Head-Fi: Covering Headphones, Earphones and Portable Audio
Support Head-Fi by starting your Amazon.com shopping by clicking here
Follow headfi on Twitter!
Follow Rocky Mountain Audiofest (RMAF) on Twitter!
Head-Fi Is Sponsored By:
Featured
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
Can Jam '09
(2009 International
Head-Fi Meet)
Impressions,
Reviews, Photos
Can Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss 1, 2, 3
dallan 1, 2, 3, 4
santacore 1, 2
nhat_thanh 1, 2
vpivinylspinner 1, 2, 3
amb 1
augustwest 1
eaglejo 1
johnsonad 1
shellylh 1
Jon L 1, 2, 3, 4
Germancub 1
zippy2001 1
IPodPJ 1
bhd812 1
Edwood 1, 2
abellaw 1, 2
minidiscs 1
atothex 1
HighLife 1
achristilaw 1
SiBurning 1, 2, 3, 4
SiBurning 5, 6, 7
LFF 1
Iron_Dreamer 1
doping panda 1
morphsci 1
ironbut 1
shaizada 1
jasper994 1, 2
jp11801 1
Uncle Erik 1
drubrew 1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Featured
Head-Fi's Sponsors
Featured
  #16 (permalink)
Old 07-20-2007, 06:41 AM
htbyron's Avatar
100+ Head-Fi'er
Default
OK. I did everything and finally got foobar to work with KS (finally, by reverting to an older driver). But I can't get iTunes to open. It installed OK & I get the icons. When I click on it, I get past the license/accept splash screen, but then I get this message: "The folder 'iTunes' cannot be found or created, and is required. The default location for this folder is inside the MyMusic folder." I tried manually creating such a folder in the MyMusic folder, but I still get the same error.
Any idea what else I can try?
Thanks,
Tom
__________________
Home (computer): FLAC --> FB2K --> AV-710 --> Zu Pivot IC --> Gilmore Lite --> Grado HF-1 / AKG K240 Sextett
Travel/Work: Eee PC 901 XP FB2K --> iBasso D2 Boa DAC/Amp --> Etymotic ER6i / Yuin Pk1 / A-T ATH-EW9
Portable: Ipod Classic 80GB --> [copper dock --> iBasso D2 Boa --> ] Etymotic ER6i / Koss KSC-75 / iGrado / Yuin Pk1
Feedback
  #17 (permalink)
Old 07-21-2007, 10:49 PM
ironman64's Avatar
100+ Head-Fi'er
Default
Before I do this, I want to make sure I'm reading you guys correctly.
I just reformatted my computer, without installing any sound card. I then installed my Turtle Beach Audio Advantage Micro & ASIO4all, then iTunes. If I am reading you right, my iTunes is still utilizing windows kernel mixing?
Oh, and please don't poke fun at my TBAAM--she works just as hard as anybody else out there to produce great music. For right now, I'm stuck with a college budget!
__________________
He who loves head-fi will not be satisfied with head-fi;
Nor he who loves its crossfeed, with increase.
This too is folly.
Feedback | last.fm
  #18 (permalink)
Old 07-22-2007, 08:44 AM
Elephas's Avatar
Default
Nah, no one's going to make fun of the TBAAM.
Try using foobar with your TBAAM and ASIO4ALL.
I used one on a ThinkPad T42 laptop with good results. Optical output to a DAC and amp worked well.
  #19 (permalink)
Old 07-22-2007, 09:56 AM
cmirza's Avatar
1000+ Head-Fi'er
Default
You could do alot worse than a TBAAM.
__________________
Team Grado
My Feedback
  #20 (permalink)
Old 07-22-2007, 12:51 PM
500+ Head-Fi'er
Default
Originally Posted by aestuo View Post
What's the problem?
On PCs iTunes uses Windows kernel mixing, which processes your sound file before sending it to your sound card. For example, if you lower the volume in iTunes, the kernel mixer will process and in essence resample your sound file at a lower volume, before sending it on to your sound card and applying whatever (other) volume controls you have enabled there.
