zero posts. Please read head-fi first before asking questions.
Team GO-U-NORTHWESTERN
Pics: Main Home Rig; Bedside Rig; Office Rig; Portable Rig;
Headphones: JVC HP-DX1000, HA-RX900; Headphile Deep Cup Darth Beyers VXD3,VXD4; Beyerdynamic DT990/600 (Manufaktur) DT770/600 (Manufaktur), DT880/600 Balanced (Manufaktur); HiFi-Man HE-2 Planar Magnetic; Sennheiser PXC-350; Shure SRH840
Home amps: Ray Samuels Audio Stealth (Mullard ECC32/CV4003); Decware Zen CSP-2 (Amperex BB 6DJ8/Sophia Princess 274B); Darkvoice 337 (GEC 6AS7G's/Tung-Sol mesh plate 6SJ7GTs); Wheatfield Audio HA-2 (Mullard ECC32/GEC 6AS7G/GEC U52); Ming-Da MC84-C 07 (Mullard CV4004/EL84/EM87); Audiotailor Jade (GEC 6AS7G/Sylvania 5751); J. Sound Lab Headphone (Mullard 12AT7); Audio-GD Phoenix; Musical Paradise MP-301 (Ken-Rad 6V6GT/Mullard 6AU6)
Portable Amps: Ray Samuels Audio P-51 Mustang; Decware ZenHead; Meier Audio 2Move, XXS; Qables iQube
Sources: Denon DP59L table + Clearaudio Maestro Wood / VPI Scoutmaster + Benz Micro Wood L2 > Audio Electronics PH-1 DJH Phono Preamp; Music Hall 25.2 DAC; Denon DVD-5900;Red Wine Audio iMod iPod (Apple Lossless) & ALO VCap dock; Sony SCD-555ES SACD player
Loudspeaker system: Krell KAV250 Preamp>Sunfire Signature II Power amp > B&W Nautilus 800 Signatures + Velodyne FSR-1500/Martin Logan Descent
Tube testers: B&K Dyna-quick 650 & Dyna-Jet 606
Head-fi feedback
03-19-2008, 10:37 PM
1000+ Head-Fi'er
Thanks Dex & Hans.
Pretty sure I have the correct side. On/Off switch is on top facing me and I'm trying to open the bottom cover with pressure on the area marked in green as show in Dex's last post with pic. Dex, I'll try what you suggested.
I really wish the battery access was easier. My fingers are getting a real workout.
__________________
My Feedback:
head-fi
ebay
03-19-2008, 10:48 PM
1000+ Head-Fi'er
No luck. Maybe I should give my fingers a bit of rest. I've spent like 20 minutes futzing with this already. Does it require quite a bit of pressure to open the first side ? A couple of wrestlers live close by, should I get their help
__________________
My Feedback:
head-fi
ebay
just wish I could teach you all in real live how to do it because it is actually real simple.
Well it is as it is. Thanks for all trying to keep up trhe good mood.
Hans
__________________
03-19-2008, 11:52 PM
Actually, yes. Which is why I have devised an alternative explanation that essentially eliminates finger-fiddling in favor of super-concentrated thumb-power!
So the following has also been added to my original review:
iQube Battery Compartment Opening Tutorial
If the battery compartment unlocking method as described in the iQube owner's manual brings you no joy, here is an alternative route:
- Hold the iQube in your hands with the bottom of the unit (the black rubberized battery cover) facing outwards. The front volume knob/switches should be pointing into your left palm, while the rear input/output jacks should be pointing into your right palm. The engraved "iQube" logo in the side-rail of the chassis will be upside down as you look downward.
- Place both of your thumbs directly over the black rubberized area where the first, lone clip is located (the corner closest to the "output" jack, Clip 1, as shown above circled in green).
- Push downward and outward simultaneously. The first side should "click" and come free.
- Press this side partially closed again (with your thumb over the portion where there isn't a clip underneath) until you hear a very slight "thuck". There should be a discernible gap of about 1mm between the cover and the chassis.
- Rotate the iQube to the opposite side. The front volume knob/switches will now be pointing into your right palm, while the rear input/output jacks should be pointing into your left palm. Again, the engraved "iQube" logo in the side-rail of the chassis will be upside down.
- Place your left thumb over Clip 2 (above in blue) and your right thumb over Clip 3 (above in pink) on the black rubberized surface.
- Again, push downward and outward simultaneously. The second side should "click" and the entire battery compartment cover should come free.
- With the cover off, try the clip massaging technique as I have outlined in the previous section, so that subsequent openings become noticeably easier.
- After changing the batteries, replace the battery cover on the side with Clips 2 & 3 first. Snap the cover into place on that side, and then snap down the opposite side where Clip 1 is located. Job done!
Note: The iQube battery cover is perfectly symmetrical, so it does not matter whether or not the original orientation is maintained when replacing it.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
