Head-Fi: Covering Headphones, Earphones and Portable Audio
Support Head-Fi by starting your Amazon.com shopping by clicking here
Follow headfi on Twitter!
Follow Rocky Mountain Audiofest (RMAF) on Twitter!
Head-Fi Is Sponsored By:
Featured
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
Can Jam '09
(2009 International
Head-Fi Meet)
Impressions,
Reviews, Photos
Can Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss 1, 2, 3
dallan 1, 2, 3, 4
santacore 1, 2
nhat_thanh 1, 2
vpivinylspinner 1, 2, 3
amb 1
augustwest 1
eaglejo 1
johnsonad 1
shellylh 1
Jon L 1, 2, 3, 4
Germancub 1
zippy2001 1
IPodPJ 1
bhd812 1
Edwood 1, 2
abellaw 1, 2
minidiscs 1
atothex 1
HighLife 1
achristilaw 1
SiBurning 1, 2, 3, 4
SiBurning 5, 6, 7
LFF 1
Iron_Dreamer 1
doping panda 1
morphsci 1
ironbut 1
shaizada 1
jasper994 1, 2
jp11801 1
Uncle Erik 1
drubrew 1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Featured
Head-Fi's Sponsors
Featured
  #136 (permalink)
Old 03-22-2008, 12:20 PM
hoosterw's Avatar
Sponsor
Qables
Default
Originally Posted by jeremyrose77 View Post
hello, iv'e purchased this amp and got this pdf from han's. say's on the pdf that the outer pin is 2.35mm and inner is 0.7mm but you can get away with 2.5mm on the outer dimension, inner dimension is the same 0.7mm, that's the smallest one at my local shop a it fit's fine. hope that helps.
I would strongly suggest not to exceed the specification of 2.35mm outer diameter. A long term increased force on the female connector inside the IQube might damage this and as a result give a bad connection.
I will check with the designers and the supplier of the internal female what is allowed and then report back here.
Rgds
Hans
__________________
iQube V2 available now, read all about it here
Find our cables and DIY parts webshop here: www.qables.com
2 new ultra low and thin iPod connectors available, please find them here
  #137 (permalink)
Old 03-22-2008, 12:23 PM
hoosterw's Avatar
Sponsor
Qables
Default
Originally Posted by All Day Breakfast View Post
Well done DD. I've opened mine a few times now and gently messagged the spring clips but I wish I had your video for the first time round. There are 2 key things in your video from my point of view.
1) It's hard from the instruction manual to know whether the technique for opening the cover requires brute force or finesse. The video clarifies that.
2) The manual doesn't include that step that you added on the web and in the video about partially closing the 1 spring side before attempting to open the second side. That missing piece of information was crucial for me.
I thought you did a good job on the video.
Hopefully Hans will see it as useful but I'm fairly certain his customers will.
Without knowing the economic consequences I also thought the rechargeable battery suggestion coming with the unit was a good one.
Neither of these two suggestions require Hans to forgo his design goals nor redesign the unit and both would reduce or eliminate the single greatest weakness of this otherwise totally enjoyable unit.
I would also like to thank DEX for his great contributiuon, I stand corrected, the video is a great addition!!! Thanks Dex!!.
I will post it on the iqube website immediately.
Also the rechargeable option is one that I plan to introduce and I will speak to moon audio to see if we can also do that for the US sales.
Thanks again and nice to see that you all are so help full BIG THUMBS UP!
Hans
__________________
  #138 (permalink)
Old 03-22-2008, 01:26 PM
slwiser's Avatar
Default
Hans
Yes, I am all thumbs up with a couple of shorter nails. You have great aesthetics's and a great sound with the iQube.
__________________
Headphones: Stax: SR-007 MkII, SR-003; Ultrasone: Edition 9 (2); AT:ESW10JPN; Sleek SA6 Wireless---Home Amps: Stax: SRM-252a; Headamp: KGSS(bg) Yamamoto: HA-02---Portable Amps: TTVJ: Portable Millet Hybrid;-----Sources: Lavry DA10 (2); Oppo 981HD; Squeezebox V3; iMod; Sansa Fuse; HeadAmp Pico-amp/dac&Pico DAC-----Feedback: http://www.head-fi.org/forums/f12/slwiser-129086/ <><
  #139 (permalink)
Old 03-22-2008, 01:37 PM
Junior Head-Fi'er
Default
Hans
That's great news Hans! Take a bow DEX and slwiser.
A great piece of kit!
  #140 (permalink)
Old 03-22-2008, 04:05 PM
Dexdexter's Avatar
Default
No problemo, Hans, it was a fun enough little exercise to do, if not just a wee bit nerve wracking. Making sure everything remains in-frame while manipulating the iQube and simultaneously supplying commentary turned out to be a real juggling act.
Gorsh...*flattered*
You can use the "embedding" code that's available on YouTube to place it directly into the (currently woefully empty ) faq section on the iQube site. Feel free to add the accompanying text explanation from post #105 here.
I dunno. It strikes me as "6 of 1, half-dozen of the other". Whether or not rechargeables are shipped installed in the iQube, it seems clear to me that the owner is gonna have to open that battery compartment eventually.
So why delay the inevitable? Is it not better just to learn the procedure straight away and feel confident & comfortable with it, than to dread having to do it cold, perhaps just a year or so down the road?
