Support Head-Fi.org by starting all of your Amazon.com shopping by clicking here.
____________________________________________________________________
Today's Featured Head-Fi Blog:  Jude's Blog
Please help support Head-Fi by becoming a Contributing Member  CLICK HERE
-- Contributing Members, thank you for your generous support! --
Head-Fi Is Sponsored By:
Register FAQ Blogs Members List Calendar Mark Forums Read Today's Posts Search
2008 International
Head-Fi Meet
(Can Jam '08)
Impressions,
Reviews, Photos
Can Jam '08 graphic
courtesy of Edwood
Click on the links below
for Can Jam '08 photos,
impressions and reviews:
NightWoundsTime
lan
agile_one
wavoman
crappyjones123
Luke G
bperboy
jimaxp
Can Jam '08 Logo
T-Shirts For Sale
Featured
Head-Fi's Sponsors
(Premier Sponsors bolded)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
 LFF's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Head-Fi's Sponsors
Featured
Go Back   Head-Fi: Covering Headphones, Earphones and Portable Audio > Equipment Forums > Headphone Amps (full-size)
Headphone Amps (full-size) Discussion of desktop headphone amps.
Meier Audio CORDA HEADSIX & The Most Recent Sponsored Threads
Celebrating 6 years of Head-Fi, Meier Audio introduces the Limited Edition HEADSIX (portable headphone amp) Head-Fi Support Sales Action
Reply
Thread Tools Display Modes
Old 10-09-2004, 02:21 PM   #81 (permalink)
100+ Head-Fi'er
Profile
Default
Rudistor RP4.1
Rudistor, Trieste, Italy
RP4.1
In production
List price 550 Euros
Type of amp hybrid
Stock tubes double triode 12AU7
Crossfeed No
Other processors No
Portable No
Power supply AC
Detachable power cord Yes
Number of headphone jacks 1
Jack output impedance 32-600 Ohm
Jack output 450 mW max
Jack type 1/4"
Inputs line in 2 RCA
Housing material aluminum
Size (dimensions) 242W*80H*282L mm
Weight 5.5 Kg
KtoEto is offline
Old 10-26-2004, 07:31 AM   #82 (permalink)
500+ Head-Fi'er
mikeymad's Avatar
Profile
Default MG Head DT / OTL MK III Headphone Amp
Specifications
Tubes (included)
2 x SOVTEK EL84/6BQ5
1 x electro-harmonix 12AX7EH
Output power:
240mW (33 Ohm)
110mW (120 Ohm)
70mW (300 Ohm)
Frequency response: 25 Hz - 40 KHz +- 1dB
Distortion: 0.60% at full power
S/N Ratio: 83dB (0.15mV)
Input impedance: 100K
Output impedance: 13 Ohm
Input sensitivity: 1V
Power consumption: 21 W
Dimensions: amp 7.1" wide, 7.5" deep, 6.3" high; power supply 7.1" wide, 3.8" deep, 3.5" high
Net weight: 10 lbs.
Current List: $395.00
mikeymad is offline
Old 03-04-2005, 12:18 PM   #83 (permalink)
digicom_t1's Avatar
Profile
Default WooAudio 3
See Manufacturer's Site for More Pix: http://www.wooaudio.com/products/wooaudio3.html
Amp manufacturer: WooAudio
Amp name/model: WooAudio 3
In production? Yes
List price: $460
Type of amp: Single Ended Class A Tube Headphone & Pre Amplifier
Stock tubes: 1 x 6080/6AS7, 2 x 6922/6DJ6 All gold pin tube sockets.
Crossfeed? No
Other processors? No
Portable? No
Power Supply: AC 110 V, 50/60 Hz (220 V available. Specify when order)
100 watts specially made toroidal transformer.
Detachable power cord? Yes (not provided)
Number of headphone jacks: One
Headphone Impedance: 30-600 Ohms
Jack type: 1/4"
Input impedance: 100 Kilo-Ohms
Frequency response: 8 Hz - 100 KHz +/-3dB
Pre-amp Gain: 10 dB
Signal/Noise: 90 dB
THD: <= 0.08%
Power output: 2 Watts per channel
Inputs: One, Gold-plate RCA
Other outputs: One (Pre Amp) Gold-plate RCA
Possible upgrades: Tube rolling within the family of tubes listed above.
