Support Head-Fi.org by starting all of your Amazon.com shopping by clicking here.
____________________________________________________________________
Today's Featured Head-Fi Blog:  Jude's Blog
Please help support Head-Fi by becoming a Contributing Member  CLICK HERE
-- Contributing Members, thank you for your generous support! --
Head-Fi Is Sponsored By:
Register FAQ Blogs Members List Calendar Mark Forums Read Today's Posts Search
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
2008 International
Head-Fi Meet
(Can Jam '08)
Impressions,
Reviews, Photos
Can Jam '08 graphic
courtesy of Edwood
Click on the links below
for Can Jam '08 photos,
impressions and reviews:
NightWoundsTime
lan
agile_one
wavoman
crappyjones123
Luke G
bperboy
jimaxp
Can Jam '08 Logo
T-Shirts For Sale
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Head-Fi's Sponsors
Featured
Go Back   Head-Fi: Covering Headphones, Earphones and Portable Audio > Equipment Forums > Computer Audio
Computer Audio Discussion of computers as source components, sound cards, USB DACs, media servers, etc.
TTVJ Millett Portable Amp & The Most Recent Sponsored Threads
Sales to Benefit Head-Fi (TTVJ Millett Portable Amp)
Reply
Thread Tools Display Modes
Old 08-27-2007, 10:30 AM   #31 (permalink)
100+ Head-Fi'er
Seidhepriest's Avatar
Profile
IM Contacts
Send a message via ICQ to Seidhepriest
Default
Must be an SSRC plugin option... Have you tried the Winamp setup?
Seidhepriest is offline
Old 08-27-2007, 10:33 AM   #32 (permalink)
1000+ Head-Fi'er
b0dhi's Avatar
Profile
Default
In Winamp I use an ASIO output plugin that has SSRC built into it. It works fine there, but ofcourse...no linear mode. The winamp version doesn't have a hardware mixing option either, though.
__________________
They gave me his photo, threw me in a pizza oven, called it a "pod", and told me to wing it
b0dhi is offline
Old 08-27-2007, 10:37 AM   #33 (permalink)
100+ Head-Fi'er
Profile
IM Contacts
Default
Whee. So well... Does the F2000 SSRC do linear resampling?
The current versions of SSRC lacking an option for software or hardware resampling might mean it automatically switches if hardware resampling fails, or just does everything in software (it is safer, and hey, CPUs nowadays are powerful...).
According to Wiki, http://en.wikipedia.org/wiki/Free_Lossless_Audio_Codec , FLAC supports non-floating-point bit depth of up to 32-bit and any sampling rate up to 1048570 Hz. So as long as the wave format is integer-based, an external editor should be capable of linear resampling, then FLAC could re-encode the 192-KHz waves.
Old 08-27-2007, 10:54 AM   #34 (permalink)
1000+ Head-Fi'er
b0dhi's Avatar
Profile
Default
You're talking about SSRC and not SRC, right? If so, no, it doesn't.
__________________
b0dhi is offline
Old 08-27-2007, 11:03 AM   #35 (permalink)
100+ Head-Fi'er
Profile
IM Contacts
Default
So you're pretty much stuck with SRC?
Old 08-27-2007, 11:08 AM   #36 (permalink)
100+ Head-Fi'er
Profile
IM Contacts
Default
The way it looks...
1. A stack of Winamp DSP adapter for F2000+Adaptx 3.5 DX adapter+some kind of Directx linear resampler.
2. The same stack, except running natively in Winamp. DSP processing is done before output. Hence whatever the DSP resampler's going to pass to the output plugin, won't be affected by the plugin's resampling.
3. A linear resample in an external wave editor, then re-encoding to FLAC.
4. The SRC plugin author might reply?
Old 08-27-2007, 11:57 AM   #37 (permalink)
1000+ Head-Fi'er
b0dhi's Avatar
Profile
Default
Thanks for all your help. I'm going for "5. Write own plugin"
__________________
b0dhi is offline
Old 08-27-2007, 01:47 PM   #38 (permalink)
Head-Fi'er
Profile
Default
Originally Posted by b0dhi View Post
Hancoque, what artifacts are you talking about, and what upsampling rate did you use?
I created 32 bit float samples at 44.1 kHz and upsampled these to 192 kHz using the different plugins and also Adobe Audition. All calculations took place in 32 bit floating point precision (including foobar2000).
These are the results:
Spectral view (original)
Spectral view (upsampled by Adobe Audition)
Spectral view (upsampled by SRC linear)
Wave view (original)
Wave view (upsampled by Adobe Audition)
Wave view (upsampled by SRC linear)
Hancoque is offline
Old 08-27-2007, 02:07 PM   #39 (permalink)
1000+ Head-Fi'er
b0dhi's Avatar
Profile
Default
The wave view for the original and upsampled waves is not accurate. The software you're using is using interpolation between samples when it's displaying the waveform, automatically. The wave view for "original" should look very much like the one for SRC linear.
The spectral analysis seems accurate though. As expected, the linear upsampling mode measures poorly.
__________________
b0dhi is offline
Old 08-27-2007, 02:29 PM   #40 (permalink)
Head-Fi'er
Profile
Default
Yes, but the original file is a perfect sine wave when played back, the one upsampled by Adobe Audition is too but the one upsampled linearly isn't. The program shows you what you actually hear. Linear connections between each sample don't represent the real world.
The artifacts you see in the spectral view are the linearly interpolated points. They add audible distortions. Why would you want to have these?
Hancoque is offline
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0 Head-Fi.org
