Head-Fi: Covering Headphones, Earphones and Portable Audio
Support Head-Fi by starting your Amazon.com shopping by clicking here
Follow headfi on Twitter!
Follow Rocky Mountain Audiofest (RMAF) on Twitter!
Head-Fi Is Sponsored By:
Featured
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
Can Jam '09
(2009 International
Head-Fi Meet)
Impressions,
Reviews, Photos
Can Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss 1, 2, 3
dallan 1, 2, 3, 4
santacore 1, 2
nhat_thanh 1, 2
vpivinylspinner 1, 2, 3
amb 1
augustwest 1
eaglejo 1
johnsonad 1
shellylh 1
Jon L 1, 2, 3, 4
Germancub 1
zippy2001 1
IPodPJ 1
bhd812 1
Edwood 1, 2
abellaw 1, 2
minidiscs 1
atothex 1
HighLife 1
achristilaw 1
SiBurning 1, 2, 3, 4
SiBurning 5, 6, 7
LFF 1
Iron_Dreamer 1
doping panda 1
morphsci 1
ironbut 1
shaizada 1
jasper994 1, 2
jp11801 1
Uncle Erik 1
drubrew 1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Featured
Head-Fi's Sponsors
Featured
  #91 (permalink)
Old 03-16-2007, 06:05 PM
Gilly's Avatar
Head-Fi'er
Default
Originally Posted by sonance View Post
How hard would it be to swap out the DAC chips on the X-Fi Xtreme Music?
How good are the DACs and OpAmps on the Elite Pro by comparison?
i think someone has said that the pin outs on the 2 dacs are not identical, so you cant replace the one on the xtreme music with the one on the elite pro.
And i guess i better risk the cap shorting/ removal. I get the popping problem on the breakout box
__________________
Foobar > Partly Modded X-fi > HD595
.flac .mp3 320k
  #92 (permalink)
Old 03-17-2007, 06:59 PM
cotdt's Avatar
Send a message via AIM to cotdt Send a message via MSN to cotdt
Default
the x-fi elite pro has a better DAC chip and would sound fuller and weightier, but the analog stage is what makes the greatest difference in sound.
__________________
Headphones: Denon AH-D2000, Senn HD595
DAC: Zhaolu 2.5 Zapfilter Mk2 balanced, amb Gamma1 γ1
Amps: SE EL84, Balanced β22, Dynahi, Mini^3, CK²III, Singlepower MPX3
HOTRODDING the X-Fi: A Layman's Guide to sonic bliss
  #93 (permalink)
Old 03-17-2007, 11:20 PM
100+ Head-Fi'er
Default what caps to short on the XFi Elite?
From what I gather I have labeled this pic
The OpAmp to replaced, and the three surrounds below it. The Power Filter Cap, and the CS4398s have been labeled. But what capacitors to short?
__________________
Take responsibilities for your actions.
Feedback
  #94 (permalink)
Old 03-17-2007, 11:40 PM
cotdt's Avatar
Default
you want to short the 16 capacitors closest to each of the 4 opamps.
__________________
  #95 (permalink)
Old 03-18-2007, 12:54 AM
100+ Head-Fi'er
Default
i have another question!
i've been reading around, and i saw that for the x-fi xtrememusic, while cmss3d is enabled, the SQ takes a noticeable hit. does this mod fix that, or does SQ still suffer while it's on?
  #96 (permalink)
Old 03-18-2007, 01:02 AM
cotdt's Avatar
Default
it will still suffer, because the problem is in the digital domain. the best way to fix it is to turn it off =).
__________________
  #97 (permalink)
Old 03-18-2007, 03:59 AM
100+ Head-Fi'er
Send a message via AIM to gates_2
Default
never got a reply from jude about the possibility of a group buy. If anyone is interested in splitting some ERS paper, let me know. I'm ordering a sheet from parts connection on monday. I'll post pics of my elite pro breakout very soon.