Ling to HeadFi DYI Mods: http://www4.head-fi.org/forums/showthread.php?t=96731
Construction Material: Heavy duty full aluminum die-cast chassis with 1/4" Face Plate, black anodized or satin brushed silver - other colors (red, blue and champagne may be available soon), large aluminum volume knob & push button power switch.
Other notes on Electrical:
All Point to point hand wired.
Alps potentiometer and power switch
ELNA and WIMA capacitors
High precision resistors
Teflon wires
Size: 5-5/8 "(L), 13 "(W), 6"(D)
Weight: approx. 9 lbs.
User Notes: This amp pairs very well with Senn 650s and Sony SA5Ks!
digicom_t1 is offline
Old 03-09-2005, 08:03 PM   #84 (permalink)
Junior Head-Fi'er
Profile
Default Lehmann - Black Cube Linear
In production? yes
price : 778 $
Type of amp : Solid State
Portable? no
Power supply : Internal
Number of headphone jacks : 2
Jack type : 1/4"
output : 200mW/300ohm 400mw/60ohm
Distortion: 0.001% 6mw/300ohm
Inputs : 1 / 47K
Gain : 0db, 10db, 20db
Consumption: 5W
Size : WxHxD 110 x 44 x 280mm
Weight : 1.5 Kg
robo7 is offline
Old 03-12-2005, 12:10 PM   #85 (permalink)
Junior Head-Fi'er
Profile
Default Headline cheaper PSU
Originally Posted by kuma
Amp manufacturer : Naim Audio
Amp name/model : Headline 2
In production? : YES
List price: 550$/Headline2
450$/NAPSC power supply 1,000$/FlatCap2 power supply 1,750$/HiCap2 power supply
Type of amp: Solid State
Power output ( into 8 Ohms ): 560mW/channel
Crossfeed? : NO
Portable?: NO
Power supply : Yes. AC type. Must be used with external power supply. Optional Flat-Cap 2 or Hi-Cap maybe used in place of NAPSC
Detachable power cord? : YES
Number of headphone jacks : 1
Jack output impedance: 8 Ohms to 2 KOhms but prefer to drive high impedance headphones per company's published specs.
Jack type: 1/4"
Inputs: 1
Possible upgrades/upgrade path:
• FlatCap2 or HiCap power supply or for real crazies Super-Cap2
• install a chassis mounted DIN connector instead of a provided captive lead for a possible cable rolling
Housing material: Aluminum chassis
Size: 57 x 121 x 187 mm
• Naim Headline2 vs. Gilmore V2 with Grado RS1
It's worth pointing out than Naim now have a cheaper PSU for the headline, the "iSupply".
US price is $165, nearly $300 cheaper than the previous cheapest option, the PSC2.
BTW, with a different adapter, the iSupply can power an iPod for improved performance. Only one item at a time, though.
cheers, Martin
MartinP is offline
Old 04-08-2005, 11:50 PM   #86 (permalink)
Head-Fi'er
Gaffer74's Avatar
Profile
Default Musical Fidelity X-Cans
In production? no
final list price? £250 (GBP)
Current "street" price? About £60-£100 dependant on shop
Type of amp? Hybrid Triode Valve amp
Stock tubes? Philips JAN 6922 tubes
Crossfeed? no?
Portable? no
Power supply? external 12V AC 500mA
Detachable power cord? yes
Number of headphone jacks? 1
Jack output? 100mW into 40 Ohm (>100mW for loads >40 Ohm)
Jack type? 1/4"
Inputs? 1 line
Other outputs? 1 line
Speaker output rating? 100mW into 40 Ohm (>100mW for loads >40 Ohm)
Possible upgrades/upgrade path? not officially but could replace stock tubes with others for a different sound
Housing material? aluminium
Size? 110 x 110 x 220 (W x H x D) width and height include feet (mm)
Weight? ~3.5kg
PS Here it is with modifications inc. holes in upper casing to improve airflow ventilation over the hot tubes inside:
__________________
True music is Stereo
www.drg4.fsnet.co.uk
HiFi = Naim CD5i | PrimaLuna Prologue2 | Quad 12L | BKelec XLS200 | ChordCo cabling | ProJect 2Xperience | Ortofon MC15mkII | Pickering PLZ | GrhmSlee GramAmp2comm
Sys2 = Arcam CD72 | AVC EL34 | Tannoy M15 | MF X-Cans | Senny HD480II
AV = Jamo DVR50 & a305pdd | Panny AE500 | DRH screen | IXOS cabling
MP3 = 4G Apple 20Gb iPod | Hdphn Remote | Senny PX100 | Senny CX300 | iSkin evo2 | iPoDonut | iTrip
Gaffer74 is offline
Old 04-10-2005, 05:44 AM   #87 (permalink)
kuma's Avatar
Profile
Default
Thanks Martin!
