Head-Fi: Covering Headphones, Earphones and Portable Audio
Support Head-Fi by starting your Amazon.com shopping by clicking here
Follow headfi on Twitter!
Follow Rocky Mountain Audiofest (RMAF) on Twitter!
Head-Fi Is Sponsored By:
Featured
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
Can Jam '09
(2009 International
Head-Fi Meet)
Impressions,
Reviews, Photos
Can Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss 1, 2, 3
dallan 1, 2, 3, 4
santacore 1, 2
nhat_thanh 1, 2
vpivinylspinner 1, 2, 3
amb 1
augustwest 1
eaglejo 1
johnsonad 1
shellylh 1
Jon L 1, 2, 3, 4
Germancub 1
zippy2001 1
IPodPJ 1
bhd812 1
Edwood 1, 2
abellaw 1, 2
minidiscs 1
atothex 1
HighLife 1
achristilaw 1
SiBurning 1, 2, 3, 4
SiBurning 5, 6, 7
LFF 1
Iron_Dreamer 1
doping panda 1
morphsci 1
ironbut 1
shaizada 1
jasper994 1, 2
jp11801 1
Uncle Erik 1
drubrew 1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Featured
Head-Fi's Sponsors
Featured
  #121 (permalink)
Old 11-09-2007, 02:22 AM
musicmind's Avatar
1000+ Head-Fi'er
Default
Mazuki, thanks for the TubeCAD site link, lots of great information there...and btw, also for the great review that got this thread started.
Are you also still regularly using your K1000 with the 337? I never found the actual power rating for the 337, I wonder if it would fare better than the T-amp when used with a K1000?
Thanks
  #122 (permalink)
Old 11-09-2007, 02:52 AM
MaloS's Avatar
Default
Originally Posted by Mazuki View Post
Malos, you used to own a Darkvoice 332. It wasn't that bad was it? The FEEL you had for a while didn't blow everything out of the water did it?
No, Darkvoice 332 was superior. Tis a good amp.
__________________
Ovation Legend 1767. It is perfectly capable of reproducing music.
Team Dispel the Myth.
  #123 (permalink)
Old 11-09-2007, 03:52 AM
Jo6Pak's Avatar
100+ Head-Fi'er
Default
So, what's the hierarchy here? 336 ->332 ->337, in terms of 'quality'? If so, what makes the 332 and 337 so much better? I realize you'll get more power per channel outta the 337, but what about the 332? Are the components in that one so much better than in the 336i? I have had my 336i for a few weeks now and it just keeps sounding better. If DV makes something superior to it, I'm inclined to try it...
__________________
Rig 1:
Marantz CD5400→Behringer DEQ2496→DarkVoice 336i→Senn HD650.
Rig 2:
Sony RCD-W500C→Behringer SRC2496/FBQ1502→Original Master→Senn HD650.
  #124 (permalink)
Old 11-09-2007, 04:06 AM
MaloS's Avatar
Default
A bit more of
336 -------> 332 -> 337
Different, cleaner design on bigger amps. 337 is dual mono for crying out loud, while 336 uses two dual tubes, each amping 2 channels. Basically higher you go, the more separated the channels become.
__________________
  #125 (permalink)
Old 11-09-2007, 04:16 AM
Jo6Pak's Avatar
100+ Head-Fi'er
Default
Wow, I had now idea the 336i was that far down the chain from the 332. I'm aware of the dual-ness of the 337, but I'm mostly comparing 2-channel/1-knob stuff here. IIRC from another thread, there is not much difference in price between the 336i and 332 and was curious why the 332 gets higher marks. I could be mistaken...
__________________
Rig 1:
Rig 2:
  #126 (permalink)
Old 11-09-2007, 04:49 AM
cclragnarok's Avatar
100+ Head-Fi'er
Default
The 332 is a newer amp than the 336 and the 337. The official word is that they used the exact same topology as the 337, and managed to make the amp smaller without losing too much sound quality.
The 336 is a different design as far as I know. So while "336 -------> 332 -> 337" is the supposed ranking of the amps, the 336 might also sound different (as opposed to strictly inferior).
By the way, the 332 is almost twice as expensive as the 336i in China. Over here, the price difference doesn't seem that big, but that's mostly because the (rather large) cost of shipping is about the same for both.
  #127 (permalink)
Old 11-09-2007, 05:55 AM
500+ Head-Fi'er
Default
No problem, there's a lot of articles on TubeCAD about the Cathode Follower topology. I highly recommend reading all of them. Thanks for the positive comments about my review!
The K1000s in the picture are actually borrow from a friend. I do not use them anymore. I actually read somewhere on the Darkvoice forum that the 337 might not have enough power to drive the K1000s. An inherent problem with the cathode follower circuit is it's low gain. Therefore even though it definitely did not sound bad, I fear the 337 is probably not driving the K1000 to it's fullest potential.
You could try building a Gainclone for your K1000s. That would most likely work better.
  #128 (permalink)
Old 11-09-2007, 06:02 AM
500+ Head-Fi'er
Default
Yes, as I mentioned previously, the 336 uses half a 6SN7 to drive half a 6AS7.
Also true, the 332 and 337 both use a pentode as a driver. However the 6C19P tube used in the 332 is only half a 6AS7. So the 337 using both sections of the 6AS7 is inherently more powerful.
All Darkvoice amps share similar components across the board. I have a feeling the 51uF SCR coupling cap on the 337 is unique. However, the transformer, filtering capacitors, resistors, etc, are all shared. All three amps have significant homology.
Also there are plenty of discussions regarding the differences between miniature tubes (used in 332) and octal tubes (used in 336 and 337). Many people swear octals sound better. But we're going into an entirely different territory here.
  #129 (permalink)
Old 11-09-2007, 06:31 AM
NoPants's Avatar
500+ Head-Fi'er
Default
I'm curious as to where you found those 6528 monsters...
__________________
"I wish I could marry a toilet seat, it accepts everything I have to give it"
Home: foobar > m-audio transit > bel canto DAC2 > darkvoice 337 > ad2000
k1000
Feedback
  #130 (permalink)
Old 11-09-2007, 06:40 AM
500+ Head-Fi'er
Default
I was fortunate to find a nice guy on eBay that had some left-over NOS. It was a great deal, $50 for both tubes, new.
The 6336A tube is essentially two 6AS7 paralleled into one envelope. The 6528 tube is a 6336A with a higher mu (gain).
  #131 (permalink)
Old 11-09-2007, 08:02 AM
100+ Head-Fi'er
Default
I always wondered about that. Do you know what the 337 does with the two sections of a 6AS7? Push-pull maybe?
  #132 (permalink)
Old 11-09-2007, 08:21 AM
MaloS's Avatar
Default
Knowing their topology, push pull would be utterly pointless, so most likely its just parallel.
__________________
  #133 (permalink)
Old 11-09-2007, 08:52 AM
100+ Head-Fi'er
Default
I guess if it is push pull, then the topology wouldn't really be the same as the 332. So you are probably right.
  #134 (permalink)
Old 11-09-2007, 12:19 PM
500+ Head-Fi'er
Default
If you take a look at the picture in post #99, you can clearly see the two sections of the 6AS7 are paralleled in 337.
  #135 (permalink)
Old 11-09-2007, 12:34 PM
jonoliew's Avatar
100+ Head-Fi'er
Default
so after reading alll these pages, the 337 seems to be better than the doge, and there's no real comparison with the bada ph12 (which is rather unreliable due to the mosfets). Then the 332 is close to the 337? so how close is the 332 to the doge? lol.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
