Support Head-Fi.org by starting all of your Amazon.com shopping by clicking here.
____________________________________________________________________
Today's Featured Head-Fi Blog:  Jude's Blog
Please help support Head-Fi by becoming a Contributing Member  CLICK HERE
-- Contributing Members, thank you for your generous support! --
Head-Fi Is Sponsored By:
Register FAQ Blogs Members List Calendar Mark Forums Read Today's Posts Search
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
2008 International
Head-Fi Meet
(Can Jam '08)
Impressions,
Reviews, Photos
Can Jam '08 graphic
courtesy of Edwood
Click on the links below
for Can Jam '08 photos,
impressions and reviews:
NightWoundsTime
lan
agile_one
wavoman
crappyjones123
Luke G
bperboy
jimaxp
Can Jam '08 Logo
T-Shirts For Sale
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Head-Fi's Sponsors
Featured
Go Back   Head-Fi: Covering Headphones, Earphones and Portable Audio > Equipment Forums > Computer Audio
Computer Audio Discussion of computers as source components, sound cards, USB DACs, media servers, etc.
TTVJ Millett Portable Amp & The Most Recent Sponsored Threads
Sales to Benefit Head-Fi (TTVJ Millett Portable Amp)
Reply
Thread Tools Display Modes
Old 07-21-2007, 06:42 PM   #11 (permalink)
Head-Fi'er
Profile
Default
ok thanks for the help guys. The advice around these forums is great. I'll check out that website when I get a minute and see what I fancy!
Theres a couple of different types. Is this the one I want?
Dual audio op-amp,OPA2134PA 10mA DIP8 or
OPA2134UA 10mA SO8?
both made by texus instruments.
Silentscope is offline
Old 07-21-2007, 07:04 PM   #12 (permalink)
100+ Head-Fi'er
Profile
Default
DIP8...Always DIP8 that is a Dual in line Package..8 pin They other are surface mount IC's these are fairly cheap I suggest you get yourself some 2227's also you may like those too. If your going headphones you only need 1 but I suggest you get 3 or 4 of both in case you go 5.1 or 7.1.
ROBSCIX is offline
Old 07-22-2007, 08:58 PM   #13 (permalink)
Head-Fi'er
Profile
Default
The only op-amps can find in stock from all the ones you mention are Dual audio op-amp,OPA2134PA 10mA DIP8. Should I just go with those? They are really cheap.
I'm finding my hd-595's quite warm and bassy with the x-med. What do the 2134's offer over the stock op-amps?
Also, do I need a chip puller or some sort of tool to remove the op-amps easily or can they be lifted out by hand or with a scewdriver?
thanks
Old 07-22-2007, 09:26 PM   #14 (permalink)
100+ Head-Fi'er
Profile
Default
Better clarity over all soundstage will get bigger and deeper. You will notice a improvement for sure.
ROBSCIX is offline
Old 07-23-2007, 02:25 AM   #15 (permalink)
Junior Head-Fi'er
Profile
Default
I just checked and they do have the ad823anz in stock, which is what I use and I can highly recommend it. It is a fair bit more expensive, but in my opinion, worth it. Actually I use a combination of 823 for the front channels and 2134s for all other channels. That might be a good option if you don't want to spend loads.
As for removing chips I just use a screwdriver. It's pretty easy, so I wouldn't worry about getting a chip puller.
FYI you can find comparisons of various opamps at http://tangentsoft.net/audio/opamps.html
neillmcd is offline
Old 07-23-2007, 11:23 PM   #16 (permalink)
Head-Fi'er
Profile
Default
Thanks Neillmcd. I've not come across anyone using the ad823anz on the X-med.
I take it they fall under he correct specs for use on the X-Med. How come they are under operational amplifiers and not audio on the website?
I also read this. "The main disadvantage of this chip is that it has a much lower output current than is typical: 15mA for the AD823 vs. around 40mA for most op-amps"
If you confirm that none of this is a problem then I'll probably go ahead and get the AD823.
I'm a bit of an amatuer with this stuff so please bare with me !
Old 07-24-2007, 03:02 AM   #17 (permalink)
Head-Fi'er
rbui's Avatar
Profile
Default
I believe that you should use a small wirecutter/clipper and cut the legs of the op-amp(s), and use a soldering gun to remove the remaining leg ends. wouldn't using a screwdriver to pry them off have the potential of damaging the PCB, or any adjacent circuitry?
rbui is offline
Old 07-24-2007, 12:03 PM   #18 (permalink)
Junior Head-Fi'er
Profile
Default
The op-amps on the X-meridian are socketed to permit easy swapping- the advice above is more applicable to op-amps that are not in sockets (surface mounted). In this case, a small flat screwdriver may be used (very carefully so you don't bend the legs) but a chip puller is both easier and safer.
__________________
Craig in Canada
craigmcg is offline
Old 07-24-2007, 01:16 PM   #19 (permalink)
Head-Fi'er
Profile
Default
Managed to order 2 LM4562's so hopefully they should arrive this week.
I'll just change out the front just now and see how I get on since I only use headphones and stereo speakers!
So its the 1 opamp closest to the back plate with the outputs on it.
Old 07-24-2007, 02:39 PM   #20 (permalink)
100+ Head-Fi'er
Profile
Default
Yes. Closet to the back plate.
ROBSCIX is offline
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0 Head-Fi.org