The listing now is updated.
kuma is offline
Old 04-10-2005, 03:22 PM   #88 (permalink)
Member of the Trade
Profile
Default Channel Islands Audio VHP•1
Amp manufacturer: Channel Islands Audio (CIAudio)
Amp name/model: VHP•1
In production: yes
List price: $349
Type of amp: solid state
Crossfeed: no
Other processors: high/low gain switch
Portable: no
Power supply: AC adapter
Number of headphone jacks: 1
Jack output impedance: 30~700 ohms
Jack output: 2 watts @ 32 ohms
Inputs: 1
Other outputs: 1 loop through
Upgrades: VAC•1 High Current Power Supply ($159)
Housing material: extruded aluminum with machined aluminum panels, knobs
Size: 4.40"w x 2.65"h x 4.40"d
Weight: 4 lbs
dusty_v is offline
Old 04-16-2005, 08:01 AM   #89 (permalink)
amb
Member of the Trade:
AMB Laboratories
amb's Avatar
Profile
Default M³ Amplifier
(AMB prototype shown, actual appearances vary depending on case used)
DIY design developed by AMB and Morsel
Also available prebuilt from MisterX, thrice and SFT.
-Amp name/model: M³ (pronounced "M cubed", sometimes written as "MMM", "M3" or "M^3")
-In production? Yes
-List price: DIY: varies; Prebuilt: contact builders for pricing info
-Current "street" price: n/a
-Type of amp: Solid state class A, 3-channel topology with active ground, High current MOSFET outputs, AD8610, OPA627 or other opamp voltage gain stage.
-Stock tubes: n/a
-Crossfeed: None, can be optionally added
-Other processors: Bass boost, continuously variable or switched (optional)
-Portable? No
-Power supply: 24VDC - 40VDC external, regulated
-Detachable power cord? Yes
-Number of headphone jacks: 1 or more
-Jack output impedance (per jack, if more than one): < 0.05 ohm
-Jack output (per jack, if more than one -- include @ #Ohms) n/a
-Jack type: 1/4" phone or others
-Inputs: Line in (two unbalanced RCA)
-Other outputs: Speaker output (optional)
-Speaker output rating: 6Wrms/ch into 8 ohms (with 36VDC 3A PSU)
-Possible upgrades/upgrade path: See websites
-Input Sensitivity: n/a
-Maximum Gain: 11 (20.8db) default, can be built to other gain settings
-Input Impedance: 47.6K ohms
-Output Impedance: < 0.05 ohm
-Total Harmonic Distortion: 0.0009% (RMAA)
-Intermodulation Distortion: 0.0051% (RMAA)
-Frequency Response: 0Hz - 1.5MHz, +0, -3dB
-Signal to Noise Ratio: 97dBA (RMAA)
-Stereo Crosstalk: -95dB (RMAA)
-Housing material: Various choices
-Size (dimensions): Various choices
-Weight: n/a
amb is offline
Old 06-13-2005, 11:31 PM   #90 (permalink)
Junior Head-Fi'er
Profile
Default Harmony Design Ear 90
The Ear-90 Headphone Amplifier
Amp manufacturer: Harmony Design
Amp name/model: Ear 90
In production: Yes
List price: Unbalanced $500, balanced $600
Crossfeed: No
Portable: No
Power supply: AC 230/115V
Detachable power cord: Yes
Number of headphone jacks: 2
Jack type: 1/4"
Inputs: One balanced or one unbalanced
Possible upgrade: Elma level control
Housing material: Steel + stainless steel + aluminium.
Size: H 50, W 25 , D 21.
Weight: 2.2 kg
Stridbeck is offline
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0 Head-Fi.org
