Head-Fi: Covering Headphones, Earphones and Portable Audio
Support Head-Fi by starting your Amazon.com shopping by clicking here
Follow headfi on Twitter!
Follow Rocky Mountain Audiofest (RMAF) on Twitter!
Head-Fi Is Sponsored By:
Featured
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
Can Jam '09
(2009 International
Head-Fi Meet)
Impressions,
Reviews, Photos
Can Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss 1, 2, 3
dallan 1, 2, 3, 4
santacore 1, 2
nhat_thanh 1, 2
vpivinylspinner 1, 2, 3
amb 1
augustwest 1
eaglejo 1
johnsonad 1
shellylh 1
Jon L 1, 2, 3, 4
Germancub 1
zippy2001 1
IPodPJ 1
bhd812 1
Edwood 1, 2
abellaw 1, 2
minidiscs 1
atothex 1
HighLife 1
achristilaw 1
SiBurning 1, 2, 3, 4
SiBurning 5, 6, 7
LFF 1
Iron_Dreamer 1
doping panda 1
morphsci 1
ironbut 1
shaizada 1
jasper994 1, 2
jp11801 1
Uncle Erik 1
drubrew 1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Featured
Head-Fi's Sponsors
Featured
  #1456 (permalink)
Old 01-11-2008, 09:46 PM
500+ Head-Fi'er
Default
Originally Posted by mdm510 View Post
Is their a way I can send my X-Fi Platinum to a guy who already has the parts because I cant really do this myself LOL. That'd be so awesome!
Same here, but I am going to attempt this by myself. $20 goes to the guy who does this for me, I'll cover ship both ways!
  #1457 (permalink)
Old 01-12-2008, 02:44 AM
100+ Head-Fi'er
Default
Originally Posted by borgsm1 View Post
Bichi,
1) "...Jamicon, which the general consensus regards as low quality..."
2) "...I would rather not go with your choice of smt parts because I fear it would be to hard for me..."
3) "...but I find with my koss spark plug that the original sound of x-fi was kind of dull..."
1) Have not found Jamicon, G-Luxon or WinCap, installed on X-FI series, to be "technically" that bad. About 100 caps replaced on X-FI SB0460 / SB0550, found one Jamicon SS, 47uf @ 16vdc, to be out of spec. Value, ESR/ESL and DF generally measured in "very good" category.
2) Not recommending SMT parts I used, but the value, 33uf and its 6.3mm diameter size, used as an example.
3) Might be a good idea to run some RMAA tests, for an objective "baseline" to compare stock vs. mods. Would be cool if you posted "pre-mod and post-mod" RMAA tests...
RMAA v6.0.6:
Latest News. Audio Rightmark
For the others considering Nichicon AUDIO series:
KZ Premium Grade Type, MUSE, For Audio Equipment –40 to +85
http://www.nichicon.co.jp/english/products/pdf/e-kz.pdf
FG High Grade Type, For Audio Equipment –40 to +85
http://www.nichicon.co.jp/english/products/pdf/e-fg.pdf
KW Standard, For Audio Equipment –40 to +85
http://www.nichicon.co.jp/english/products/pdf/e-kw.pdf
MW 5mmL, For General Audio Equipment –40 to +85
http://www.nichicon.co.jp/english/products/pdf/e-mw.pdf
105 SERIES:
KT 105°C Standard, For Audio Equipment –55 to +105
http://www.nichicon.co.jp/english/products/pdf/e-kt.pdf
UQ 105°C Chip Type, For Audio Equipment –40 to +105
http://www.nichicon.co.jp/english/products/pdf/e-uq.pdf
__________________
CURRENT: (mild OC)
P5W DH Deluxe Rev 1.02G/66MOAG (BIOS: 2406); CPU: Q6700 (G0, wk 23) @ 3.0G; FSB: 300
MEMORY: OCZ OCZ2G11002GK 2x1gB or 4x1gB PC2-8800; vDIMM = 2.15vdc; 500mhz; 3:5; 5-5-5-15/18; 6113/6093
HSF: Thermalright SI-128 w/120mm; LOADED TEMPS: CPU: 119f/48c; Cores(avg): 143f/62c; MEM: 102f/39c; AMB: 72f/22c
GFX: AIW 2006 Edition PCIE; PSU: Seasonic S-12+ 550W; FANS: 4 x 120mm; 2 x 80mm (all low RPM, low noise)
DRIVES: 7200.10 250G (x2); 7K500 500G (x1); 7200.10 400G (x2); 7200.10 250G (x1); ADDED Controller: Adaptec 1430SA PCIE
AUDIO: X-FI Elite MOD: http://www.esnips.com/web/X-FIOpAmpandCapModification/ OPTICAL: LiteOn: DH-20A4P and LH-20A1H;
SYSTEM: http://www.esnips.com/web/ConroeReady
  #1458 (permalink)
Old 01-13-2008, 06:49 AM
Junior Head-Fi'er
Default
anyone encounter this error before:
after doing the whole mod, my PC won't recognize X-Fi, tried on other PC too, same problem.
tried reseating, changin PCI slots, cleaning the gold fins, searching new device at device manager, and still the same problem.
it's Xtreme Gamer Fatal1ty.
the only difference in mod parts is the supply caps, i used BG STD 3300uF 16v.
  #1459 (permalink)
Old 01-13-2008, 03:19 PM
Junior Head-Fi'er
Default
Hi all, in the last few days my unmodedd X-fi extreme music began sounding a little strange, so I did some testing with RMAA.
Here is the result
I suppose it is caused by a leaking coupling cap (I also get 180mV DC on right channel and 30mV on left channel).
I can easily get Panasonic FC caps, do you think they are a good replacement?
