Head-Fi: Covering Headphones, Earphones and Portable Audio
Support Head-Fi by starting your Amazon.com shopping by clicking here
Follow headfi on Twitter!
Follow Rocky Mountain Audiofest (RMAF) on Twitter!
Head-Fi Is Sponsored By:
Featured
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
Can Jam '09
(2009 International
Head-Fi Meet)
Impressions,
Reviews, Photos
Can Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss 1, 2, 3
dallan 1, 2, 3, 4
santacore 1, 2
nhat_thanh 1, 2
vpivinylspinner 1, 2, 3
amb 1
augustwest 1
eaglejo 1
johnsonad 1
shellylh 1
Jon L 1, 2, 3, 4
Germancub 1
zippy2001 1
IPodPJ 1
bhd812 1
Edwood 1, 2
abellaw 1, 2
minidiscs 1
atothex 1
HighLife 1
achristilaw 1
SiBurning 1, 2, 3, 4
SiBurning 5, 6, 7
LFF 1
Iron_Dreamer 1
doping panda 1
morphsci 1
ironbut 1
shaizada 1
jasper994 1, 2
jp11801 1
Uncle Erik 1
drubrew 1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Featured
Head-Fi's Sponsors
Featured
  #31 (permalink)
Old 03-01-2008, 07:31 PM
Default
Yes, enable it, and see if we can get WMP to play through that first. Best to power down and disconnect the 0404 USB for now.
Once we can get WMP playing again with onboard sound, try a reboot, then reconnect and power up the 0404 USB, then we'll go into Control Panel>Sounds and Audio Devices and check the settings there again before going back into WMP.
My WMP settings under Tools>Options>Devices>Speakers, Properties show that the "Audio device to use:" is "Default DirectSound Device".....I've never had to change anything there.
IMHO, E-MU is just playing it very safe by suggesting that you disable onboard sound--I don't think anyone has reported any difficulty with the 0404 USB in conjunction with enabled onboard sound once various XP and player settings are all correct.
  #32 (permalink)
Old 03-01-2008, 07:42 PM
Head-Fi'er
Default
I enabled the onboard soundcard but Im not getting any sound from the speakers when using WMP (same with winamp or youtube), but when I use Foobar i get sound....
  #33 (permalink)
Old 03-01-2008, 07:44 PM
Default
How do you have Foobar set for output? ASIO?
  #34 (permalink)
Old 03-01-2008, 07:48 PM
Head-Fi'er
Default
Nope, not using ASIO, its set to DS : Sigmatel Audio.
  #35 (permalink)
Old 03-01-2008, 07:50 PM
Default
OK, then, what happens when you open the Sounds and Audio Device applet in XP Control Panel? I'm still assuming that the 0404 USB is disconnected at this point.
Also, just to be safe, make sure that you have completely exited Foobar when trying to run any other playback app!!!
  #36 (permalink)
Old 03-01-2008, 07:53 PM
Head-Fi'er
Default
Yes the 0404 is disconnected. In the control panel it still says no devices....
  #37 (permalink)
Old 03-01-2008, 07:55 PM
1000+ Head-Fi'er
Default
Check if the "Windows Audio" service is running (start run services.msc)
I checked just that as for an example, Beatport SYNC can play audio even this service is stopped ... WMP gives just error message and Foobar is silent w/ DS output.
jiitee
__________________
VST/DX (effect) plug-ins with Winamp, MediaMonkey and Foobar 0.8.x-0.9.x - needed components :
Winamp and MediaMonkey: VST support - VST Host DSP for Winamp, DirectX support - FFX-4 for WinAmp
Foobar: VST Host plug-in: (0.9.x) Cannibal Zerg's George Yohng's and FFX-4 VST for DX plug-ins (see above)
Additional plug-ins: Acon EffectChainer (DX/VST), CTAF MultiFXVST (VST), XLUTOP Chainer (VST), energyXTEffect (VST)
Output plug-ins: Foobar: ASIO and KernelStreaming (0.9.x), ASIO (0.8.x) ... Winamp and MediaMonkey: ASIO and KernelStreaming ... WMP: ASIO 3rd party ASIO drivers: Asio4All, ASIOx (discontinued?), ASIO2KS, USB-ASIO, FireWire-Universal and Ideal (+ OEM), ..... !!! ASIOCaps ASIO Control panel, ASIO Config launcher
Favorite player: Native Instruments - TRAKTOR BeatPort SYNC
  #38 (permalink)
Old 03-01-2008, 07:58 PM
Default
I sure hope it's that, jiitee, because otherwise something sure seems goofed up in his XP audio config, right?
Onboard devices should always show up in the Sounds and Audio Devices applet in XP Control Panel, AFAIK....unless as you suggest, if Halqyon mistakenly stopped the Windows Audio service when trying to fix the pop/click situation, maybe?
  #39 (permalink)
Old 03-01-2008, 08:01 PM
Head-Fi'er
Default
Windows Audio is running, maybe I should restart it?
  #40 (permalink)
Old 03-01-2008, 08:04 PM
Default
Do you recall all of what you did in previous attempts to stop the pop/click problem once we suggested the DPC latency checker? Something tells me that a setting got messed up between then and now.
  #41 (permalink)
Old 03-01-2008, 08:14 PM
Default
You may know this already, I don't know how many times you've rebooted......but if you reboot without the 0404 USB connected, don't load any player applications at all, and immediately go into Sounds and Audio Devices, what does it show?
  #42 (permalink)
Old 03-01-2008, 08:17 PM
Default
Jiitee, should he try to run dxdiag at some point, just to be sure that something isn't goofed up there that, for whatever reason, Foobar can get around, but the other playback apps cannot?
  #43 (permalink)
Old 03-01-2008, 08:20 PM
Head-Fi'er
Default
I'm using System Restore to check what I've been installing: I've installed a couple of drivers, a wifi driver, new bios and a driver for the Sigmatel soundcard.
  #44 (permalink)
Old 03-01-2008, 08:27 PM
Default
I guess what bugs me is that your onboard isn't being seen by all the other playback apps, which seems to be more of a Windows problem.
Let's try this....click Start>Run, then type dxdiag in the box and click the OK button. Select the option to not connect to check for signed drivers (I cannot recall the exact wording) and let dxdiag start up. You should then see a Sound tab, and when you click on that tab, you can then click the "Test DirectSound" button to be sure that the Sigmatel drivers are all OK.
I wonder if installing a new driver could possibly have caused the other apps not to recognize the onboard sound, though, but first make sure that the Sigmatel works fine in DirectSound mode.
I'm guessing here, but it might be that the new Sigmatel driver installation didn't configure properly for some reason.
  #45 (permalink)
Old 03-01-2008, 08:32 PM
Default
What I meant was more along the lines of did you stop or disable any services as jiitee mentioned in post #7 of the thread.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