One final thought. The iQube cover retaining clips could conceivably be shipped pre-conditioned, using the massaging technique previously discussed. Of course, although it takes but a mere few seconds to accomplish, those seconds do add up in an assembly process and ultimately would entail additional time and effort. So if doing so would further add to the price of the iQube, diminish your margins, or delay the development of a matching iQube DAC, well, nevermind!
  #141 (permalink)
Old 03-22-2008, 04:09 PM
slwiser's Avatar
Default
Not a bad ideal either....I like it.
__________________
  #142 (permalink)
Old 03-22-2008, 07:13 PM
Junior Head-Fi'er
Default
snip... or delay the development of a matching iQube DAC, well, nevermind!
I'll buy the matching DAC too
  #143 (permalink)
Old 03-22-2008, 07:20 PM
slwiser's Avatar
Default
What DAC?
__________________
  #144 (permalink)
Old 03-22-2008, 07:23 PM
musicmaker's Avatar
1000+ Head-Fi'er
Default
Originally Posted by slwiser View Post
What DAC?
x2, yeah what dac ? Tell us, tell us..
__________________
Sources: Cambridge Audio Azur 640C, RWA iMod 5.5 80gb w/ DIY Sonicap dock, iRiver ihp-140
Amps: KICAS Caliente, SR-71, MiniBox-E+
Phones: Sony MDR-CD3000, Sennheiser HD600 w/ APS v3 cable, HD25-1 II w/ Vampire, Koss KSC-75
Cables: All DIY. See my Flickr photostream
My Feedback:
head-fi
ebay
  #145 (permalink)
Old 03-22-2008, 07:49 PM
Dexdexter's Avatar
Default
It's mostly just me trying to nudge Hans, as I had earlier on in Post #31:
Hans, since you've already found us here and are apparently in a good mood, howsabout getting those Class D elves of yours to blow a little pixie dust on a matching battery-operated DAC with optical and USB inputs?
When I spoke to Hans last weekend at the Netherlands Meet, he acknowledged that there has been some discussion in that general direction...
  #146 (permalink)
Old 03-22-2008, 07:50 PM
Junior Head-Fi'er
Default
Hans?
  #147 (permalink)
Old 03-22-2008, 09:03 PM
Ihatepopupads's Avatar
Default
That would be quite cool, this thread is a bastion of wisdom- I know what kind of rechargeables to use, and how best to open the little beastie. Damn the torpedoes, open the wallet, iQube will be mine.
__________________
lol! http://www.youtube.com/watch?v=bIqHokjymJ8
Technical Difficulties!!!
http://www.youtube.com/watch?v=ES1RypBww_g
Gear: Sony NWZX1060B- (it's here!) Thanx Sooz!xxx / sony s639/sansa clip/+ others :)- P-51- PFE, hd 595, hfi 780- IE8/W3 RIP
P.S. My dogs don't like you!
  #148 (permalink)
Old 03-22-2008, 10:25 PM
Junior Head-Fi'er
Default
...I dunno. It strikes me as "6 of 1, half-dozen of the other". Whether or not rechargeables are shipped installed in the iQube, it seems clear to me that the owner is gonna have to open that battery compartment eventually.
snip
Ray Samuel does the calculations on his web site for one of his battery powered amps to show how the battery will last something like 8 years of constant use before needing replacement. I'm not into the techie side of things so I let this slide off my scales but if the calculations are straight forward the question is, how long will the batteries likely last? I don't know how much it matters if you learn how to open the thing after the first 100 hours if you're going to install batteries which last 8 years. 2 years or less between battery changes is one thing but 4 years or more between battery changes starts to influence the calculus IMO.
Last edited by All Day Breakfast; 03-22-2008 at 10:29 PM. Reason: to clarify my writing
  #149 (permalink)
Old 03-22-2008, 11:01 PM
Junior Head-Fi'er
Default
Rgds
Hans
hello, just to add about my previous post the 2.5mm plug when half inserted in the amp still moves up and down left and right and fits snug when fully inserted without putting pressure on it. i was assuming this would be fine and i don't want to mislead people with what i said, i myself will hold back on useing the plug until i hear back from you/someone here. thanks jeremy.
  #150 (permalink)
Old 03-22-2008, 11:46 PM
Junior Head-Fi'er
Default
To add some info from the battery site mentioned earlier
1. Standard NiMH cells have an approximately life span of 3 years with increased internal resistance, lowered capacities, and higher self discharge with age. Cheaper brands may have less.
2. NiCd cells have about 5 year life span usually fails with internal shorts (complete failure) or excessively high resistance.
3. LSD NiMH cells currently have no data in this regard, they're advertised as having better longevity than regular NiMH cells. They've only been out for less than 3 years now. The oldest cells reported (1.5 years old) was lightly used and perform like new.
and
LSD [low self discharge] NiMH tech has dramatically improve the performance, longevity, durability, and cycle life too. However, it is new and relatively unproven tech. For general use, the Sanyo Eneloops LSD NiMH seem the very best and there seems to be no reason to buy any non-LSD NiMH cells these days
and
regular NiMH AA rechargeable batteries giving 10 shots in a digital camera, regular AA alkaline batteries gave 90 buy Sanyo eneloops gave over 400 shots on a charge!
While this data says nothing definitively about Eneloop AAAs, It suggests that they would have a performance lifetime of more than 3 years and maybe in the 4-5 year range. Assuming for the moment that's true, does it matter if you successfully opened your iQube 4 years ago and never since?
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