Thanks for your help
  #1460 (permalink)
Old 01-16-2008, 04:44 PM
Junior Head-Fi'er
Default
Sorry not regarded as low quality but was prone to leak I misread the first post. I have misconceived it as low quality.
I have an Xtreme music by the way. I forgot to post it.
When I get everything I would measure my x-fi using the RMAA and will install latest drivers on fresh windows xp sp2 installs with latest hotfixes. and will try it again after the mods.
It's sad that they did the power connector only for the i/o module if it was otherwise it would have helped in the proper power supply for the opamps and may have given the users better sound.
  #1461 (permalink)
Old 01-16-2008, 11:29 PM
Junior Head-Fi'er
Default
so for the powerfilter area on the x-fi, we replace it with a 1000uf or more 16 volt blackgate. right? however, i read that the solid conductive polymer capacitors have lower esr and they are more capacitive. wouldn't having a big blackgate for filtering, the analog section, we use standard blackgates and the digital section, we use the conductive polymer ones? what are the most important specs that one needs to know when comparing capacitors for sound cards? the sanyo oscons are conductive polymer and seems interesting. Also, i read somewhere in this thread that the nonpolar version of caps perform better, but take longer to burn in. is this true?
  #1462 (permalink)
Old 01-21-2008, 02:10 AM
500+ Head-Fi'er
Default
woot, after about an hour of being frustrated because the AD8599 kept moving because it was so small and putting on way too much solder, booted up the computer for the second time and bam there's sound.
First thing I noticed was way better mids and more soundstage.
WOW, listening to No Roads Left - Linkin Park Instruments and details I seriously never heard before and the clarity.... Best $20 ever spent on materials to get that opamp in. Now I won't need to get that Zero amp anymore.
__________________
X-FI XtremeMusic ( modded ) -> Zhaolu D2.5C -> Denon AH-D2000 / Koss KSC75 / Sony XD400
Sold: HD485, HD555, DT770 Pro, Headsix, Hornet-M, SR-225, Portapro, iGrados ( died )
  #1463 (permalink)
Old 01-21-2008, 02:22 AM
500+ Head-Fi'er
Send a message via MSN to Maniac
Default
One trick is to use paper based masking tape to fix it in place. Paper is surprising resilient against heat, even blowing it with 450C + air (Eutectic 63/37 solder melts at less than 180C), it can still hold for a while without getting completely burnt into ash.
Not to mention burning paper smells about a million times better than burning plastic.
__________________
Currently applying for Member of Trade status...
Feedback Thread: http://www.head-fi.org/forums/f12/maniac-329127
The creator of UberShipSpeed, ExtremeNeutralToneExpansionResonancePerformanceRev ealIsolationSystemEnhancement. (USS-ENTERPRISE)
(love that string of meaningless acronyms...)
  #1464 (permalink)
Old 01-22-2008, 05:49 AM
100+ Head-Fi'er
Default
I have the Prelude. I love the way it sounds. Is there even a need for me to look for a DAC? It seems from what I've read that an XFi with the right components will even beat the likes of DAC1 and Apogee Mini-DAC (which costs quite a bit).
  #1465 (permalink)
Old 01-22-2008, 03:16 PM
Junior Head-Fi'er
Default Parts List
Could someone do me a favor.... I am trying to buy all the parts from digikey. I know you cannot get the blackgate there. Could I get a list of all the parts (numbers would be awesome) for the power cap, the options for opamps, and the 16 coupling caps I would need for 5.1/7.1 all around mod?
Thank you!
  #1466 (permalink)
Old 01-22-2008, 03:19 PM
Default
The Prelude uses high end DAC's and can take on and beat many devices for it's DAC quality. If you want to improve th sound of the prelude more get some new opamps such as OPA627's etc.
  #1467 (permalink)
Old 01-22-2008, 06:42 PM
Junior Head-Fi'er
Default
I have finally replaced the stock coupling capacitors with 33uF Panasonic FCs and the power filter cap with a 1500uF Rubycon MBZ. The sound improvement is huge (power filter cap made only a little difference anyway)
RMAA results for the capacitors mod:
All the testings were done on lineout 2 because lineout 1 is still ko. I thought the problem was caused by a bad coupling cap, but it is not the case. I will replace the opamp as I get some 4562 to see if it fixes the problem.
Any hint about fixing my front channel will be appreciated!
RMAA results for lineout1
  #1468 (permalink)
Old 01-22-2008, 10:40 PM
100+ Head-Fi'er
Default
But what DACs can beat the Prelude, if any? Is this a question of price range or does the Prelude at the end of the day even beat out something like a DAC1 or a Apogee Mini-DAC, which all cost 4x the price of the soundcard?
  #1469 (permalink)
Old 01-22-2008, 10:41 PM
100+ Head-Fi'er
Default
I also have no technical experience with electronics, I would not be able to solder on new opamps, unfortunately.
  #1470 (permalink)
Old 01-23-2008, 06:26 PM
Junior Head-Fi'er
Default
Bichi:
I noticed you have done a lot of testing on the thread and you have replaced more than the opamps, main power cap, and coupling caps. I was wondering you could take a look at what I have and suggest any other caps I should have changed as well.
opamps (x4): LM4562MA-ND (digikey)
Power Cap: Panny CAP 2200UF 16V ELECT FC RADIAL
Coupling Caps (x16): Panny CAP 33UF 35V ELECT FC RADIAL
I have the X-Fi out using Creative's Home Theater cable (analog) going to my Onkyo SR875 outputting to my Paradigm Monitors 5.1 (very nice ) From what I have read I might be able to get better output from my PS3 hdmi for dvd-a/SACD output, but i felt like modding something. Anything else you, or anyone for that matter, would suggest differently or in addition to?
Thanks!
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
