Support Head-Fi.org by starting all of your Amazon.com shopping by clicking here.
____________________________________________________________________
Today's Featured Head-Fi Blog:  A Japanese headfier's monologue (Sasaki)
Please help support Head-Fi by becoming a Contributing Member  CLICK HERE
-- Contributing Members, thank you for your generous support! --
Head-Fi Is Sponsored By:
Register FAQ Blogs Members List Calendar Mark Forums Read Today's Posts Search
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
2008 International
Head-Fi Meet
(Can Jam '08)
Impressions,
Reviews, Photos
Can Jam '08 graphic
courtesy of Edwood
Click on the links below
for Can Jam '08 photos,
impressions and reviews:
NightWoundsTime
lan
agile_one
wavoman
crappyjones123
Luke G
bperboy
jimaxp
Can Jam '08 Logo
T-Shirts For Sale
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Head-Fi's Sponsors
Featured
Go Back   Head-Fi: Covering Headphones, Earphones and Portable Audio > Equipment Forums > Computer Audio
Computer Audio Discussion of computers as source components, sound cards, USB DACs, media servers, etc.
TTVJ Millett Portable Amp & The Most Recent Sponsored Threads
Sales to Benefit Head-Fi (TTVJ Millett Portable Amp)
Reply
Thread Tools Display Modes
Old 03-01-2008, 08:14 PM   #41 (permalink)
Profile
Default
You may know this already, I don't know how many times you've rebooted......but if you reboot without the 0404 USB connected, don't load any player applications at all, and immediately go into Sounds and Audio Devices, what does it show?
sejarzo is offline
Old 03-01-2008, 08:17 PM   #42 (permalink)
Profile
Default
Jiitee, should he try to run dxdiag at some point, just to be sure that something isn't goofed up there that, for whatever reason, Foobar can get around, but the other playback apps cannot?
sejarzo is offline
Old 03-01-2008, 08:20 PM   #43 (permalink)
Head-Fi'er
Profile
Default
I'm using System Restore to check what I've been installing: I've installed a couple of drivers, a wifi driver, new bios and a driver for the Sigmatel soundcard.
Halqyon is offline
Old 03-01-2008, 08:27 PM   #44 (permalink)
Profile
Default
I guess what bugs me is that your onboard isn't being seen by all the other playback apps, which seems to be more of a Windows problem.
Let's try this....click Start>Run, then type dxdiag in the box and click the OK button. Select the option to not connect to check for signed drivers (I cannot recall the exact wording) and let dxdiag start up. You should then see a Sound tab, and when you click on that tab, you can then click the "Test DirectSound" button to be sure that the Sigmatel drivers are all OK.
I wonder if installing a new driver could possibly have caused the other apps not to recognize the onboard sound, though, but first make sure that the Sigmatel works fine in DirectSound mode.
I'm guessing here, but it might be that the new Sigmatel driver installation didn't configure properly for some reason.
sejarzo is offline
Old 03-01-2008, 08:32 PM   #45 (permalink)
Profile
Default
What I meant was more along the lines of did you stop or disable any services as jiitee mentioned in post #7 of the thread.
sejarzo is offline
Old 03-01-2008, 08:36 PM   #46 (permalink)
Head-Fi'er
Profile
Default
I did what you said and this is what it said : DirectSound test results: Failure at step 3 (DirectSoundCreate): HRESULT = 0x88780078 (No driver)
Halqyon is offline
Old 03-01-2008, 08:41 PM   #47 (permalink)
Profile
Default
Well, that says to me that the Sigmatel driver installation was goofed up.
I'd suggest going to the Sigmatel page and finding out exactly how to uninstall and reinstall the driver. Sometimes installing a new one without following some explicit directions for uninstalling the previous one will result in big problems.
You had to download that driver installer from Dell, correct?
EDIT: Well, I see that Sigmatel sold out their PC audio device business, and that the Dell page for the driver sure doesn't give any info on install instructions.
sejarzo is offline
Old 03-01-2008, 08:51 PM   #48 (permalink)
Profile
Default
Jiitee, do you think that maybe he should do a System Restore back to a time when he knew that that the onboard audio worked with WMP? I have to believe that something goofed up in the driver update that is now causing him problems with DirectSound, and that might be the most direct way to get out of the mess?
sejarzo is offline
Old 03-01-2008, 08:53 PM   #49 (permalink)
Head-Fi'er
Profile
Default
Hmm, just installed the driver again, but it still doesnt work. Maybe I should restart?
Halqyon is offline
Old 03-01-2008, 09:23 PM   #50 (permalink)
Profile
Default
Yes, restart.
Then immediately go into XP's Device Manager when your system boots up. Click the + to expand the "Sound, video, and game controllers" section....see if there is a problem noted with the Sigmatel driver. I don't know if there will be a valid rollback option available there, if you've installed and reinstalled a new driver (never had to do that myself!)
I am confused a bit by the page for your notebook at Dell......did Dell supply some with a Creative Audigy internal card, and others with the Sigmatel? I can only get to the page that shows drivers for all XPS 1710M's which show both. You probably get to a support page specific to your serial number, though, that shows only the drivers required for your specific hardware, maybe?
sejarzo is offline
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0 Head-Fi.org