__________________
Team AKG
Team College
Dorm Rig: X-Fi Elite Pro(modded) bitperfect out to--> DIY Maxed Pimeta w/ TREAD/ SOHA-->AKG K501(recabled)
Onkyo c390(thanks asr!)/Modded Sony SCD-595-->5687 Tube Preamp --> Firstwatt F2 clone-->Tekton Design 4.1's
Portable: AlienDAC--> Cmoy-->ETY ER4-S
  #98 (permalink)
Old 03-18-2007, 04:13 AM
mobayrasta's Avatar
100+ Head-Fi'er
Location: Maryland USA-All over Jamaica whenever possible.
Send a message via MSN to mobayrasta
Default
cotdt can you post a pic of the completed card with all opamps changed and the recap.
__________________
Headphones-Ultrasone 2500's
AMP- SOHA dual OPA627-BUF634 output stage
X-fi with Blackgate NX 2200uF and 4x LM4562 and EFI shielding
  #99 (permalink)
Old 03-18-2007, 04:30 AM
cotdt's Avatar
Default
i put ERS paper on them so you can't see anything anymore! it's no longer naked!
__________________
  #100 (permalink)
Old 03-18-2007, 04:37 AM
Junior Head-Fi'er
Default X-Fi Output Diagram
Attached in the pdf is the output circuit that I have traced on an X-Fi Platinum. I cannot see any of the 22uF electrolytic caps in the ouput at all but have traced some connected to +5v and -5v rails. Replacing the op amps are a great idea but could more be done replacing the transistors Q2,Q3,Q4,Q5 that are all marked J1X on the front outputs and on the other outputs a different set of transistors are used marked O2NR. Anyone know what who makes the J1X and O2NR transistors?
  #101 (permalink)
Old 03-18-2007, 04:54 AM
cotdt's Avatar
Default
amazing work! you sure entered head-fi with a bang. on the newer X-Fi cards, the transistors are J1(infinity) instead of J1X and O2N- instead of 02NR. any idea what they can be replaced with?
__________________
  #102 (permalink)
Old 03-18-2007, 07:05 AM
]|[ GorE's Avatar
500+ Head-Fi'er
Send a message via Yahoo to ]|[ GorE
Default
Those capacitors dont block DC ! They are connected to the +5 and -5V lines and are meant as current reservoirs. The reason there are 4 for each opamp is to keep the capacitors impedance low . I would add a higher valued cap in parallel to the existing caps,not short them.
And,instead of doing such a hokey mod,i would look up the datasheets of the dac and add the capacitors Creative has left out.
__________________
Team EQ
Hardmodded Audigy Value 24bit (AD8620 opamps and improved power filtering) -> 48Khz Resampling ->Winamp ->diy maxed out cmoy ->[EQ'ed]Philips HP805 . Portable : Zen Neeon 6GB - >[EQ'd]Koss UR40.
  #103 (permalink)
Old 03-18-2007, 08:06 AM
cotdt's Avatar
Default
hmmmz... you sure? i'll trace the board and see...
Edit: Updated about the DC-coupling caps. I traced the opamp outputs and the 22uF are not part of the DC-coupling after all. Apparently, the X-Fi does things different from other sound cards. I still prefer the sound with those 22uF caps shorted though.
__________________
  #104 (permalink)
Old 03-19-2007, 12:48 AM
500+ Head-Fi'er
Default
hmmm interesting, the from what you guys are saying, is it better not the short them out, since they might cause damage to the chips?
__________________
as of 9-14-2008
Headphones: W5000
Amplification: Stello HP100
Source: Foobar2000 ->Juli@
Portable Audio: Sony NW-A3000 with E4C (currently broken)
Used to own: HD650 (original, Carda, Equinox), HD595, Headfive
  #105 (permalink)
Old 03-19-2007, 11:13 AM
]|[ GorE's Avatar
500+ Head-Fi'er
Default
No damage will be caused to any chips;we aren't sure what is the exact use of those 22uF caps . If they are reservoir/decoupling caps for the V+ and V- of the opamps and shorting them seems to improve the sound(according to the OP),then perhaps the Jamicons should be replaced with lower ESR caps.
__________________
Team EQ
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
