Head-Fi: Covering Headphones, Earphones and Portable Audio
Support Head-Fi by starting your Amazon.com shopping by clicking here
Follow headfi on Twitter!
Follow Rocky Mountain Audiofest (RMAF) on Twitter!
Head-Fi Is Sponsored By:
Featured
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
Can Jam '09
(2009 International
Head-Fi Meet)
Impressions,
Reviews, Photos
Can Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss 1, 2, 3
dallan 1, 2, 3, 4
santacore 1, 2
nhat_thanh 1, 2
vpivinylspinner 1, 2, 3
amb 1
augustwest 1
eaglejo 1
johnsonad 1
shellylh 1
Jon L 1, 2, 3, 4
Germancub 1
zippy2001 1
IPodPJ 1
bhd812 1
Edwood 1, 2
abellaw 1, 2
minidiscs 1
atothex 1
HighLife 1
achristilaw 1
SiBurning 1, 2, 3, 4
SiBurning 5, 6, 7
LFF 1
Iron_Dreamer 1
doping panda 1
morphsci 1
ironbut 1
shaizada 1
jasper994 1, 2
jp11801 1
Uncle Erik 1
drubrew 1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Featured
Head-Fi's Sponsors
Featured
  #76 (permalink)
Old 03-14-2007, 11:00 PM
100+ Head-Fi'er
Default
Originally Posted by Soymilk View Post
hmm... how much of a difference is there between the cs4382 DAC in the xtrememusic etc vs the cs4398 in the elite pro? and is there any difference between the xtrememusic etc that would matter?
also, for the option of getting different caps and replacing all of the caps on the soundcard, am i interpreting this wrong or do you mean replace all 20+ capacitors on the soundcard? (unless i'm stupid and am thinking of the wrong thing as capacitors)
quoted my question cuz it got no attention
  #77 (permalink)
Old 03-15-2007, 04:22 AM
aris's Avatar
100+ Head-Fi'er
Default
bedtime so soon? darn
  #78 (permalink)
Old 03-15-2007, 04:43 AM
cotdt's Avatar
Send a message via AIM to cotdt Send a message via MSN to cotdt
Default
you're going to have to hear them for yourself, because no one has ever modded an Elite Pro that i know of. however, there are some modded Zhaolu's with CS4398 and LM4562s and it should sound the same.
Yes, you can replace all the Jamicon capacitors. There are probably 20-30 on the board but half of them are coupling capacitors which you want to short anyway. I beleive you short almost a dozen capacitors if you do the surround channels and certain others, so in reality you're only replacing a dozen or so capacitors. This is entirely optional anyway, it doesn't affect sound quality. Personally, I would only replace the larger capacitors.
__________________
Headphones: Denon AH-D2000, Senn HD595
DAC: Zhaolu 2.5 Zapfilter Mk2 balanced, amb Gamma1 γ1
Amps: SE EL84, Balanced β22, Dynahi, Mini^3, CK²III, Singlepower MPX3
HOTRODDING the X-Fi: A Layman's Guide to sonic bliss
  #79 (permalink)
Old 03-16-2007, 03:10 AM
500+ Head-Fi'er
Default
I have a question. I would like to try out the mode, but afraid to do so my self
PS: I already screwed up pretty badly while moding my Deck Legend Keyboard
A 160 dollar keyboard
So currently, I am not so confident toward my soldering skill
So, here is the biggest question, would anyone do this for me?
I will pay for the shipping the component and even for the moding job as long as they are in a reasonable price. Thank you
__________________
as of 9-14-2008
Headphones: W5000
Amplification: Stello HP100
Source: Foobar2000 ->Juli@
Portable Audio: Sony NW-A3000 with E4C (currently broken)
Used to own: HD650 (original, Carda, Equinox), HD595, Headfive
  #80 (permalink)
Old 03-16-2007, 03:32 AM
soloz2's Avatar
Send a message via AIM to soloz2
Default
I am seriously considering picking up an extra x-fi card or two, modding them and then selling on other forums that are not quite as into DIY then here. Regardless of if I do that I plan to mod my x-fi. I just have to look into the budget to see if I can do it this month or if I need to wait till next month. I already have the op-amps on order
I want to see how the analogue out sounds compared to the digital out to either my upgraded Zhaolu 1.3 or my Beresford MKIII. If I like the analogue out better I'll skip the external DAC altogether... but if I still like one or the other DACs better then I'll look into upgrading the digital out.
__________________
feedback
  #81 (permalink)
Old 03-16-2007, 05:15 AM
100+ Head-Fi'er
Default
Originally Posted by cotdt View Post
To add to that, for digital you want to do a different set of mods. This is taken from Empirical Audio's website for the E-MU but it applies to any sound card including the X-Fi:
Digital Sound Card Mods
This E-MU PCI card has several opportunities to improve the S/PDIF out, including reducing the output voltage (3X the spec), improving power delivery and precisely matching to 75 ohms. After the mod is installed, the S/PDIF output is 500mV peak-to-peak. The impedance is perfectly matched to 75 ohms and the risetime is an unprecedented 5 nsec, allowing use of very short S/PDIF cables. The manufacturer cannot design it this way because they would likely fail emissions testing. However, most audiophiles are expected to use high-quality S/PDIF cables, so the emissions should not be an issue.