KMixer will resample only if there are multiple files being played back at the same time. Are you guys absolutely sure you hear any difference? How about a blind test to negate the placebo?
  #21 (permalink)
Old 07-22-2007, 03:45 PM
infinitesymphony's Avatar
Default
The difference is subtle for most current cards, but for older cards that would otherwise have forced resampling to 48 kHz, the improvement is much greater.
__________________
Team Value-Fi.
  #22 (permalink)
Old 07-25-2007, 05:33 PM
driftingbunnies's Avatar
100+ Head-Fi'er
Send a message via AIM to driftingbunnies
Default
i finished burning in my headphones but when i try to play my pink noise mp3 or wave file on foobar with either KS or ASIO with my EMU 0202, it doesn't let me play them for some reason. i have to use DS before it works.
  #23 (permalink)
Old 07-26-2007, 06:01 AM
Default
That sounds like a resampling issue. Do other files work?
__________________
Team Value-Fi.
  #24 (permalink)
Old 07-26-2007, 05:22 PM
starmaker's Avatar
100+ Head-Fi'er
Send a message via AIM to starmaker Send a message via Yahoo to starmaker
Default
Thanks,
Tom
Did you move your My Music folder to somewhere else besides the default location?
__________________
Computer: Dell E1505 => M-Audio Audiophile USB with Stancor PSU => Meier Audio Corda PreHead-1 MKII Prototype => Sennheiser HD650 with Classic Equinox Cable or Headphile Darth Beyer Custom (Beyerdynamic DT770 Pro/80 Ohms with Blackmax Recabling and Medium Deep Circular Zebrawood and Gabon Ebony Woody)
Portable: Cowon 8GB D2 => Shure E4c
My Head-Fi Feedback
My eBay Feedback
  #25 (permalink)
Old 07-27-2007, 01:58 AM
starmaker's Avatar
100+ Head-Fi'er
Default
When you say the volume bar doesn't work, you mean window's volume bar not itunes right?
__________________
My Head-Fi Feedback
My eBay Feedback
  #26 (permalink)
Old 07-27-2007, 05:27 AM
htbyron's Avatar
100+ Head-Fi'er
Default
Yes, I did. And probably inartfully, too! I put it on an external drive. And that folder has my name (Tom's Music) , but it doesn't show up in My Documents -- I have to navigate to it by going to the drive letter. But now there's a new My Music folder under My Documents, which doesn't have anything except a blank iTunes folder in it (no music, of course).
Any tips on how to solve this? I don't really have the room on the onboard drive to put the music files there.
Thanks,
Tom
__________________
Feedback
  #27 (permalink)
Old 07-27-2007, 05:58 AM
Default
One possibility: Download the Tweak UI utility from Microsoft. It will allow you to point your documents folders to other places. I've never tried pointing My Documents to an external drive, though, so I'm not sure what would happen if the external drive was turned off.
__________________
Team Value-Fi.
  #28 (permalink)
Old 07-28-2007, 03:00 AM
starmaker's Avatar
100+ Head-Fi'er
Default
foobar passthrough doesn't seem to be working as I get crackles when I play the song in itunes and no crackles when using foobar
__________________
My Head-Fi Feedback
My eBay Feedback
  #29 (permalink)
Old 07-28-2007, 07:31 PM
Member of the Trade:
Empirical Audio
Default
Originally Posted by holland View Post
what's the diff between the resampler (secret rabbit code) and the one that comes with foobar?
Secret Rabbit Code sounds good.
Steve N.
  #30 (permalink)
Old 07-29-2007, 11:25 PM
starmaker's Avatar
100+ Head-Fi'er
Default
Thanks,
Tom
I use to have the same exact problem too. I just got a bigger internal hd and reformatted and installed it and it works. I don't really have an other suggestions...
__________________
My Head-Fi Feedback
My eBay Feedback
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