S/PDIF mod Details:
1. Change pulse transformer
2. Impedance match to 75 ohms
3. Add power decoupling to decoder and driver chips
4. Improve digital coupling caps
5. Remove various filter components
Would these S/PDIF mods be worthwhile? Has anyone done these and reported on the outcome?
  #82 (permalink)
Old 03-16-2007, 05:40 AM
cotdt's Avatar
Default
I'm pretty sure it would make a difference, but personally for digital I would use an I2S connection. Most modern DACs can be modified to accept I2S. This would be good for minimizing jitter. This is only worth it if the DAC was very high-end. Most budget external DACs would probably be beaten by a analog-modded X-Fi.
__________________
  #83 (permalink)
Old 03-16-2007, 05:46 AM
100+ Head-Fi'er
Default
How would you get I2S out of a computer and which sub $1000 dacs will already accept it?
  #84 (permalink)
Old 03-16-2007, 06:00 AM
cotdt's Avatar
Default
For output, dddac.de has instructions on making a USB-to-I2S convertor, and empirical audio also has several solutions for it.
As far as DACs go, most of them can be modified to accept I2S, and you can look at schematics provided by the DAC chip company.
the non-DIY solution is to wait a few years for I2S to become more standard, but sadly it might not ever happen.
__________________
  #85 (permalink)
Old 03-16-2007, 07:36 AM
droopy1592's Avatar
Head-Fi'er
Default
Originally Posted by germanium View Post
Be aware that the card puts out about 30millivolt D.C. with stock op amp at output with the coupling caps shorted. This may not seem like a lot & in most cases its not but if you have D.C. coupled amps upstream without D.C. offset compensation you can cause the amp to over heat & possably damage you amp & speakers.
You will also notice some popping sounds as the computer is booting up & shutting down.
That said the mod is really worth it especially if you have D.C. coupled amps that have D.C. offset protection. I'v done this to mine over a year ago & all my amps are D.C. coupled but with D.C. offset protection in my preamp. The sound is as good or better than my SACD player (SCD222ES).
Is it necessary to short the caps or can I leave them be and just change the filtering cap and the op amp and still get great sound? I already have a problem with a kick at boot up and I don't want it getting any louder.
got the parts on order and I should have them within a week. Ack, haven't soldered in almost 10 years.
__________________
Grado RS-2|Modded Grado SR-325|X-fi Xtrememusic|Shuttle XPC SN95G5v3 | Athlon64 X2 3800+ | Samsung 250GB Spinpoint X2 | 160GB Firewire Samsung | Passively cooled 9600 Pro 256MB | 2GB Corsair XMS RAM | NEC ND-3520a | PSU and ICE fan replacements Adda (AD0912UX-A7BGL 92mm & AD0612LX-G76 60mm) & Zalman ZM-NB47J NorthBridge HS to silence fan noise
  #86 (permalink)
Old 03-16-2007, 07:41 AM
soloz2's Avatar
Default
you can leave them alone and see how you like it w/ just the op-amp change. If you are really concerned you could get some better caps and swap them out.
or even if you just use a solder bridge to sort them you can try it easily shorted and unshorted. To unshort again just clean up the solder bridge
__________________
feedback
  #87 (permalink)
Old 03-16-2007, 10:22 AM
droopy1592's Avatar
Head-Fi'er
Default
Good Idea about the solder bridge. I'm glad I thought of it.
__________________
  #88 (permalink)
Old 03-16-2007, 05:03 PM
Gilly's Avatar
Head-Fi'er
Default
you mention replacing the shorted caps, i take it that caps of any grade will degrade the audio, so if you have DC isolated stuff your fine to short it, and will sound best shorted?
If i want to replace them, are blackgates of the same type as the power filter fine, just with a lower rating? i cant take my card out right now to look :P
__________________
Foobar > Partly Modded X-fi > HD595
.flac .mp3 320k
  #89 (permalink)
Old 03-16-2007, 05:10 PM
cotdt's Avatar
Default
blackgates are not high enough quality as output filter caps. i recommend ~3uF teflon capacitors, or at the very least film capacitors like mundorf supreme. the best for sound quality is to not have the capacitor at all.
__________________
  #90 (permalink)
Old 03-16-2007, 05:59 PM
sonance's Avatar
100+ Head-Fi'er
Default
How hard would it be to swap out the DAC chips on the X-Fi Xtreme Music?
How good are the DACs and OpAmps on the Elite Pro by comparison?
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
